Old 11-03-2002, 01:39 PM   #1
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Default Link fine yesterday, but not today
Need help, car won't start.
Yesterday I went to pick up a laptop so I can start tuning the Link. I drive home for the evening and park the car out front. I come out this morning, plug in the Link, don't touch a thing, and try to start the car. Nope. The engine is completely missing now. It feels like it's going to come out of the car. I tried reloading the pcl file from the ecu and the car will barely start and still feels like it's missing. I tried the good map again and the car still won't start.
What could have happened? The weather conditions are the same and I felt nothing wrong with the car last night. I see no leaks of any kind. I have fuel pressure at around 32psi. All the hoses are connected. I don't get it.
Should I plug the factory ECU in and see if it will start? Would the 440 injectors mess anything up too bad?
wcbjr is offline   Reply With Quote
Old 11-03-2002, 02:04 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
That is very weird. Don't suppose any wirring came loose?
You've probably already done this, but just to make sure. Check the vacumm line to the link plus at the engine and at the ecu. Check the plugs at the ecu and check your wirring. Check the injector wirring. Make sure that the injectors are properly hooked to the fuel rail and they are seated in the intake manifold properly. Check for vaccum leaks. Check spark plugs.
If that looks good then you can try and plug the stock ecu in, but i don't know how it is going to do with the 440s on there.
-Chav
Chav is offline   Reply With Quote
Old 11-03-2002, 02:19 PM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I hate the Link software. That sums it up. I can't get the PCLink software to save any of my changes. I'm not even trying to save the changes to the ecu itself, I just want to save the changes in the pcl file. It can't even do that. Every time I change something, like crank enrich, save it to the pcl file on the hard drive and reopen it, the change is gone. This is without even hooking the computer to the ecu. What is going on here?
Old 11-03-2002, 02:21 PM   #4
Chav
Member#: 3269
RSTi
Have you tried the latest software and an older version?
-Chav
Old 11-03-2002, 02:22 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I am trying to look at the files on the filesystem in Windows and one pcl file is 11k and the other is 22k. What are the file sizes supposed to be?
Old 11-03-2002, 02:22 PM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I just dl'ed the software from AMR's site yesterday. That is what I am using right now. But I didn't even use it when I tried to start the car this morning.
Old 11-03-2002, 02:37 PM   #7
Chav
Member#: 3269
RSTi
My pcl file is 12kb. Do you want an older version of the software to try?
-Chav
Old 11-03-2002, 03:00 PM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Yeah, where can I get some older versions?
Back to the other problem. The weather has been the same, rainy. I popped the hood one more time to start taking out the plugs and I noticed a lot of water around the engine. I then proceeded to pickup a rainsoaked filter that is located under the passenger side hood vent. I am pretty sure the car was not starting because it was also pulling in a buttload of water. How do I need to go about fixing this? Besides putting the plate back on the vent...
Old 11-03-2002, 03:10 PM   #9
Chav
Member#: 3269
RSTi
As long as the filter wasnt submerged or anything you should just be able to dry the filter out a bit and everything will be fine.
I thought I had some older versions on my computer, but I cant find them. Sorry.
Will the car idle with the default map? If it does you can track the missing cyl. by pulling injector plugs. When the idle changes you have a good cyl. if you pull the injector plug and the car's idle doesnt change then you've found your bad cyl.
Before you do any of that try to get the car to idle and see if it will rev freely. This is a very unusal problem and I'm sure there is some simple reason why this is happening. It isn't like you changed anything on the car (it was working fine before). Worst comes to worst you can get a new Link plus under warranty.
Just be careful. Make sure there isn't any fuel leaking and the engine is still in good shape. I don't want you to try and crank the thing if there is a hole in the fuel line or some thing is wrong with the engine.
-Chav
Old 11-03-2002, 03:54 PM   #10
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Check your MAP limit. Mine did the same thing when I first got it. For some reason it set my map limit to 5Kpa! The car wouldn't start at all.
ScoobieSnaX is offline   Reply With Quote
Old 11-03-2002, 04:07 PM   #11
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I pulled the plugs and they are completely black. I am cleaning them right now, I'll keep you updated. As to why everything went wrong just this morning, I have no idea.
Old 11-03-2002, 05:10 PM   #12
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default did you get it running?
Just to make sure, Your car ran then you hooked up your laptop and it didn't?
Double check all your configuration settings, take a close look at coil single& duel.
