Old 11-04-2002, 12:26 AM   #1
jibber
Member#: 6675
98 SF5 some mods
01 allroad
Default injectors
does anyone have any info on why the injector sizes 550and up
seem so common. i was speeking with a friend of mine about this topic and he was telling me about the escort cosworths using i think he said 330cc injectors? anyone know why? both 2.0l engines both turbo why would there be such a big difference? the turbo on the cosworth is HUGE!!!
thanks
josh
jibber is offline   Reply With Quote
Old 11-04-2002, 04:29 AM   #2
teiva-boy
Member#: 22825
Turbo size is one thing, but it depends on the amount of boost it's running. No sense to have huge injectors if it's only seeing some 7psi stock.
teiva-boy is offline   Reply With Quote
Old 11-04-2002, 06:52 PM   #3
jibber
Member#: 6675
98 SF5 some mods
01 allroad
Default injector size?
the injector size is 311cc on the stock escort cosworths this is good for 270hp at 15 to 16 psi of boost. about the biggest injectors ford motorsport uses is 503cc these are good for 420hp
the garretts flow more cfms than the ihi's. why do we use such big injectors? are we cooling combustion temps with fuel?
thanks all
Old 11-04-2002, 11:53 PM   #4
WRBLUEWAGON
Member#: 10745
2006 VW SUV
our fuel rails are ****ty. My understanding is with fuel rails just added to the EJ20 15% to 20% gas would need to be taken away for them just not to run pig rich.
STI's only flow 530 so 370hp
Eric
WRBLUEWAGON is offline   Reply With Quote
Old 11-05-2002, 03:46 PM   #5
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Re: injector size?
thanks all
I've often wondered that as well. IMO, it almost has to be related to the combustion chamber, rpm range, piston crown, cylinder head, and coolant flow design, as well as camshaft profile. In other words, Volumetric Efficiency. FWIW, I've noticed over the years some engine designs can make peak torque/hp with a really lean A/F, while others...you can't give 'em enough fuel.
n2xlr8n is offline   Reply With Quote
Old 11-05-2002, 06:50 PM   #6
jibber
Member#: 6675
98 SF5 some mods
01 allroad
Default injectors
i 'm wondering about turbo shaft speed / and impeller eficency. it's relation to combustion temps. the ihi turbos spin at something silly like 180,000rpm and a garrett t3 t4 spins at like 100,000rpm
this all has to make some sort of effect on combustion temps. could this be why the big difference in fueling needs.
thanks again
WTB: STi pink injectors/ 07 STI injectors/ 06 WRX injectors bwco VIC Private Classifieds 8 06-19-2013 10:40 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 19 11-24-2007 10:30 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 25 11-12-2007 04:36 PM
FS: My personal SDSEFI.com Extra Injector Controller, Two 480cc injectors, TB mount + ImprezaRS dot com Rocky Mountains Impreza Club Forum -- RMIC 12 01-29-2003 10:31 PM
Injector Pulse Width to Injector Duty Cycle SonicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-19-2002 09:36 AM
