Vancouver Impreza Club
Old 10-31-2002, 11:54 AM   #1
Parousia
Member#: 24252
05 Legacy GT LTD
Satin White Pearl Wagon
Lightbulb Sylvania Cool Blue Headlamps
Has anyone tried these headlamps before?
Sylvania
I was wondering if they really change the appearance of the headlamp light or not?
Parousia
Parousia is offline   Reply With Quote
Old 10-31-2002, 02:02 PM   #2
Koyo
Member#: 19332
I'm running those on my minivan. It just look whiter but don't really notice it making thing brighter and easier to see.
Koyo is offline   Reply With Quote
Old 10-31-2002, 02:08 PM   #3
jengyigin
Member#: 8209
2002 impreza 2.5 RS
blue ridge pearl
i have them on my RS. they're slightly whiter and brighter than stock headlights. that's about it. if u want good lights, get HID
jengyigin is offline   Reply With Quote
Old 10-31-2002, 02:14 PM   #4
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
There's really good info on blue bulbs here: http://lighting.mbz.org/tech/info/bulbs/blue/
The Sylvania fall into the "good" blue category but even then:
In fact, you could be getting less light from such a bulb than from a regular clear bulb, and here's why: A blue filter removes nonblue components of the light passing through it. Halogen bulbs produce very little light in the blue frequency range. When you put a blue filter on the bulb or lamp, you are reducing the amount of usable light that gets from the glowing filament to the reflector, to the lens and from there to the road.
AllWheelDrift is offline   Reply With Quote
Old 10-31-2002, 09:46 PM   #5
Parousia
Member#: 24252
05 Legacy GT LTD
Does the light actually look any more blue?
Parousia
Old 10-31-2002, 09:58 PM   #6
Koyo
Member#: 19332
Nope, it actaully looks white.
Old 11-01-2002, 12:53 AM   #7
fukamoto
Member#: 13339
2014 SWP WRX Wagon
IMHO, Subaru already has a bright stock bulb with the headlamps and fogs. If you change to Sylvania or Phillips, I don't see much of a change rather than a whiter hue. Only way you'll get noticeable change is if you get illegal lights (Eurolite). I had them on my Legacy for 4 months before it burnt out. Usually they burn out after 3-6 months. Best bet is to stay stock or go for the Sylvania's. Or just get HID
Derek
fukamoto is offline   Reply With Quote
Old 11-01-2002, 02:14 AM   #8
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Functionally speaking.. stick with the stocks.
Cosmetically.. go with those.
The moment I went for a drive after I put in whiter bulbs, the visibility went down. Sometimes I drive with my tiny MY01 fogs as a supplement. Whiter light just don't bounce back off of objects as good as the stock yellowy light.
I believe they are "brighter" is only because the color white is more lively than yellow to begin with.
Mirage is offline   Reply With Quote
Old 11-01-2002, 02:21 AM   #9
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Derek
I believe the stock bulbs in Subarus are made by Osram.
Go check your own bulbs to make sure! In the three years of owning my car, only one bulb has burnt out - the map light!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-01-2002, 08:20 AM   #10
bender
Member#: 1839
LaterZ!
Darren!!
you got stop grading papers while driving
back to topic, I'm running the cool blues and they do look white and not blue. no problems from cops yet in the 2 1/2 years I've had them.
I want to try the sylvania silverstars. does anyone know where I can get them locally?
bender is offline   Reply With Quote
Old 11-01-2002, 01:20 PM   #11
fukamoto
Member#: 13339
2014 SWP WRX Wagon
I was at Lordco and Canadian Tire this week to look for McGard's and I beleive Canadian tire has Sylvania but I'm not too sure about silverstars. Check Lordco. But I'm 100% Canadian Tire has Sylvania, just nto sure which kind.
Derek
Old 11-01-2002, 01:28 PM   #12
COwannago
Member#: 6972
I currently have the Silverstars in my car and they are definitely brighter than the stock bulbs as well as whiter.
Nick C.
