#1 |
Member#: 874
RMIC
Vehicle:2003 Honda S2000 2004 Mazdaspeed MX-5 |
DD users -
What values for the 'knock' readings are indicitive of a knock event? Also, is the 'Rear O2 Sensor' voltage reading the one I can plug into the equation: v * 14.7 = A/F ratio ? TIA PS - Yep, I did do a search & mail EcuTek already. ![]()
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The rear 02 sensor is after the cats and is used only to measure catalyst efficiency, it does not indicate A/F ratio.
The front sensor is a wideband unit and does not read in voltage like the rear or a conventional 02 sensor. The parameters for it are current and resistance, and the DD also shows A/F correction and learning data. There is no direct reading for A/F ratio and I don't know if there is a simple way to calculate it based on the readings. |
#3 |
Member#: 874
RMIC
Rats. I was afraid of that. Thanks for the input. |
#4 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
The DeltaDash parameter "Air/Fuel Sensor #1" is reported in terms of "lambda" (λ), which is defined as actual air/fuel ratio divided by the fuel's stoichiometric air/fuel ratio. The limits on the lambda values that the ECU reports are 0.76 (rich) and 1.72 (lean). When the actual lamda is outside that range, the limit value is reported. Assuming premium gasoline's stoichiometric A/F ratio is 14.5:1, 0.76 and 1.72 correspond to sensor A/F limits of approximately 11:1 and 25:1, respectively.
I'd ignore the DeltaDash "Knock Signal 1" parameter and focus, instead, on the "Knock Correction" parameter. Large positive values indicate the absence of detected knock. |
#5 |
Member#: 874
RMIC
Excellent. That is EXACTLY what I was looking for. Thanks.
-paul |
#6 |
Member#: 18384
Vehicle:2004 STi: 580 AWHP Java Black Pearl |
So we can use the Delta Dash to read the WRX wideband O2 sensor instead of having to buy a separate wideband O2 sensor/interface/display for tuning?
That would be great! Russ |
#7 | |
Member#: 16897
Vehicle:2002 WRX WRB |
What would a typical 'large' value's range be in Knock Correction? I am typically seeing values of +4.5 to +6 under boost. TIA, |
#8 |
Member#: 17994
Vehicle:99 Impreza UKTurbo Midnight Blue |
Values of 4 and upwards generally indicate a happy state of tune and keeping a nice saftey cushion for conditions such as heat soak of the TMIC.
#9 |
Member#: 2992
NESIC
I have seen logs where knock correction was as high as +10.5 at 6800 RPM under WOT in 2nd. In retrospect, probably any positive knock correction should be viewed as "good."
#10 |
Member#: 16897
S.D. & Jon:
I was somewhat stuck trying to figure out the KC values. The D.D. software is proving to be a pretty nice tool as I learn to actually decipher the data. Anyhow, thanks! |
| Thread Tools | |
| Display Modes | |
| Delta Dash Question | wyowrx | Engine Management & Tuning | 3 | 04-27-2004 07:43 PM |
| delta dash question | jetsiphon | Rocky Mountains Impreza Club Forum -- RMIC | 6 | 11-06-2003 11:09 AM |
| Delta Dash question | teiva-boy | Factory 2.0L Turbo Powertrain | 9 | 03-24-2003 02:13 PM |
| Help on some Delta Dash Questions | mrtrex | Engine Management & Tuning | 4 | 03-01-2003 10:21 AM |
| Delta Dash Question | StormShadow | Engine Management & Tuning | 0 | 12-22-2002 08:48 PM |
