Old 11-08-2002, 02:12 PM   #1
jbdadog
Member#: 12820
Cool REplace factory guages?
I'm lloking to replace the factory guages with new greddy electric guages. Im going to replace the boost and oil temp. Just wondering if the wiring will match up or if I'll need to completely run new sending units and how hard it would be. An y input would be appreciated!
jbdadog is offline   Reply With Quote
Old 11-08-2002, 02:16 PM   #2
NYC TURBO
Member#: 25214
well, I think you can leave the pressure lines from the factory guages, but You will have to run new electrical wires to ensure proper connection for the electric guages since the stock ones are not electric. IMHO, this is not a worthwhile mod since the stock guages, aside from not being ultra bright at night are of decent enough quality to properly tune your car.
Lee
NYC TURBO is offline   Reply With Quote
Old 11-11-2002, 01:48 PM   #3
jbdadog
Member#: 12820
Default thanks
Thanks but these guages are for show not for tuning.
Old 11-11-2002, 02:04 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The factory boost gauge is mechanical and has a vacuum line run into the car to the back of the gauge. If you replace it with an electric gauge you can use the same vacuum line, just cut it so it ends under the hood wherever you mount the sensor unit for the new gauge.
The factory oil temp gauge is an electric one and the sensor is in the oil drain plug. This sensor may or may not be compatible with your new gauge. You can measure the resistance of both sensors at ambient temperature to see if they match, or just try the new gauge with the old sensor and see if it is accurate. If you need to replace the sensor the drain plug is still the best place for it, so you can either see if Greddy has a pre-made plug/sensor unit available or buy a new drain plug and modify it to accept the sensor.
Old 11-11-2002, 06:19 PM   #5
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Wait... are you serious? You just need power and that's it? You're just going to use them for looks?
I'm probably reading that wrong... but I guess if that's all you're doing, then you may want to just use mechanical gauges because they usually only require 12v and that's it - don't need to worry about expensive sending units and all that stuff.
CirrusWRX is offline   Reply With Quote
Old 11-11-2002, 08:00 PM   #6
HellWagon
Member#: 16172
Default Re: thanks
If thats the case why not glue egg timers, alarm clocks, or anything else with a dial to the inside of your car.
HellWagon is offline   Reply With Quote
Old 11-11-2002, 09:25 PM   #7
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
I gotta flux capacitor for real cheap if ya want one.
sorry to be an @ss
Old 11-11-2002, 09:58 PM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
does running hot oil to your dash scare you at all? i am fine with air for boost, but hot oil. if you install them incorectly you could have a major mess. for boost go with mechanical, for water and oil go with electrical, unless you want to run and oil/water feed up to your dash.
subiekid is offline   Reply With Quote
Old 11-11-2002, 11:32 PM   #9
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
but read his original post -- to me it doesn't appear he'll be running ANYTHING in them at all - he could have a mechanical nuclear core gauge, but if nothing is running in it, who cares
Old 11-12-2002, 10:42 PM   #10
subiekid
Member#: 25516
how bout getting one of these maybe you should run some cool glow in the dark honda signs on your car. lol
if you dont need them thendont waste your money, just by a flesh light.
Old 11-12-2002, 11:29 PM   #11
WorldOne
Member#: 22731
2002 WRB Do-Luck GDA
worldoneperformance.com
Default Disagree
Hello all.....
I think that you are all approaching this guys post with the wrong attitude.
The stock gauges may be 100% functional and they may get the job done just fine. However, lets face it, they are not very attractive to look at. Countless WRX owners have replaced the stock gauges with aftermarket units, and there are plenty of reasons for doing so.
Many do it because they like the functionality of electronic gauges over there mechanical counterparts, many are trying to unify the styling of the interior by adhering to a color, or light scheme, and some would just like more attractive gauges. All of these are perfectly valid reasons to upgrade to new gauges.
In addition the gauges in the WRX are viewed by both driver and passenger very frequently. They sit in arguably the most prominent location on the dash, and I would argue that considering the frequency with which they are viewed, all WRX owners could benefit from a set of more appealing gauges.
