Old 11-04-2002, 10:47 AM   #1
Will98RS
Member#: 15816
1998 Impreza RS
Default wrx rear seats in an rs
im not sure if this is the right forum but...
i have a 98 rs and i was wondering if anyone knew if wrx rear seats would fit. looking forward to snowboarding season and i would like the pass through. thanks
will
Will98RS is offline   Reply With Quote
Old 11-05-2002, 08:47 AM   #2
Will98RS
Member#: 15816
1998 Impreza RS
no love?
bump
Old 11-05-2002, 10:59 AM   #3
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
i want to know too. last i heard, it wouldn't fit properly without some modification. then again, anything will fit with modification...and what i heard was just heresay...
Darby is offline   Reply With Quote
Old 11-05-2002, 04:57 PM   #4
JaiMak
Top Scoob 004
Member#: 697
1999 Top Scoob #4
Satin White Pearl
They will bolt right in, but they will sit a touch higher..
JaiMak is offline   Reply With Quote
Old 11-05-2002, 05:13 PM   #5
RuCKuS
Member#: 7260
bann ning teh
jamaican bobsled team...
any idea how much higher?...would these fit?:
jeremy...
RuCKuS is offline   Reply With Quote
Old 11-05-2002, 06:24 PM   #6
Julian
Member#: 1182
MY00 RS
BRP
The FRONT seats bolt in. The rears do not fit like stock. It can't be THAT different, but may not end up looking/fitting as easily.
Julian is offline   Reply With Quote
Old 11-05-2002, 10:07 PM   #7
Will98RS
Member#: 15816
1998 Impreza RS
so who wants to lend me their wrx rear seats so i can test fit them
Old 11-05-2002, 11:13 PM   #8
TonyWRX
Member#: 21146
jeremy...
i want those seats so bad
TonyWRX is offline   Reply With Quote
Old 11-06-2002, 08:27 AM   #9
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
i believe something to keep in mind is that the rear seats would fit better in a 4 door GC8. (just thought i'd mention that since the rears are slightly different between GC8 coupes & sedans-U.S.)
Old 11-06-2002, 08:41 AM   #10
vermonturbo
Member#: 22698
Default rear seats
hey guys just try it. i put wrx seats in my 91 legacy4dr. the bottom back seat bolted right in to those wire loop hangers that are in thelower front and the plate mounts in the rear. it should be close enough but you might have to drill the hole out on the plate mounts to be able to put the bolts in. the upper back seat has those rod sections that come down over hooks on the body of the car, again subaru did not stray far from mounting locations. the lower mounts for the upper back seat are also withinreach of the original mounting holes. the only problem i had is that bracket for the fold down to lock it in place would not work without redrilling or just finding a different mount fro it at a junk yard. there are a few gaps around the edges for seats but nothing that foam and trim wouldn't cover up. take a couple dimensions on thespacing of your brackets for the top and bottom seats and compare them to the rex...they should be close. gooodluck
vermonturbo is offline   Reply With Quote
Old 11-06-2002, 09:37 AM   #11
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
Default Re: rear seats
cool, i'm gonna try it soon...gotta finish other projects first KYB AGX /Eibach's/STi top mounts and upgraded rear swaybar going in this friday
wrx seats in an rs...problems kaptainkevlar Interior & Exterior Modification 1 03-24-2007 04:40 AM
WTT my 03 wrx rear seat for an all black rear seat BuggeyEYED Private 'Wanted' Classifieds 0 07-20-2006 02:36 PM
Wagon rear seats in an 00 RS coupe SubeSTIle Interior & Exterior Modification 0 07-03-2006 02:14 AM
WRX rear seats in RS? trojan9x Interior & Exterior Modification 4 10-13-2002 08:27 PM
WRX seats in an RS aowRS Interior & Exterior Modification 5 04-26-2001 12:29 AM
