Old 11-03-2002, 10:05 AM   #1
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
Default Running Rich...
Ok,
I'm using a 100% atmoshpere BOV, and it's causing my car to run rich(duh). Is there ANY way to adjust it so it's not running rich without just getting another stock BOV???? I LOVE the sound, and want to keep it, but it's not worth running rich all the time. I have a TXS unichip too, and I'm not sure if that can be adjusted for fuel mixture... Would a Apexi-SAFC work???
WRXGuyInUSA is offline   Reply With Quote
Old 11-03-2002, 04:36 PM   #2
URABUSx714
Member#: 26002
2003 DuB ReX
blk
wats wrong wit running rich?
URABUSx714 is offline   Reply With Quote
Old 11-03-2002, 05:37 PM   #3
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
carbon build-up, more frequent backfires, black tailpipe, less performance...
Old 11-03-2002, 05:57 PM   #4
gpatmac
Member#: 18446
2002 WRX wagon
psm
I think that the first generation of non-code guys are starting to get comfortable with our UTECs. I have a feeling that our questions are going to be very similar.
I think that what we will need to do is drop the numbers on our Fuel map at certain load points.
I am getting overduty on my injectors at high rpms, but running rich pretty much throughout my 1/4 run.
3875 -10.4 2.1 8 00 00 14.1 +40.5 9.0 ECU. +0.0 ECU. 2.2
4182 -9.8 2.5 14 00 00 14.6 +40.3 89.0 ECU. +0.0 ECU. 2.6
4668 -6.1 3.1 98 10 00 16.4 +31.3 32.0 ECU. +0.0 75.00 3.2
4089 -0.6 3.3 97 10 00 rich +24.8 38.0 ECU. +0.0 75.00 3.3
2810 +4.9 3.2 98 30 00 rich +13.5 31.0 ECU. +0.0 88.00 3.1
2427 +8.2 2.9 98 50 00 rich +15.7 25.0 +20.0 +0.0 92.00 2.8
2149 +8.6 2.6 98 50 00 rich +19.5 17.0 +25.0 +0.0 95.00 2.6
2754 +7.6 2.9 98 40 00 13.7 +23.2 23.0 +20.0 +0.0 88.00 2.9
3066 +7.2 3.0 98 40 00 13.0 +20.3 28.0 +18.0 +1.5 80.00 3.2
3367 +8.2 3.2 97 50 00 rich +16.9 37.0 +18.0 +1.5 80.00 3.3
3894 +10.2 3.5 98 60 00 rich +14.3 54.0 +18.0 +1.5 75.00 3.6
4317 +12.3 3.7 97 70 00 rich +14.1 69.0 +21.0 +0.5 75.00 3.7
4873 +13.7 3.8 97 70 00 rich +18.2 79.0 +23.0 +0.5 75.00 3.9
5232 +13.7 3.9 97 70 00 rich +20.3 88.0 +24.0 +0.2 80.00 4.0
5767 +14.1 4.0 96 80 00 rich +22.1 95.0 +24.0 +0.5 80.00 4.1
6127 +12.7 4.1 96 70 00 rich +22.6 99.0 +25.0 +0.8 80.00 4.1
So far, I've just taken a .1 out across the board from 5000-7250 rpms.
Pat
gpatmac is offline   Reply With Quote
Old 11-04-2002, 02:37 AM   #5
URABUSx714
Member#: 26002
2003 DuB ReX
blk
then should i take out my blitz dd bov ?
Old 11-04-2002, 04:26 AM   #6
Onederer
I am NOT nice
Member#: 7952
2014 Ford Fiesta ST
no, keep it it you like the sound.
You only go rich when you shift, of the when you can hear the BOV doing it's noise thing. Don't sweat it.
Onederer is offline   Reply With Quote
Old 11-04-2002, 04:32 AM   #7
gpatmac
Member#: 18446
2002 WRX wagon
psm
Huh? Dude, put the needle down.
Anyhow, what makes you say it's your BOV? From what I've picked up on from here and talking to my pardners, the car runs rich by default, and a BOV doesn't really add or subtract from performance. (Make sure and look left at that big 'Newbie' under my screenname, though).
It would seem to me that there are 2 options for you: look into a higher octane gas, or get your unichip remapped.
Just my opinion.
Old 11-04-2002, 08:39 AM   #8
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
I run Sunoco 94 all the time, and I'm in the process of sending my chip out to get re-mapped...
Running rich- very rich Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 19 04-12-2003 08:11 PM
MBC WRXes running rich? jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-03-2001 02:55 AM
Question on running rich Rubik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-25-2001 04:45 AM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 10:53 PM
MY00 Running Rich (C.E. Light) w/ Cobb Intake, Stromung Exhaust Swivel1000 Normally Aspirated Powertrain 8 03-11-2001 03:21 PM