Not to mention, mkpa is a absolutely hideous and completely unconventional way to read boost pressure and who honestly needs a voltage gauge anyway? The stock gauge package is adequate at best.
Upgrading your gauges "for show" or for aesthetic appeal is perfectly acceptable and does not fall into the same catergory as altezza tail lights and chrome wheels IMHO. Furthermore, greddy black faced 52mm gauges are about as far from "Bling" as you can get when it comes to aftermarket gauges.
Don't worry about these guys jbdadog plenty of WRX owners have upgraded their gauges for a myriad of reasons and I am sure plenty of them will attest that they are thrilled with their decision.
Its going to be best to run new wiring since the gauges that you are going to be getting are going to be electric. You'll have no use for all of the old mechanical wiring especially the mechanical boost pressure line. Greddy gauges come with all the needed wiring and sending units.
I hope that I have answered all of your questions. If you happen to have any more just let us know.
Take care,
Garret
World One
http://www.worldoneperformance.com
WorldOne is offline   Reply With Quote
Old 11-12-2002, 11:34 PM   #12
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
I'm sorry - I've been leading the "prick responses" because I think either I've interpreted something incorrectly, or people keep missing the point:
It is my understanding, and if you READ HIS POSTS, he simply says that the gauges are NOT GOING TO BE HOOKED UP. He said he WILL NOT USE THEM FOR TUNING PURPOSES, THEY ARE ONLY FOR SHOW.
Do you NOW think that's a little strange? Again, I guess if you're showing your car and stuff, it looks cooler with gauges in it, and I guess if you don't drive it much, then it doesn't really matter if the gauges work or not.
Get why we keep doing the "bling" stuff, WorldOne??
In his own words, Thanks but these guages are for show not for tuning.
Edit: and once again, I am quite possibly interpreting his posts incorrectly, but we haven't heard a peep outta him since the most recent post! Hope we didn't scare him away!!
Old 11-12-2002, 11:42 PM   #13
WorldOne
Member#: 22731
Default Hmmmmm
Hmmmmm......
I don't gather that they won't be hooked up from his posts thus far. I think that it is piculiar that he says he won't be using them for tuning, but I interpreted "for show" as meaning that he was more interested in the visual appeal of the gauges than anything else, which I think is perfectly normal.
If indeed he doesn't have any plans to hook up the sending units than yes that would be absurd. I think that since he inquired about wiring the sending units in his initial post that we can conclude he is going to hook them up.
To answer your question, I think that aftermarket gauges that are not hooked up definately do fall into the same catergory as altezza light and those flashy valve step cap thingys.
It is funny how such a small distinction in the application of a product can completely change my mind about it.
Old 11-13-2002, 12:39 AM   #14
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Now we're talkin! LOL
Yeah - I agree, I hope I (and others) have just been mis-interpreting his meaning. I too wanted my gauges for form and function, so I got the Omori "subaru" look gauges with the yellow needle. Did I pay more for em? You betcha, but they look very nice and stock, BUT they also tell me nice things about what's going on in the engine!!
Old 11-13-2002, 06:23 PM   #15
subiekid
Member#: 25516
if you want some blingin gauges with out the high price chekc these out
http://www.scoobymania.co.uk/site_flash.asp?page=gauges
they are really nice, and only run about 80 bucks a gauge, and not to many people have htem.
Want to replace factory head unit, don't want to ditch factory sub nuggetWRX Car Audio, Video & Security 5 05-21-2008 11:48 PM
replace factory boost guage? surfer5567 Electrical & Lighting 8 05-13-2004 07:34 PM
FS: new factory guage pod replaces clock superhawk44 Private 'For Sale' Classifieds 4 04-14-2004 10:49 PM
Q: Should a Factory Turbo have Factory Guages? (Rex Question) J-Spec General Forum Archive 5 01-15-2001 07:40 AM
Factory Guage Pack (Compass one) LongIsland RS Technical Forum Archive 7 09-17-2000 03:26 PM
