#1 |
Member#: 18751
Vehicle:2000 Impreza RS Aspen White |
I have a 2000 RS with a 5 speed. I must keep the A/C. The car has stock drivetrain. However, I have a very large skidplate blocking any airflow to the oilpan. I go to track days, rallycrosses and other "hard" driving.
Of the three gauges below, which one would be most important or which one do I put right in closest to my line of my direct line of vision. I only have room for one at this location. *Oil Pressure *Oil Temperature *Water Temperature Thanks for your input. Gravel
#2 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
I doubt any useful cooling comes from air flow around the pan. Not much air flows past, the airflow would be too turbulant. I suggest connecting you own digital gauge to the stock dash gauge sender unit (disconnect dash unit) and go from that point.
#3 |
Member#: 2683
South East
Vehicle:2011 STi 5-Door White |
My oil temp gauge dropped 10 degrees Celcius from its previous warm average when I took my skidplate off. It's the Subaru perf. gauge pack gauge. FYI.
Ross N. |
#4 |
Member#: 6178
Vehicle:98 GM67 + 03 SG6 2 whls > 4 whls |
Give me about a month to get the gauges in and figure out how I need to "persuade" the skid plate so it'll fit around my headers, and I'll be able to tell you. All 3 will be in, probably before the skid plate as I need to create a jig to keep the mounting holes in the same place so I don't skew anything while shaping it.
AJ |
#5 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
Get an oil cooler.
#6 |
Member#: 18751
An oil cooler is in the plan.
Thanks Gravel |
| Thread Tools | |
| Display Modes | |
| What is most important when looking for a used subaru? | Kel Dub | Newbies & FAQs | 8 | 11-06-2006 04:54 PM |
| Relationship-wise, what is most important?... | Hazdaz | Off-Topic | 10 | 08-17-2006 11:02 AM |
| what is most important to monitor w/ gauges? | Vampyr | Interior & Exterior Modification | 30 | 09-27-2005 08:34 AM |
| What is MOST important to women? | MeddlingKids | Off-Topic | 127 | 12-20-2004 06:04 PM |
| What one mod will make the most diffrence? | 128d | Factory 2.0L Turbo Powertrain | 16 | 08-27-2001 02:50 AM |
