Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 11-05-2002, 11:30 AM   #1
GregUnd
Baaleted
Member#: 11800
Default Is there any ride height control for WRX
I'm thinking of getting a ride height setup and was wondering if there was any availible. I would like to able to raise the beyotch when I'm going off roading.
GregUnd is offline   Reply With Quote
Old 11-05-2002, 11:51 AM   #2
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
Sorta, in a way, in that some coil-over setups have a manually adjustable spring perch height, which will change ride height. Its a long way from 'push a button to go off-road' kind of deal.
Sam2 is offline   Reply With Quote
Old 11-05-2002, 11:58 AM   #3
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
Old 11-05-2002, 12:12 PM   #4
DarkShadow
Member#: 17615
2009 Toyota Tundra
Tien has a electronic height controller for the Flex coil overs. You can change the height on the fly.
DarkShadow is offline   Reply With Quote
Old 11-05-2002, 12:24 PM   #5
D_REX
Member#: 8945
MY02 WRX
WOW!!!! This is really cool stuff. I know all about EDFC where you can electrically adjust damping from within the cockpit (they accomplish this by using small motors on top of the shocks) but ride height adjustment is new.
Please give me a link or at least a description. I'm really inderested in how this works.
D_REX is offline   Reply With Quote
Old 11-05-2002, 12:37 PM   #6
GregUnd
Baaleted
Member#: 11800
where can I find some of this stuff????
link please
Old 11-05-2002, 12:43 PM   #7
DarkShadow
Member#: 17615
2009 Toyota Tundra
Old 11-05-2002, 01:00 PM   #8
D_REX
Member#: 8945
MY02 WRX
OK, Like I said before, EDFC is cool, but ride height adjustment it isn't. So where is the remote ride height adjustment stuff?
Old 11-05-2002, 01:39 PM   #9
jmott
Member#: 6713
2007 Prius
brown
the ferrari f50 has remote ride height adjustment =)
greg -your going to have very few options if you want coilovers that can go from the stock ride height and lower.
there are some DMS50s you can get setup to do that.
jmott is offline   Reply With Quote
Old 11-05-2002, 01:43 PM   #10
GregUnd
Baaleted
Member#: 11800
Hmmm.... I'm kinda looking for maybe 2-3" over stock height and 2" under stock height. Anything out there?
Old 11-05-2002, 02:22 PM   #11
D_REX
Member#: 8945
MY02 WRX
NO
If you want 4 -5 inches of adjustment out of a coilover you need much more than a threaded spring perch.
Old 11-05-2002, 02:33 PM   #12
GregUnd
Baaleted
Member#: 11800
Originally posted by D_REX
NO
Well what then damnit? I WANT HEIGHT!!! and low
Old 11-05-2002, 03:16 PM   #13
jmott
Member#: 6713
2007 Prius
brown
you dont need to be higher than stock to do most offroading.
the WRC cars arent that high.
and you dont need to be 2 inches lower than stock either
Old 11-05-2002, 03:38 PM   #14
fusilier
Member#: 26352
83 Audi Rally
Audi Sport
If you serious about taking your WRX offroad then your going to need something that can take a pounding. A street coil-over kit won't last one hour on a hard rally. Get your hands on a subaru works suspension setup shouldn't be too hard to find considering the number of WRx in prorally. I have an ex-audi rally suspension with the Sachs/Boge custom uprights with the adjustable fluid and rebuildable internals. They can go up and down about +4" and -1" from "nominal" with adjustable spring perches on the coil overs. You want the car as low as you can even off roading. +4" would be the Audi setup for Kenya or something severe like that. -1" would be an asphalt rally.
Why reinvent the wheel? You've got good competing WRX on the rally circuit. Just get what they use and put it on your car. Might take some custom work, but its not impossible. DMS makes a pretty reasonable suspension for rallying and its not too expensive. Some guys have converted their Audis over to DMS with good results after trying a Koni setup that lasted about one hour.
Do WRXs have control arm braces that go from the hub/axle area of the control arm forward to the frame so that you can take jumps and hit ditches without breaking off control arms?Try these on for size..
fusilier is offline   Reply With Quote
Old 11-05-2002, 04:25 PM   #15
Kartoffel
Member#: 12976
grocery getter
Adjustable ride height?
Get you some airbags and a hydraulics kit! Crazy stylee!
