Old 11-03-2002, 12:11 AM   #1
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
Have a Nice Day? What's going on with Perrin's downpipe
It was supposed to be out a month ago. I am still waiting for a 3" downpipe with a high flow cat in it. Has anything come out yet?
I have a HKS Ti catback so I cannot use the TXS stealth back.
I know MRT makes one but there is the talk that it will not mate up to my catback either. I know Shiv is supposed to have one, but it is still not out (from what I know) and I have heard it will be VERY expensive.
Any advice and help would be appreciated.
BTW, no, I will not go catless and I do not want any custom piping.
dman918 is offline   Reply With Quote
Old 11-03-2002, 02:17 AM   #2
Austin
Member#: 7089
2016 STi
Try Alta Sports - www.altasports.net .
The Perrin downpipe is completed. I saw it an event called Taste of Subaru at PIR a couple weeks ago...
Austin is offline   Reply With Quote
Old 11-03-2002, 03:42 AM   #3
teiva-boy
Member#: 22825
teiva-boy is offline   Reply With Quote
Old 11-25-2002, 10:06 PM   #4
mlambert
Member#: 13831
and the cat version
THE PERRIN DOWN PIPE WILL ATTACH TO ALL CAT BACK EXHAUST SYSTEMS INCLUDING THE FACTORY EXHAUST SYSTEM.
mlambert is offline   Reply With Quote
Old 11-26-2002, 12:22 AM   #5
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
It looks like a very nice piece but I don't see any place for the O2 sensor. Does it have one? Or is this just a prototype pic?
Don Arm is offline   Reply With Quote
Old 11-26-2002, 12:25 AM   #6
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
There is a place for the the O2 sensor. Its just closer to the end of the downpipe so you can't see it in these pictures. You can see it in the pictures on Perrin's website. I got the catless version of this installed at Alta in Portland last Friday. Its currently hooked up the stock catback so its very quiet but still provides a very noticeable power increase. And it looks darn nice
driggity is offline   Reply With Quote
Old 11-26-2002, 03:08 AM   #7
koloumb
Member#: 28268
2002 WRX Sedan
any CEL's?
_Owen_
koloumb is offline   Reply With Quote
Old 11-26-2002, 12:24 PM   #8
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Same question any CEL's ?
Also, how does the wastegate outlet look when mated to the turbo? The inlet into the downpipe looks a little small from the picture, do you think there is a smooth enough transition for the exhaust gases?
Don
Old 11-26-2002, 01:41 PM   #9
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
The stock DP does not have an O2 sensor on it.
Nice peice that Perrin is! Whats it made of 321?
PaulRex is offline   Reply With Quote
Old 11-26-2002, 02:15 PM   #10
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Yeah, I threw a CEL about 400 miles after I got the downpipe on. I haven't pulled the code yet but I assume its for cat inefficiency since I don't have any cats . Car is running just fine so I'm not too concerned about it. I'm not sure how big the wastegate tube is but its probably about an inch in diameter. It does look kind of small next to the main pipe but that one is 3 inch diameter the whole way.
Old 11-26-2002, 08:10 PM   #11
1quikrex
Member#: 15329
2015 WRX WRB Ltd
2002 WRX PSM (sold)
Yes it's 321, but $600- for a dp w/ cat? That's insanely overpriced.
1quikrex is offline   Reply With Quote
Old 11-26-2002, 09:06 PM   #12
koloumb
Member#: 28268
2002 WRX Sedan
Yeah - even the non-cat version is instanely priced. But Perrin components are well designed and built to last.
_Owen_
Old 11-26-2002, 11:15 PM   #13
project_cdubb
Member#: 4142
I got to hold this bad boy in my hand tonight at the weekly BAIC meets and it is very very light. Construction of the downpipe is very impressive. Can't wait to get one in my car .
Clive
project_cdubb is offline   Reply With Quote
Old 11-27-2002, 01:34 AM   #14
mlambert
Member#: 13831
uhh...vishnu is selling a turboback for $1650
scoobysport runs about $1200
turboxs is about $1100
add in a catback and its all priced the same...you could get one of those crazy titanium catbacks that cost $1000 and it would still cost less than the vishnu sig.
i dont see insanely overpriced
Old 11-27-2002, 01:40 AM   #15
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
I believe this is the only dp made in 321. Looks very good.
