Old 10-31-2002, 04:50 PM   #1
WiredWRX
Member#: 20768
2009 IS-F
Default UTEC MAP FOR UP PIPE and CAI
Hello,
Here is the thing. UTEC on the way, should be here today or tomorow. Coming with Stage 1 on it. Should be relatively O.K., EXCEPT, I have an up pipe, and a CAI. I don't really want to remove the CAI (Pain in teh arse, and I am going to the track on the weekend, and don't think I will hae time before then to remove the CAI, but definitely want to use the UTEC at the track)I was hoping that someone out there, with a working map on his/her UTEC, with the same mods, could chime in with the changes they made, or a copy of the map. ANY help is appreciated.
Thanx
Michael
[email protected]
P.S. At this time, I have no other mods, including exhaust mods.
WiredWRX is offline   Reply With Quote
Old 10-31-2002, 05:59 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
This sounds like a recipe for disaster. Aftermarket intakes change the air flow through the MAF sensor in unpredictable ways. Some, like the APS, cause a "Fuel Trim Too Lean" trouble code, whereas others, notably the Injen, cause a "Fuel Trim Too Rich" trouble code.
Jon [in CT] is offline   Reply With Quote
Old 10-31-2002, 09:24 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Yeah, with an aftermarket intake and using the MAF to tune (as the UTEC does) I wouldn't trust someone else's map. I would definitely want to come up with my own. Aftermarket intakes can cause a certain amount of unpredictability for the MAF readings.
Concillian is offline   Reply With Quote
Old 11-01-2002, 12:59 AM   #4
Z1 Performance
Member#: 9327
Copying others maps, even on a stock car should be avoided like the PLAGUE.
If you are unsure about the tuning of it, have TXS refer you to a dealer comfortable with the tuning side of things.
As for the intakes, some affec tht cars ecu, some do not. While we don't sell the part, we ahve tons of customers with the Injen, and not one E light, even when coupled with substantial other mods. The APS one though has caused problems for a few customers. Units lik eht AEM, while not really a great banfg for the buck mod, have a pipe diamter and sensor location identical to stock.
Adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 11-01-2002, 01:14 AM   #5
gpatmac
Member#: 18446
2002 WRX wagon
psm
I had a stage II setup with a CAI until last Sunday when I put on an uppipe. This is a sample of my log prior to the uppipe (and prior to turning my abc up two turns from where I originally had it; all the way clockwise):
gpatmac is offline   Reply With Quote
Old 11-01-2002, 01:27 AM   #6
gpatmac
Member#: 18446
2002 WRX wagon
psm
And here's a log after I installed the uppipe.
Now I'm still learning my way around the UTEC, but it would seem that my CAI and uppipe are not producing any extreme numbers.
Old 11-01-2002, 12:12 PM   #7
2000vfr800
Member#: 15599
How come you aren't running much boost (your MAP readings are around 10-11.5 psi)? What is your in-car boost gauge reading?
Oh wait...never mind. I see that you didn't have you foot in it on the second run... And, if you were at WOT on the first run, you need to adjust your TPS setting in the UTEC. You are only reading 97%...
2000vfr800 is offline   Reply With Quote
FS: TurboXS Up Pipe and AEM CAI Rehabguy Tri-State Area Private Classifieds 3 08-13-2009 11:09 AM
FS: UR 44mm EWG Up Pipe, APS CAI, Cobb Down Pipe, VF39 Shop7STi RMIC Private Classifieds 10 06-23-2009 01:00 PM
Where can I get new hardware for up pipe, and downpipe??? Scott4DMny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-10-2005 04:24 PM
utec map for 800cc injectors and race gas. oldbluwrx Engine Management & Tuning 9 06-21-2004 04:44 AM
Does anyone have the UTEC stage 2 + up pipe and IC hose map? lawn boy Engine Management & Tuning 3 06-01-2004 01:30 AM
