Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-30-2002, 11:24 PM   #1
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Default Is WRX motor an interference motor
From everything I've heard, it is. I have a chance to buy a motor from a wreck but am being told one of the cam gears was broken in the accident (the car was rolled and every body panel damaged and the radiator pushed back). I haven't seen it yet so I'm not sure if it was totally broken or not and if the belt is still on the gears. Thanks.
rallynutdon is offline   Reply With Quote
Old 10-30-2002, 11:40 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
The WRX's (like any Subaru DOHC) engine, is an interfernece engine. It's possible to damage the valves if the timing belt breaks or jumps a tooth due to an accident.
Jon [in CT] is offline   Reply With Quote
Old 10-31-2002, 07:39 AM   #3
JenisonWRX
Member#: 6049
02 WRX & 99 RS
I've heard its not but if both exhaust and intake valves are open they will hit each other ... but not the piston...
hmmm
JenisonWRX is offline   Reply With Quote
Old 10-31-2002, 11:37 AM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
There's no doubt that the intake and exhaust valves can interfere with each other. From the service manual:
Intake and exhaust camshafts for this DOHC engine can be independently rotated with the timing belts [sic] removed. As can be seen from the figure, if the intake and exhaust valves are lifted simultaneously, their heads will interfere with each other, resulting in bent valves.
However, there is some doubt about whether the valves can interfere with the pistons. On the one hand, the service manual says:
The piston head has recesses to prevent interference with the intake and exhaust valves.
On the other hand, in another part of the service manual, there is this:
Old 10-31-2002, 02:30 PM   #5
rallynutdon
Member#: 24568
1993 Impreza, WRX
That's my dilemma. A bent valve (or 2) "should" be easier, less expensive to repair than a piston (particluarly if the engine stopped running upon impact?). But I get varying opinions on the piston interference question. I think I'm goin gto wait for the next car with no external engine damage. Thanks.
Old 11-01-2002, 08:57 AM   #6
rallynutdon
Member#: 24568
1993 Impreza, WRX
Default Is WRX motor an interference motor-Do you know for sure?
Doesn't anyone have first hand experience with this? I'm now being told by 1 Subaru mechanic that it's only an issue with bent valves, not a big deal (which is kind of obvious with dual overhead cams). Thanks.
Old 11-01-2002, 09:09 AM   #7
XT6Wagon
Member#: 524
04 STi
A motor that is designed to be non-interferance, can STILL have valve to piston contact in the real world. This is why any manual will warn you about not screwing up the timing belt alignment.
Carbon buildup and valve float are the most common causes for this to happen.
XT6Wagon is offline   Reply With Quote
Old 11-01-2002, 11:24 AM   #8
BluSuby
Member#: 12154
04 Sti
99 Outback
FWIW I has an accident with the front end of my WRX a year ago. I hit the drivers side front corner pretty hard. I had the dealership fix everything etc... I'm down at the dealership 4 months later to talk to a SOA rep about a warranty issue. He hears my car and tells me he doesn't like the idle of my car. I bring it in a week later to get it checked and it turns out I was out of time by 4 teeth( according to the service manager)!
I'm new to Subarus. I knew they had a slight lope at idle. This was a lttle too much I guess, and I had gotten used to it.
I don't know if it jumped when I wrecked the car or if it was a faulty cam belt tensioner. When they fixed it they installed a new one along with the belt.
Regardless , my car runs fine and I haven't had any problems since.
At the time I didn't think they were interference motors. I'm confident they are now from looking at the Diagram above. I must have been lucky,
Bryan
BluSuby is offline   Reply With Quote
Old 11-01-2002, 11:30 AM   #9
bbaerotek
Member#: 10427
WR Blue
Post Just valves
I had a wreck in which this happened to my motor. One cam gear just disintegrated. Total bill for the dealer to fix the motor was $2400. Just valves, gaskets, and labor. The funny thing is the $350 gasket set that you have to buy, and then the ANOTHER $150 in misc. gaskets that aren't included in the $350 gasket set.
Anybody know why Subaru makes 3 of the gears out of plastic?
Who makes after market cam gears for the WRX? Or could we just order 3 more of the metal ones and install those? Anyone know if this would hurt the motor?
Brian
bbaerotek is offline   Reply With Quote
Old 11-01-2002, 12:32 PM   #10
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Recently one of my Friends was complaining that he was only making 5 psi of boost and had no power. After spending a week tyring to find boost leaks and swapping turbos We figured out the problem. He started the car and I noticed the thing would fire over and run the instant he touched the key. Normally on an EJ20 it cranks over one or two revolutions before starting. We decided to check the cam timing and sure enough it was off a few teeth. He took the tensioner off and reset the timming and now he makes full boost again and his power is back.. why it skipped I will never know... I have heard people say that light flywheels can cause this on Subaru motors. He has an MRT flywheel and 5 puck clutch...
CT
AZScoobie is offline   Reply With Quote
Old 11-01-2002, 12:46 PM   #11
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Interference
However, there is some doubt about whether the valves can interfere with the pistons. On the one hand, the service manual says:On the other hand, in another part of the service manual, there is this:
I take this information as yes. Yes it is a int. engine, and yes, the valves can hit the pistons, regardless of the valve reliefs if you A) float the valves or B)Get out of cam timing.
n2xlr8n is offline   Reply With Quote
Old 11-01-2002, 01:54 PM   #12
D_REX
Member#: 8945
MY02 WRX
I have 12 bent valves and no damaged pistons.
D_REX is offline   Reply With Quote
Old 11-01-2002, 04:20 PM   #13
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
My car was hit early in its life and finally after it was finished I got it back and noticed a lumpier idol... took it back to the dealer and they said it was normal... I thought, well its been 4 months since I drove her... so maybe...
Anyway, then I took her to a more local dealer for a CEL (one of those early EVAP codes )
The techs asked me if I had any engine work down, because it wasn't idling right. I said no... just got hit and the timing belt cover had been damaged. (the engine was still running after the accident too... I had to turn her off... $12,500 in damages to the front end!!)
At any rate... I finally got the other dealership to check it out and sure enough, the belt was off "a couple teeth" as they put it.
I had ran at the track with the timing off... hit a 14.002@96mph with just an EBC set to 14.5.
With timing fixed I came back and busted out a string of 13.8s and 13.7s... @ ~97-98MPH.
Thats was over a year ago... now I am running 12s .
def
dug-e-fresh is offline   Reply With Quote
is 95 wrx ej20g an interferance or non-interferance motor GregBolby Pre-2002 Factory Turbo Powertrain 14 03-27-2010 02:40 PM
Is my 2000 2.5l SOHC an interference engine? skottm Normally Aspirated Powertrain 7 03-10-2010 12:29 PM
Interference Motor, Broken Timing Pully = ??? trex616 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-24-2008 09:51 PM
In my experience EJ251 SOHC motors are interference JoshP Normally Aspirated Powertrain 2 11-23-2005 11:48 PM
A long shot... Is a 92 Mazda MPV V6 engine an interference type? biggreen96 Off-Topic 23 05-17-2004 11:27 PM