Jay.
illmatic is online now   Reply With Quote
Old 11-28-2002, 03:26 PM   #16
chazbott
Member#: 15933
2002 WRX Wagonian
Platinum Silver Metallic
Default Perrid DP mate with Vishnu non-sig series
Wow. That's just what I wanted, a divorced wastegate design that still goes through the cat.
Q: anybody know or can anyone speculate whether the Perrin DP will mate up with the Vishnu non-signature exhaust?
That setup would probably make it very smoggable: under inspection, all flow paths flow through two cats, and the cat in the DP would handle cold startup better.
chazbott is offline   Reply With Quote
Old 11-29-2002, 07:18 PM   #17
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Hard to tell from the pictures if the Vishnu system will swap in with any parts of the stock system. The Perrin system does mate up just fine with the stock cat-back. Thats the setup I have. Oh, and on another note my CEL was gone when I started up the car today and I never got it pulled so I don't know what it was for or why it fixed itself.
Old 11-29-2002, 09:02 PM   #18
Austin
Member#: 7089
2016 STi
As long as you haven't reset the ecu it'll still be there. You're coming for wings tomorrow, right? I'll pull your code there.
Old 11-30-2002, 02:56 AM   #19
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
Default Re: Perrid DP mate with Vishnu non-sig series
From the looks of the Perrin DP with cat, it would be replacing the OEM DP cat and the OEM mid cat. If we are talking about a visual inspection, a well-informed tech looking for 3 kitties would only find 2 (at most).
Schlad is offline   Reply With Quote
Old 11-30-2002, 03:12 AM   #20
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
it sounds like an ineffecient cat code, its basically a BS code and it turns it self off after 2 or 3 driving cycles
its usually caused by driving before the cat is warmed up
hpracingwrx is offline   Reply With Quote
Old 11-30-2002, 10:47 AM   #21
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
The total leingth & bung for the second O2 sensor would indicate that it totally eliminates the 3rd cat...
I was hoping for something similar to the Bosal pipe so I can swap the 3rd cat in & out if I wanted...
At over $550 w/cat I'ld have to think hard about it...
A Bosal costs $270, and a 3rd cat eliminator $160ish total $430 with enough flexibility to configure however I want...
I haven't seen a Bosal pipe first hand, but have heard the fit is good & construction solid.
?What is the pipe diameter of the Perrin pipe? The ony thing I can find is "larger than the stock DP."
GLwagon is offline   Reply With Quote
Old 11-30-2002, 12:58 PM   #22
mlambert
Member#: 13831
its full 3inch and full 321 stainless, only one on the market.
Old 11-30-2002, 01:16 PM   #23
dman918
Member#: 11202
2009 Infiniti G37X
I'm going to wait until it is a little less than $600. The vendors will sell it at less after the initial boom. I know Nino had 10% off the first batch, and I would have considered that, but I need money from XMas, my birthday and graduation for the toys I will be buying.
Old 11-30-2002, 02:11 PM   #24
Rattler
Member#: 6351
2004 Tacoma 2xCab
\m/ \m/
I have a Perrin uppipe. Excellent product. I am running a cat'd Stromung now. I would love to have the Perrin downpipe but $600 is hefty. It would be nice rid myself of the sound of the wastegate smacking the flange though.
Rattler is offline   Reply With Quote
Old 12-01-2002, 03:51 AM   #25
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Wastegate smaking against the flange? I have catless Stromung DP and have no such issues. Are you sure it's hitting the flange, because IIRC it's nearly impossible for that to happen because I think it is too far away from it, and IIRC the flap is recessed in the turbo.
The Perrin peice looks nice though, I like it's design, but if I could buy a DP again I would prob. buy the Bosal DP now, better price, divorced wastegate, except the gases are seperated until nearly the end of the pipe unlike the Perrin where the gases are mixed immediatly following the first bend. I doubt that will affect per. though.
Paul
What's going on with the words on these forums? DtownIan Off-Topic 33 04-01-2004 11:34 PM
What's going on with Etown?? WRXcellent Tri-State Area Forum 1 07-20-2001 08:44 AM
Imprezer - What's going on with the seat rail mod? cakagan Interior & Exterior Modification 6 11-13-2000 11:18 AM
