Old 11-04-2002, 07:10 PM   #1
Scott F. Williams
Member#: 13930
1999 Impreza 2.5RS
Silverthorn Metallic
Default how to: install rear trailing arm bushings
Hey, I just picked up a set of Whiteline poly bushings that fit the rear trailing arms. Specifically, they replace the rubber parts that are in the front of the trailing arm. My question is: does removing the stock bushings require a press? And, must the trailing arm be completely removed from the car to do it? Or, can the stock parts be slid out after droping just the front of trailing arm down?
Thanks,
P.S. Has anybody got some before/after stories to report about this modification? I'm wondering how much of an effect they have on turn in, mid-corner stability, ride quality, etc.
Scott F. Williams is offline   Reply With Quote
Old 11-04-2002, 07:17 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I've got the STI versions of these bushings and would like to know as well...
From what I've heard, you need a press to get them in and out.
nhluhr is offline   Reply With Quote
Old 11-05-2002, 06:54 PM   #3
WhatleyWRX
Member#: 6634
2002 WRX Sedan, Dirt
with some Silver patches
I completely removed mine, pressed them out, pressed the new ones in. They aren't going to fall out I can't contribute on before/after. I did all my suspension stuff at one time.
Whatley
WhatleyWRX is offline   Reply With Quote
Old 11-05-2002, 09:21 PM   #4
Scott F. Williams
Member#: 13930
1999 Impreza 2.5RS
Default press'm out/ press'm in - got it!
Thanks for the info, man. I was hoping that they'd slide out, but... from an engineering perspective I suppose that it is better that they don't. Right on.
Old 11-06-2002, 11:37 AM   #5
WhatleyWRX
Member#: 6634
Not sure that you need a full on hydraulic press for this. I used a small arbor press, worked fine for me.
Whatley
How to remove rear trailing arm bushing in 5 min txl146 Brakes, Steering & Suspension 57 11-11-2013 01:44 AM
Some pictures of the rear trailing arm bushing install trhoppe Brakes, Steering & Suspension 4 06-10-2004 05:31 AM
"BIGSKYWRX" Rear Trailing Arm Bushing Installation Tool Moondongle Private 'For Sale' Classifieds 7 03-31-2004 02:03 AM
