Old 11-04-2002, 04:46 PM   #1
gldenchld
Member#: 19994
Question How many degrees of advancement are you running with link?
To anyone who has a link, how much degrees of advancement are you running?
gldenchld is offline   Reply With Quote
Old 11-04-2002, 05:08 PM   #2
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
When I had mine I ran around 9 or 10 (20 total) at 18psi. I didn't know much about tuning back then and tried to get my a/f ratios around 11.5:1 which was way to lean on 92 octane. I managed to squeak out a 13.5 @99Mph with that setup.
I've seen some maps with 13 (23 total) or higher.
ScoobieSnaX is offline   Reply With Quote
Old 11-05-2002, 02:47 PM   #3
JenisonWRX
Member#: 6049
02 WRX & 99 RS
well where? what rpm and MAP?
My timing changes quite a bit ...
I will say this though ... drop it down inthe mid range and ramp it up to redline as boost goes down.
I run about 15 in the mid range and ramp up to 26 at redline ...
I run 94 octane
I ran a 13.5 @ 101 and with the stock turbo.
I will be back to the track in the spring ... and it will be faster. Doing many things to it right now
JenisonWRX is offline   Reply With Quote
Old 11-05-2002, 07:32 PM   #4
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
Your advance will look pretty much the opposite of your boost curve. Before boost builds you will have high timing numbers and as boost rises timing will fall. The low point of timing will usually be at the peak of your torque (not necessarily the peak of boost.) At that point you will want to run around 12-14 degrees of advance at say 17psi of boost (just aproximations.) From there your boost should gradually taper down and as it does your advance will rise. By redline it should peak again at around 22-27 degrees again depending on how much boost you hold to redline.
These numbers are gross aproximations and are based on 91-93 octane fuel. Race fuel will allow you to run more advance without detonaton. You should always advance your timing when using street fuel so long as A. detonation is not present and B. you are creating more power by doing so.
Here is a map of a 3rd gear pull at Wide Open Throttle (WOT) using a stock turbo and fueling system on 02 WRX. Notice the timing curve (dark grey) looks pretty much opposite the boost curve (green):
Always remember to add 10 degrees to what is displayed on the timing map of the Link. If you see 4 for example the actual timing is 14.
Hope it helps...
-Jonathan
mynew02 is offline   Reply With Quote
Old 11-05-2002, 08:26 PM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Hmmm from a low of about 10 to a high of 50 depending where on the map you are.
Midwayman is offline   Reply With Quote
Old 11-07-2002, 11:28 PM   #6
Delicious Tuning
Member#: 1990
Timing is also dependent on the RPM's of the car. As the motor speeds up you will need to increase your timing to make up the time difference between spark and peak compression. This si where you get your most power, and how the DYNO results become so high.
Delicious Tuning is offline   Reply With Quote
How Many Shades of Black Are There? tairese Newbies & FAQs 36 06-19-2006 09:15 PM
How many out of towners are coming to the UG BBQ? DanzBorin Texas Impreza Club Forum -- TXIC 16 04-27-2006 09:59 AM
How many gigs of pr0n do you have you your HD? wyn525i Off-Topic 13 09-27-2004 10:35 AM
how many miles per tank are you guys getting? newb General Community 46 01-30-2004 07:12 PM
how many miles per tank are you getting STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-09-2002 11:54 PM
