Old 11-03-2002, 03:12 AM   #1
spoolinmp3
Member#: 27047
Default Turbo selection...25g??
This is my buddies setup currently
FMIC
HKS BOOST controller
Unichip
Uppipe
Down Pipe
3inch exhst catless
and some other things cosmetic mods ect.
Ok here is the question, what are your opinions on the mitsu 25 G turbo for the WRX?
He wants all out power but does not want a 5500 rpm lag. Is this possible? Does anybody know how long it takes to spool up one of these bad boys?
Also for this amount of power would you reccomend an emanage? Or a full standalone like a haltech, tec2 ect.
He will still need to get bigger injectors, engine managment, refab the DP and upipe and get the turbo.
I told him that he is sick. Yes the turbo will make gobs of power but what will be the driveability on this thing? I just dont want him to make a mistake. I was thinking something more along the lines of a t3/t4 or an 18g perhaps 20g??
Thanks for your help
Terry
spoolinmp3 is offline   Reply With Quote
Old 11-03-2002, 11:56 AM   #2
N/A01RS
Member#: 22478
2002 WRX Sedan
Platinum Silver
Greddy makes a bolt on T67-25G turbo kit, but from what I understand even with a stroker kit it is still going to be a very laggy turbo. A.K.A. race only. Dont forget to slide a full dog box tranny into the budget for a setup like that.
N/A01RS is offline   Reply With Quote
Old 11-03-2002, 12:01 PM   #3
2002whitewrx
Member#: 21414
02 wrx
white
a 25g holy $&*( if he could spool that he would be the man, I would suggest getting a crank with a little less stroke to take it to a higher redline bore the crap out of everything especially the exhaust ports bigger valves you would have to do all sorts of stuff to spool that big of a turbo unless you wanted to kill cars on the highway you would definately do that.
2002whitewrx is offline   Reply With Quote
Old 11-03-2002, 12:03 PM   #4
2002whitewrx
Member#: 21414
02 wrx
white
you could spool it real good with a 100 shot of nitrous
Old 11-03-2002, 05:17 PM   #5
spoolinmp3
Member#: 27047
Ok has anybody used bigger mitsu units like the 18g or 20g?
And what specs were you running on them turbine ect?
Also what are your opinions on the emanage for this setup?
Thanks
Terry
Old 11-03-2002, 08:20 PM   #6
slin02
Member#: 11588
Greddy also make TD06-20G
slin02 is offline   Reply With Quote
Old 11-03-2002, 08:41 PM   #7
nqwan
Member#: 2916
02 duburu arr exu
Thanks
Terry
imprezer is using the greddy t67 kit
nqwan is offline   Reply With Quote
Old 11-04-2002, 01:32 AM   #8
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Boogerwrx has (had?) a TD05-18g on his '02 WRX last I heard. I know I read a post about the install and greatly improved performance over his old VF23, but all I can find is this post where he refers to the 18g:
http://forums.nasioc.com/forums/show...hlight=TD0518g
I'm running the small 16g, which is a bad ass street turbo, but a far cry from an 18g or 20g, let alone a 25g
In '03, I'll be swapping in bigger injectors and a big 16g or 18g.
annointed is offline   Reply With Quote
Old 11-04-2002, 04:19 AM   #9
spoolinmp3
Member#: 27047
Thanks for the input guys,
Yeah I am running a small 16g with clipped wheels on my MP3 and its a sweet turbo. Mitsus are great reliable turbos.
Just trying not to get my friend to go overboard. He just spent the weekend at a supra dyno day and now he is having visions of granduer. He wants the biggest damn turbo he can find.
I think a 20g is a better approach.........and hell thats still big
Old 11-04-2002, 09:31 AM   #10
Quantum-Racing.com
Vendor
Member#: 20483
There are several vendors (including me) coming out with T3T4 kits so you can customize your turbo. You can get anywhere from slightly smaller than a 20G up to bigger than a 25G. I have one on my own car that is in between the two (closer to the 20G) and it spools by 4k. Get some headwork done to gain 1000 rpms or so and you have a 4,000 rpm powerband.
Mark
www.Quantum-Racing.com
Quantum-Racing.com is offline   Reply With Quote
Old 11-04-2002, 09:41 AM   #11
2002whitewrx
Member#: 21414
02 wrx
white
you could spool a 20g on a stock wrx in 5th gear with a shot of nitrous
Old 11-04-2002, 12:50 PM   #12
Quantum-Racing.com
Vendor
Member#: 20483
20G's are not as hard to spool as you think.
As I said, mine is larger than a 20G and it spools by 4000 without issues and I have yet to tune it much.
Old 11-04-2002, 08:40 PM   #13
spoolinmp3
Member#: 27047
Thanks for the input gentleman
I need a RFBig Turbo aka 25G! Hyper Normally Aspirated with bolt-on Forced Induction Powertrain 13 02-17-2005 12:21 AM
Pump gas only turbo selection help please jlp7t Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 08-24-2004 07:53 AM
Help with turbo selection SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-20-2003 06:28 PM
Turbo selection for a built motor? JohnGalt00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-11-2003 01:29 AM
Does NOS affect CFM/PPM of turbo selection? Greg Sharpe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-25-2001 09:27 AM