When you hooked up the laptop did you down load to or from the link?
milkman is offline   Reply With Quote
Old 11-03-2002, 06:26 PM   #13
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I downloaded from the Link.
But, I just plugged in the stock ecu and it started first time. Granted it threw out a lot of fuel, but it ran ok.
Where can I get the past versions of the Link software?
Old 11-04-2002, 02:17 AM   #14
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
You in a cold enough area to freeze? ITs possible for the vacuum line to the link to get a little water frozen in it and block the line. (can happen with any ecu that uses an internal map sensor)
I havent upgraded my desktop software yet, so I can get you that if you end up needing it.
Midwayman is offline   Reply With Quote
Old 11-04-2002, 09:15 AM   #15
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
pm'ed you Midwayman
Old 11-04-2002, 04:06 PM   #16
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Sorry to hear about this Charlie. Have you started the car since the problem, or are you still back to the stock ECU?
I didn't think the stock ECU would drive those injectors you have, interesting.
Graham
Graham is offline   Reply With Quote
Old 11-04-2002, 04:09 PM   #17
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
The stock ecu will drive the injectors, but spit out about 40% more fuel. I can't rev up past 4000 or the ecu will freak out (boost). It's ok enough to drive to the exhaust shop a couple miles away without fouling anything up.
Old 11-04-2002, 06:10 PM   #18
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
Your posts are raising more questions than they are answering.
I don't think a vacuum line or plugs would cause the car not to start, but rather to just run poorly. I don't know much about your car, does it use direct ignition or a cap/rotor? Could your spark system have gotten wet?
I would reset the Link to it's stock map. Why are you going to the exhaust shop?
The difference in .pcl file sizes are usually due only to notes that you have made in the file.
-Jonathan
mynew02 is offline   Reply With Quote
Old 11-04-2002, 07:33 PM   #19
Chav
Member#: 3269
RSTi
Vaccum line would cause a problem since the Link Plus has a built in map sensor that needs a vaccum source to decide how much fuel to dump into the engine.
Ignition system is out cause the stock ecu works fine.
wcbjr, I think it maybe time to call the person you bought the link from and find out if you can warranty it. Or better yet find someone that you know that has a link and will swap with you.
-Chav
Old 11-04-2002, 10:39 PM   #20
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Ok, this is a bit odd. I tried various things to get a map in the Link that would work. I dl'ed from, dl'ed to, reset the thing, the works. No go.
Then I sat there and looked over all the settings again for the map I knew was good. I got the map from Imprezha and it was the one I tuned with on the dyno. Lo and behold I spot that the Link is setup to run a dual coil ignition. I change it to single coil and the car starts right up.
I then go out and proceed to get some datalogging done. Next, I come back home, turn off the laptop, and then turn off the car. I sit for a few seconds and try to start the car again. No go, same problem as before.
What the heck is going on here?!
edit: i just looked at the Link again and it still says single coil but it's not starting.
Old 11-05-2002, 12:21 AM   #21
mynew02
Member#: 13726
2002 WRX - 264 AWHP
Ok.. you not only need to make the change to the map but then STORE the change. Make sure when you download your map you store it or it will go back to the previous state it was in before loading it up.
-Jonathan
Old 11-05-2002, 12:36 AM   #22
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Well the my01 impreza you have is a dual coil setup. IE wasted spark.
Old 11-05-2002, 02:05 AM   #23
Chav
Member#: 3269
RSTi
Yup, you want dual coil.
-Chav
Old 11-05-2002, 02:13 PM   #24
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Chav and Midwayman, are both your cars starting on dual coil?
Charlie, did you store the map?
Graham
Old 11-05-2002, 02:49 PM   #25
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Graham, I did everything but throw it in the kitchen sink. And why would it work with single coil if it's supposed to be dual?
Is it possible for a perfectly fine clutch to not grab during startup? WorstNameEver Transmission (AT/MT) & Driveline 7 09-29-2008 01:29 PM
Running Link car cranks but will not start subaru mike Engine Management & Tuning 31 02-15-2005 09:57 PM
Done yesterday, but what the hell... Happy B-day to me moogoob Tri-State Area Forum 6 04-08-2003 07:21 PM
Your Semi-Sexual but not obscene Horoscopes for today... sherifx Mid West Subaru Owners Club Forum -- MWSOC 0 10-08-2002 08:46 PM
The rear deck speakers worked fine mounted one way, but not another..?!?!?! help! ChosenWon Car Audio, Video & Security 7 10-26-2001 12:50 PM
