Old 11-05-2002, 10:15 PM   #1
Jake Steed
Member#: 24756
2002 WRX sedan with
scratch marks and dirt
Default Will Endless or Carbotech pads fit StopTech brake kit?
I was wondering if I could use Endless NA-Ys or Carbotech Panther pads with a StopTech brake system? Will the pads fit the 4-piston calipers? Thanks.
Jake Steed is offline   Reply With Quote
Old 11-05-2002, 11:43 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I believe the Stoptech kit uses the same shape as one of the Porsche pads, if someone here doesn't pipe up with it (I'm sure someone will), then email Stoptech and ask them which years of which models are common. I understood this was one of the advantages of the Stoptech kit, reasonably priced pads because they are common with other high performance applications.
Regardless, if you call Carbotech, you'll find out that they will take a set of used pads, de-bond the leftover pad and use the old backing plate for their compounds. So in any event you can definitely use Carbotech pads if you want.
Concillian is offline   Reply With Quote
Old 11-06-2002, 09:02 AM   #3
Tuning Factory Inc.
Vendor
Member#: 3600
Which Porsche pad does it use? I can look it up. I think Endless makes most for the brembo calipers which should work.
Tuning Factory Inc. is offline   Reply With Quote
Old 11-17-2002, 07:23 PM   #4
MattN
Member#: 24710
I am not 100% sure of the number (I'm at home, not at work), but I am nearly 100% sure we have pads for that. And I think you're right, it's a Porsche pad.
MattN is offline   Reply With Quote
Old 11-17-2002, 08:02 PM   #5
wylie
Member#: 7387
02 wrx wagon
blue
Jake,
If you haven't already checked out the Stoptech website, here you go:
www.stoptech.com/faq/data/faq19.html
The FMSI number is D372. I know the guy at Carbotech is really helpful.
wylie is offline   Reply With Quote
Old 11-18-2002, 07:03 AM   #6
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Question
Hi Matt, is there any other pad in your lineup that would not stain the rotors like the panthers but brake just as good?
I have the panthers and they are staining teh hell out of the clear coat on the rim. like little black flakes!
Thanks,
Leo
Leonardo is offline   Reply With Quote
Old 11-18-2002, 09:18 AM   #7
MattN
Member#: 24710
Hey Leo, I responded to you in this thread: http://forums.nasioc.com/forums/show...ight=Carbotech
You're the only person I've talked to that has had any wheel finish issues with our Panther pads.
Old 11-18-2002, 09:36 AM   #8
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Replied!
Auto Plaza here in PR has had the same results as their owner and mechanic had told me about this when they sold them to me as the OEM 4pots were sold out
Leo
Old 11-19-2002, 10:53 AM   #9
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Bump!
06 sti brake pads will 05 and lower pads fit? freshpl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-18-2007 01:27 PM
Pads for StopTech Brakes ? cyrexpl Brakes, Steering & Suspension 2 03-31-2006 11:23 AM
Wanted: carbotech pads and superblue brake fluid Penguinking Private 'Wanted' Classifieds 3 07-30-2003 08:06 AM
How are is the Stoptech brake kit supposed to feel? ImprezaWRXDriver Brakes, Steering & Suspension 28 09-25-2001 11:04 PM
Stoptech Brake Kits ImprezaWRXDriver Brakes, Steering & Suspension 11 09-01-2001 08:13 PM
