Old 11-04-2002, 10:17 AM   #1
JohnWad
Member#: 4768
2002 WRX Sport Wagon
Default UTEC Datalogging Lock Up
Just got the UTEC installed this weekend and WOW! Very impressive versus the Unichip. I am still rich running the Stage 2, but I am having trouble datalogging. Everytime I run datalogging my computer locks up after the screen fills up completely. It still gathers data, but I am unable to pause it, or exit it, and the only way to stop it is to CTRL/Alt/Del out of Hyperterminal. I have an older laptop running Win95 and I think the old beast just can't keep up. Is there a setting that can be changed to avoid this problem? Any suggestions are welcome.
JohnWad is offline   Reply With Quote
Old 11-04-2002, 11:35 AM   #2
scrmnsmn
Member#: 8299
Midnight Swirl
Default datalogging
I doubt it's your laptop. I'm using a 486 with Windows 95 now, but I was using a 386 with Windows 3.1 previously. It works fine on both, but if I don't follow a specific procedure it will lock up on me. First I boot up the laptop and double click on my hyperterminal UTEC shortcut. Then I turn the key to the on position, bringing up the initial menu. If I'm only datalogging I go ahead and start the car up. If I turn off the key while Hyperterminal is running, it will lock up, and I have to repeat the procedure.
How are you starting the datalogging? Are you using the transfer pull down and the capture text option? Also make sure your settings match those in the UTEC directions.
Chris
scrmnsmn is offline   Reply With Quote
Old 11-04-2002, 11:57 AM   #3
JohnWad
Member#: 4768
I have the settings per the instructions. When I want to log, from the main page, goto transfer/capture text and then press 1-6. I am logging the data, I just can't stop unless ctrl/alt/del is hit. I can pause or start as long as the screen hasn't filled up with data though.
Old 11-04-2002, 12:54 PM   #4
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
From the main menu, press 1-6, or "L". THEN do the capture text routine, specifying where you want to download the file to.
Right?
DarthChicken is offline   Reply With Quote
Old 11-04-2002, 12:57 PM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
alt-t doesn't get you to the transfer menu?
If that's the case, you have to understand that it has absolutely nothing to do with the UTEC, or your serial connection
It's the simple fact that your computer can't keep up with writting a text file, and driving a serial port.
If you have a 16550 UART onboard, make sure the buffers are set to their highest settings, make sure that your set at 19200, and/or try 4800 and see what happens.
Check resources too.. anything under 60% is going to be bad...
Defrag
Scandisk
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 11-04-2002, 01:02 PM   #6
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
This is related to the electrical connection of the serial port. Trust me, I go through a similar routing constantly with Sun servers and Cisco routers. You will have to determine which method works and then just stick to it. Generally any deviation from this method will cause a lock up on the port or the device (in this case UTEC).
Go with what scrmnsmn said, that sounds most likely.
Once I get my UTEC (mid-October? ), I'll post the exact procedure but his method sounds pretty accurate according to the crap I have to do every day with serial ports.
Good luck,
Scott
sdecker is offline   Reply With Quote
Old 11-04-2002, 01:22 PM   #7
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Are you using battery power or external power for the laptop?
ScoobieSnaX is offline   Reply With Quote
Old 11-04-2002, 02:14 PM   #8
JohnWad
Member#: 4768
Battery Powered. Thanks for the suggestions!
Old 11-04-2002, 02:30 PM   #9
epsilon
Member#: 24509
2003 WRX 5MT sedan
WRB RiftsTuned
I would second Jorge's advise and also suggest that you set your serial port's settings (in Windows, not just HT) to N-8-1, hardware handshake. You may also want to try a different terminal emulator (I recall HT was patched at some point back then). Also, applying the latest 95 service pack couldn't hurt.
epsilon is offline   Reply With Quote
UTEC Datalog Analyzer T-WRX UTEC 11 06-24-2008 08:03 PM
DCCD- Locking up? Brakes Locking? benolium Transmission (AT/MT) & Driveline 5 10-07-2005 09:28 PM
question bout the utec locking up RACER1269 Engine Management & Tuning 0 01-25-2005 05:31 PM
Stage 2 Utec datalogging scrmnsmn Engine Management & Tuning 4 10-23-2002 06:53 PM
Evaluate my UTEC datalog ScoobieSnaX Engine Management & Tuning 19 10-01-2002 02:47 PM
