Old 11-04-2002, 10:46 PM   #1
E-Ticket
Member#: 4128
2002 WRX Sport Wagon
Default Where to tap voltage for Valentine 1?
And yes, I already did a search.... couldn't find anything. But that could be "operator error" as well. <grin> If you of a thread/FAQ, please point in the right direction.
2002 WRX Sport Wagon. Want to hardwire in a Valentine 1 radar detector. Looking for the right point in the fuse panel for the voltage/ground points.
Many thanks! - E-Ticket
"Leave no turn unstoned.."
E-Ticket is offline   Reply With Quote
Old 11-04-2002, 11:00 PM   #2
eightballrj
Member#: 18520
2005 L GT Limited
This might sound rigged but I just quick spliced mine into the cigarette lighter power wire since i dont smoke. Then i unscrewed a bolt on the bottom of the steering brace(steering column) and removed some paint and used that for a ground. It works great. Enjoy that thing!!!!! I love mine! I hope I helped.
RJ
eightballrj is offline   Reply With Quote
Old 11-04-2002, 11:19 PM   #3
tdxflex
Member#: 13634
if you have an auto/dimming compass in the rear view mirror, you can tap the power wire from there.
tdxflex is offline   Reply With Quote
Old 11-05-2002, 01:47 AM   #4
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Tap the map lights... I did with my Bel 985. Works great!! make sure you get the constant power and not the switched power.
def
dug-e-fresh is offline   Reply With Quote
Old 11-05-2002, 01:51 AM   #5
yonrin kudo
Member#: 17019
Hi,
I got a V1 a month ago but still havent hardwired it yet heh.
Here's link to check out: V1 Install
Cheers-
yonrin kudo is offline   Reply With Quote
Old 11-05-2002, 07:21 AM   #6
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Here is a link to my install:
V1 install above rear view mirror
Paul G.
paultg is offline   Reply With Quote
Old 11-05-2002, 08:41 AM   #7
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
paul g- do you still get good rear readings because it looks like its pointed up pretty well....
ScreaminFast is offline   Reply With Quote
Old 11-05-2002, 08:59 AM   #8
paultg
Member#: 437
'91 Miata MX5 (Red)
I have a wagon, and I can see the detector from the rear of the car. I haven't had any issues. You can slide the detector in and out of the clip to angle it correctly. The picture might make things look weird, but it's not pointing up when I drive.
Just walk a good 20-30 feet behind the car and make sure you can see it before you complet the install. That's what I did.
Edit: After looking at the last picture I'm pretty sure I have the mount a bit lower (bottom of radar closer to mirror). I keep it just close enough so the mirror doesn't bounce and hit the mirror.
Paul G.
Old 11-05-2002, 09:14 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Here's where I put mine, the bracket is mounted semi-permanently where the useless center visor was, using an already existing plastic push-pin from the headliner-
Lines up in just the right position and has clear visibility to the rear, and is not that easy to spot from outside. The unit slides in and out of the bracket in about 5 seconds.
And the remote display-
As for wiring the adapter is located at the fuse box and the power is tapped from the yellow/red wire that powers the mirror and some other stuff. Ground is direct to chassis through one of the bolts that secure the fuse box.
Old 11-05-2002, 09:27 AM   #10
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
thats cool, i def am considering one, but its ruff to drop 400 bucks on something like that....
Old 11-05-2002, 09:48 AM   #11
DJWRX
Member#: 10340
Mulder, could you post those pictures again, I can't get them to come up. Wait, I can see them here in the reply page, but not on the normal thread. Oh well, looks good. How much was that remote display? I've been wanting one of those for a long time.
I hardwired my V1 into the fuse box, I just found a fuse that had power as long as the key was turned on. It's mounted left of my rear view. I just flip my visor down if a cop is behind me, especially at night, which might look a little strange, but I'd rather him/her see that than my V1 exploding.
A side note on radar placement, I think it's ok to not have a perfectly clear line of site out both windows. Radar bounces and scatters off everything. While it is optimal to have unobstructed paths out the windows, it is not necessary. Just my opinion though...
A semi-OT quesiton, is there any advantage to using a three line(6 contacts) phone line for the power line? I'm pretty sure I saw more than four contacts in the detector, but I don't remember for sure. So, am I missing out on any functions by only using a 2 line phone line?
Tim
DJWRX is offline   Reply With Quote
Old 11-05-2002, 10:06 AM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not sure how much the remote display costs these days, check the V1 website for current product and pricing info.
The remote display I have is an older model that included only the display and was smaller than the present one which also has a control knob next to the display. Because of the smaller size I was able to install it inside the dash behind the bezel, but unfortunately the newer one is too large to fit in there.
Yes the unit will still work without a clear line of sight out the rear window but there will be some signal attenuation. It's best to have an unobstructed "view".
As for wiring there are four contacts and the wires provided with the unit are 4-conductor so that's what you should be using. I don't know what the individual pin functions are (power, data etc.) but if you are using 2-conductor wire and it works then leave it alone. It's possible the extra conductors are used for the external accessories that you don't have yet, if you add them you'll find out.
Where to tap power for Autometer electric boost gauge? daybreak Electrical & Lighting 5 04-28-2003 11:13 PM
Where to tap power for wideband? SonicWRX Engine Management & Tuning 6 12-31-2002 08:56 PM
Where to tap power for wideband? SonicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-27-2002 07:55 PM
Where to tap onto for the EGT N/A Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-14-2002 10:35 AM
Where to tap in for boost gauge??? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-18-2002 02:33 PM
