Old 11-04-2002, 11:22 AM   #1
Scooby_Treat
Member#: 20676
Default Help with APEX Auto TT
Help how do i hook up the APEX o2 sensor 2 the cars O2 sensor. and where do i ground APEX"s wire into the ECU so i can get the auto timer to work?????
Scooby_Treat is offline   Reply With Quote
Old 11-04-2002, 01:19 PM   #2
BullsWRX
Member#: 12097
2003 Ford Mustang GT
Dark Shadow Grey
its been a while.. but I'm 85% sure there were 2 wires for the rear o2 sensor. Those are the 2 I connected mine to for the A/F readings.
One of them is the ground. But the autotimer isn't going to work on our cars. We have a heated o2 sensor. Just set it to a default and go with it.
BullsWRX is offline   Reply With Quote
Old 11-04-2002, 01:52 PM   #3
Scooby_Treat
Member#: 20676
where are these wires located???
Old 11-04-2002, 04:07 PM   #4
jfalcon001
Member#: 23062
2002 Impreza WRX
Default WRX ECU Wiring Diagram
Here take a look at
http://www.northursalia.com/m...ng/wrxpin.html
This will show you the entire list of wires comming out of the ecu. It is very very helpful...
I also have the apexi TT and A/F gauge... i just wanted to mention to you that the A/F on it is going to be worthless if you connect it to the rear o2 sensor.... the air will have already gone through three cats. And since the front o2 sensor is wide band you can't connect to that at all. The only solution i have had to this problem is to install another new aftermarket o2 sensor. Otherwise the A/F should be trusted about as far as you can push you car up a hill on an icy new england road with the e-brake on.
Justin
PS.. i got alot from people on the board... i am sure if you search you can find some of my posts about this.
jfalcon001 is offline   Reply With Quote
Need help with Blitz Duall TT 03 wrb Electrical & Lighting 7 04-25-2006 10:42 PM
NYC:Helix up, apex-i tt, gtspec Supreme Private 'For Sale' Classifieds 13 12-23-2004 04:04 PM
Need help with Apex-i EL2 boost gauge Thai Silk Mid Atlantic Impreza Club -- MAIC 8 10-28-2004 01:28 PM
need help wireing apex i tt billyr2.5 Electrical & Lighting 7 07-08-2004 04:10 AM
i need some help with apex controllers... Vidiotgamer General Community 1 06-09-2003 03:32 AM