COwannago is offline   Reply With Quote
Old 11-01-2002, 03:06 PM   #13
spy gurl
Member#: 15356
2002 wrx
black
i tried those bulbs, they're supercheap from Can.Tire
its quite a bit whiter&brigher than the stock 325i bulbs...
haven't tried it on my car yet...
spy gurl is offline   Reply With Quote
Old 11-01-2002, 04:47 PM   #14
rtam
Member#: 13267
2002 Impreza 2.5RS
I emailed Daniel Stern of Stern Lighting a while back and this is what he said:
The headlamps on the North American WRX are typical of late Subaru
headlamps: Not real good. They could be a great deal worse, but the
pattern isn't very good. The *one and only* bulb that would be worth
installing in a 9007 bulbed headlamp is the Sylvania Xtravision 9007,
which has approximately 20 percent higher luminance. This improves
in-beam performance by a roughly comparable amount at the hot spot,
but does not change the overall shape of the beam pattern, which is
the prime determinant of headlamp "goodness" (performance). There are
LOTS of so-called "performance" bulbs that should be left on the shelf
(PIAA etc.).
You can order Xtravision bulbs from Autozone.
rtam is offline   Reply With Quote
Old 11-01-2002, 11:18 PM   #15
Snake Eyes
Member#: 13384
2002 Impreza WRX
Talking
I tried the Cool Blues on my WRX and i found that they didn't make a huge diff. don't waste your cash eventhough they are cheap... IMHO the Cool Blues only made a very little significance, and i mean little in terms of brightness and colour compared to the stock bulbs. I eventually bought another set of aftermarket bulbs and replaced the Cool Blues. Anyhow hope this helps
Snake Eyes is offline   Reply With Quote
Old 11-02-2002, 02:19 AM   #16
AcIdRoX
Member#: 1021
1999 2.5 RS
Blue :)
Just a note,
Osram = Sylvania
AcIdRoX is offline   Reply With Quote
Old 11-02-2002, 02:21 AM   #17
AcIdRoX
Member#: 1021
1999 2.5 RS
Blue :)
Nick C.
You use 9003/H4 right? Ive been looking for the H4 silverstars but every store I asked didnt carry the H4 type. Where did you get yours?
Thanks in advance
Old 11-02-2002, 02:33 AM   #18
ashtaron14
Member#: 4674
2004 Toyota Vitz
Black Black Black!
I use Piaa Platnium White for my Driving lights and some Korean H3 bulbs for the fogs... I love them... just that I don't think they are exactly properly aligned
Sunny
ashtaron14 is offline   Reply With Quote
Old 11-02-2002, 05:44 AM   #19
ScoopY
Member#: 25405
If ur gonna get the Cool Blues, might as well buy the Eurolites....their about the same price........only diffrents is colour..one is white and the other is blue...
ScoopY is offline   Reply With Quote
Old 11-02-2002, 11:25 AM   #20
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Eurolites are illegal for street use. Sylvania's are legal. Plus the Eurolites are notorious for burning out within a few months of use and it blinds oncoming traffic.
Derek
Old 11-02-2002, 01:10 PM   #21
COwannago
Member#: 6972
Thanks in advance
I'm in the States and I looked for quite some time. All the stores had lights for other makes rather than for the Subie but I found them at a place called Pep Boys. I don't know if you have that store there but on Sylvania's website they list the stores that carry them.
Nick C.
Old 11-02-2002, 02:28 PM   #22
AcIdRoX
Member#: 1021
1999 2.5 RS
Blue :)
No way! you can totally tell the difference. If you use eurolites, you wont be able to see anything on the ground, the filament isnt even aligned properly, it hardly focuses any usefull light to the ground. I found cool blues to be much "brighter" as it more light is focused down in front of you where it should be. Nothing beats a non-tinted bulb though, visability wise.
BTW, I have a pair of H4 eurolites for sale, used for 2 days
Nick C.
Thanks for the info, maybe ill pick a pair up next time I go down
Does anybody want some Sylvania Cool Blues? mav1c Mid Atlantic Impreza Club -- MAIC 6 12-16-2002 02:45 PM
('93-'01) Sylvania Cool Blue... nmack Impreza Forum 18 10-06-2001 07:38 PM
Anyone have any experience with Sylvania Cool Blue bulbs? Robmat General Forum Archive 21 03-23-2001 07:36 PM
Narva rangepower vs. Sylvania cool blue? speedracer47 Interior & Exterior Modification 6 11-08-2000 10:41 PM
Installed Sylvania Cool Blues.....first impressions... JasonRan Technical Forum Archive 8 07-17-2000 07:58 AM