Kartoffel is offline   Reply With Quote
Old 11-05-2002, 04:28 PM   #16
Kartoffel
Member#: 12976
grocery getter
Yup. Most rally cars are not much higher than stock height. They are just way stiffer.
Old 11-05-2002, 04:57 PM   #17
GregUnd
Baaleted
Member#: 11800
It's not need Jack, but more want
No seriously, about 1"-2" higher than stock would be great. But on the street, I would like my -1.5" drop
Old 11-06-2002, 01:30 PM   #18
rossman
Member#: 6652
2002 wrx
mbp, wingless
I'm pretty sure the answer to your question is "yes." Definitely in the rear not so sure in the front.
Excuse my ignorance but is your car is similar to a '83 Quattro?? I dated a girl in college who had one of these. Really cool car.
rossman is offline   Reply With Quote
Old 11-06-2002, 02:10 PM   #19
fusilier
Member#: 26352
83 Audi Rally
Audi Sport
I would expect them in the front before the rear. When going off road the more typical failure is for the front tires to plow into something causing a rearward force on the control arm instead of the typical up/down. The brace is essentially a long tension rod from the tip of the control arm to the frame. Its essentially for off road rallying. Otherwise hitting a dip could rip the control arm off the subframe
You dated a girl who drove an 83 quattro? Very cool. Thats a high maintanance original supercar. I have an 83 street Quattro in original form and an 83 quattro rally car. If you want to see them check out www.austinaudiclub.org
some pictures of the car.
http://forums.audiworld.com/quattro/msgs/732.phtml
http://forums.audiworld.com/quattro/msgs/780.phtml
http://forums.audiworld.com/quattro/msgs/834.phtml
James Bufkin
Austin TX
Old 11-06-2002, 03:17 PM   #20
rossman
Member#: 6652
2002 wrx
mbp, wingless
Cool pics. I'd like to see it first hand.
A tension rod just seems like a better design to me. My old 240Z had (has) a compression rod design which always seemed a little goofy to me. But I guess it's probably lighter (since it didn't require heavy structure near the nose of the car to react the loads) and Z's aren't exactly rally cars. I do remember seeing some old picture of one in a safari rally though.
The girl I dated was very proud of that car. Her daddy bought it for her brand new as a H.S. graduation present. She let me drive it a couple of times, very nice.
Ross
James Bufkin
Austin TX
Old 11-06-2002, 05:25 PM   #21
fusilier
Member#: 26352
83 Audi Rally
Audi Sport
Ross
Ross, where are you at? Anywhere close to Austin?
Audi only imported about 600 original quattros from 1983 to 1985. They're very rare cars and were all handbuilt. New in 1983 they cost more than a new Porsche 911..... Interesting factoid cause its the first all wheel drive turbo supercar which puts it solidly in the top 20 of the 50 greatest cars of all time.
James Bufkin
Old 11-07-2002, 02:03 PM   #22
rossman
Member#: 6652
2002 wrx
mbp, wingless
Houston .
Wow, didn't realize it was such a special car. Makes sense though, her daddy was very wealthy, Shell big wig, river oaks house, bla bla.
gregung: sorry for hijacking your thread.
Old 11-07-2002, 03:07 PM   #23
John C
Member#: 4429
Houston .
You still have her number, right?
John C is offline   Reply With Quote
Old 11-07-2002, 05:24 PM   #24
tEkkGOD
Member#: 10110
greg, did you read your pm's??
tEkkGOD is offline   Reply With Quote
Old 11-08-2002, 05:40 PM   #25
rossman
Member#: 6652
2002 wrx
mbp, wingless
Yea, right! But it did take her a while to realize I was a loozer. I'm not sure but I think my beat up toyota pickup and lack of beer money gave me away. .
Is there a generally accepted estimate for WRX mileage ceiling? Asinine General Community 54 09-23-2008 11:30 AM
Is there any benefit (power wise) for rotated setups? tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 08-19-2005 12:34 PM
Is there any way to search for threads that you've posted in that have been closed? Handsdown Off-Topic 5 04-14-2005 02:22 AM
Why is there no ride height and damp force adjustable coilover for under $1000? Caplin 2.5 Brakes, Steering & Suspension 16 02-11-2005 03:00 AM
Is there any higher performing injectors for the WRX besides the STi? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-22-2002 09:53 PM
