Old 10-30-2002, 09:39 PM   #1
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Default Mega Squirt Fuel Injection System
Has anyone seen this? It looks like a really good deal. It only cost $110. What do you think?
Here is the website, lot's of technical info
http://www.bgsoflex.com/megasquirt.html
criscross79 is offline   Reply With Quote
Old 10-30-2002, 10:15 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Q: Does MegaSquirt control ignition?
A: No
Q: Why not?
A: Because the original goal was to develop an inexpensive fuel injection controller - something that one could you to replace a carburetor. Also, there are tons of ignition systems out there, but very few stand-alone EFI controllers, and nothing that can be put together for $150.00 like MegaSquirt.
Midwayman is offline   Reply With Quote
Old 10-31-2002, 07:37 PM   #3
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
i dont think i could buy something for my car when its named Mega Squirt
moogooob is offline   Reply With Quote
Old 11-06-2003, 06:45 PM   #4
Joel Gat, 1.8L
Member#: 32
Hello,
So... has anyone used the MegaSquirt? I want to hear more information about it. I know some of the teams are using it for the GRM $200x challenges (past and the upcoming one). It sounds pretty cool, especially for a project car. That plus a simple spark controller...
Joel Gat
Joel Gat, 1.8L is offline   Reply With Quote
Old 11-06-2003, 11:14 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Seems perfect to control a WI system
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 04-29-2004, 12:17 PM   #6
fullup1
Member#: 60629
2000 Impreza 2.5RS
Sedona Red
Sorry about reviving this old thread, but megasquirt can control spark, assuming you download the megasquirtnspark code to the controller and make a few adjustments.
Basically instead of using the FIdle pin to control an idle air motor, megasquirtnspark uses it as an output to an ignition control module. Another change is that the Coil signal to Megasquirt can't come off the ignition coil, but has to come off a Hall effect sensor on the distributor.
It's been done on some Volvo 740s and 240s, not to mention a bunch of other makes and models (Volvos are the ones I hear about). I haven't checked to see if people have used the setup with coilpacks rather than a separate ignition coil, but I haven't attempted to MSnS my 2.5RS (probably won't for a while).
Before I added a turbocharger and Megasquirt to my Volvo 240, I got somewhere around 22 mpg highway, and even going up hills could be a pain at 65 mph.
Now I'm running Megasquirt and 11.5 psi and I recently got 25.5 mpg on the way to an autocross, at the autocross, and part of the way home from the autocross. There's more tuning to be done, but with my cheap Thinkpad in the car I can make datalogs and tune all I want.
http://autos.groups.yahoo.com/group/megasquirtnspark/
fullup1 is offline   Reply With Quote
Old 04-29-2004, 02:59 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
A $60 companion to megaquirt for ignition control.
http://picasso.org/mjlj
I know Brent personally and his kit has been proven to perform well.
-Rob
rob is offline   Reply With Quote
Old 11-29-2004, 02:28 PM   #8
Joel Gat, 1.8L
Member#: 32
Hello,
Any updates on people using the MegaSquirt and related systems?
Joel
Old 12-02-2004, 06:19 PM   #9
doug242ti
Member#: 68017
I stumbled across this thread. I've been running Megasquirt + Spark control for a couple years now (spark in the last 6) and I couldn't be happier. Its pretty simple but a great setup.
(for my volvo 242ti www.cluvolvo.com and www.pbase.com/dkauer744 )
doug242ti is offline   Reply With Quote
Old 12-02-2004, 06:57 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
www.msefi.com - the MegaSquirt forums.
I have been watching the project for about 6 or so months now as I have been thinking of using it on my Corolla. I have yet to hear of anyone using one on a Subaru, though I don't see there being an issue running standalone fueling, though I'm unsure if the lack of closed loop corrections from the ECU directly would throw a CEL or not. The MS does have a closed loop mode, though, so possibly you could get it just right and not even throw a CEL.
There are PLENTY of hacks for the MS to utilize the idle output to instead control timing, most of which are using a Ford EDIS timing setup to alternate sparks for a waste spark setup. This also means adapting a 36 tooth wheel and sensor to your crank somehow, but it should be able to be done pretty easily.
Old 12-02-2004, 07:05 PM   #11
Joel Gat, 1.8L
Member#: 32
Hello,
You could do that the same way Shiv did it for the TEC-II / III folks. Bolt the toothed ring to the back of the crankshaft pulley.
Joel
Old 12-02-2004, 07:12 PM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, exactly. I think that wheel is also a 36 toother, as well, as it's a common part.
Old 12-02-2004, 07:30 PM   #13
Joel Gat, 1.8L
Member#: 32
Hello,
TEC is a 60-2 wheel... and the stock WRX uses a 30 toothed wheel. So you need to come up with your own, but these aren't hard to come by...
Joel
Old 12-03-2004, 10:28 AM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
WRX? Who needs a MS on a WRX? Flashing the ECU in a WRX/STI gets far better response then any standalone fueling would. Especially since they only reason you'd go standalone fueling is because you want to eliminate the MAF, which you wouldn't be able to do with timing on the stock ECU.
The RS is a 6 tooth pulley. My mistake on the TEC kit... I never was a big fan of it, though. *shrug*
Old 12-03-2004, 11:31 AM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah i can't see puting this on a subaru .. maybe a formula ford or somthing really basic
but if you look at the people that have been swapping subarus motors in, like the guy that put the 1.8 into the porsche 912, they have been just using the stock ecu
the next best thing would be a link 1. link is really the only ecu that supports the old style subaru IAC and the 6 tooth wheel
Old 12-03-2004, 12:27 PM   #16
Joel Gat, 1.8L
Member#: 32
Hello,
Oh, I just meant as an example. 60-2 for TEC, 30 for WRX, 6 as y'all are saying for the Impreza, etc. Not exactly standard But so many implementations out there, should be easy to do.
A couple years ago, I was close to entering a car in the GRM $200x challenge - that's where I would have used that. For a turbo Mustang.
Joel
Old 12-03-2004, 05:24 PM   #17
vizor
Member#: 13851
2002 WRX Wagon
WRBP
I'm in the middle of an engine swap and mechanical resto of an old jeep. While I'm putting in a factory MPI engine, I'm thinking of converting it to MegaSquirt to get live tuning. In the past few days I've talked to several people that have used MS for their engines, including turbocharged motors, and in general, no complaints.
A lot of four wheelers are moving to MegaSquirt to convert their old carb'd V8s to TBI or (banked) MPI injection by modifying the intake manifold. For boosted engines, MS will handle up to 20psi through the MAP sensor; any higher boost requires a different MAP sensor and MegaSquirt source code changes to handle sensor outputs.
But you nailed it Jaxx -- it's a great controller for basic setups. No way would I put it on my Scooby though.
An earlier poster is a little optimistic on price. A typical setup that includes the other diagnostic tools and possibly new sensors pushes the price to $300-400.
vizor is offline   Reply With Quote
Mega Squirt? Chp_Stix Engine Management & Tuning 47 08-08-2012 10:30 PM
Mega Squirt ModPR3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-02-2006 05:59 PM
best fuel injection/system cleaner? Sobelizard109 New England Impreza Club Forum -- NESIC 14 04-14-2003 01:10 PM
Mega Squirt Fuel Injection System criscross79 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-30-2002 03:27 AM
Fuel Injection Systems The_extreme Technical Forum Archive 0 05-30-2000 06:03 AM
