Old 11-09-2002, 12:26 PM   #1
BIG BEN
Member#: 24984
2003 WRX
Default Help what wires on the clock do I tap for gauge wiring
I am installing a boost gauge and want to know what wire I tap to get the power and the ground on the clock.. Thanks
BIG BEN is offline   Reply With Quote
Old 11-09-2002, 12:40 PM   #2
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
If you look on the clock part you unplugged and removed you will noticed that the wires are labled on the connector end on the clock. I assume you are refering to the center pod, right?
lstepnio is offline   Reply With Quote
Old 11-09-2002, 01:04 PM   #3
iflybyu
Member#: 20292
2002 Impreza WRX
Platinum Silver
Default There is another way ..
Are you installing a OEM gauge? If so, there is a connector on the backside of the radio (somewhere on that harness) that carries 12v (dimmable). If you want, you can tap it anyways to get your lighting for your gauge. It's just a two wire connector.. behind the deck..
iflybyu is offline   Reply With Quote
What wire/wires on the MAF are shielded? Peeblesmx445 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-13-2007 11:28 AM
What wire is the MAF wire(06STI) to tap for Snow Kit? ace996 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 07-03-2007 08:37 PM
Which wire to tap for gauges? Hit Man X Electrical & Lighting 9 06-08-2004 07:24 AM
What cars on the road do you mistake for a Subie? chrislehr Off-Topic 35 04-11-2003 06:29 AM
What is the best way to remove the clock housing? and tap wires for gauge lighting? NYWRXTASY Interior & Exterior Modification 10 11-03-2002 11:41 AM
