Old 11-09-2002, 02:02 PM   #1
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default EJ25 Compression Test Results
Hello Guys,
I just did a compression test on my stock EJ25 before I go turbo. I'd like to see how healthy the engine is before I go through a series of mods.
Here are the results:
1) 215 psi
2) 220 psi
3) 225 psi
4) 230 psi
I did the test this morning. Any comments? Based on my research here on i-club, those numbers are signs of a healthy engine.
What's funny is that some people made fun of me when I warm up the car every morning before taking off.
What do you think guys? Should I do a second for comparison? I need a laptop to install my TEC-II.
I'm debating if I should just install the Vishnu Fuel Rails right now and the Walbro 255lph fuel pump and RC 550's so I can run in parallel now.
I don't know.....Please comment, I'd like to get insight on the experts.
Thank you,
Kevin
latinskllz is offline   Reply With Quote
Old 11-11-2002, 11:44 AM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
results seem quite positive...
I wouldn't worry about them. As for the laptop, I wouldn't install a tech II unless I knew what I was doing... that's just me. It's the tuning stages where people end up blowing up their motors and I'd hate to see yet another victim, maybe the guys in the aftermarket forced induction forum would have a better idea,
AO
m750 is offline   Reply With Quote
Old 11-11-2002, 11:51 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Woah... now those are some impressive compression test results. The books call for 165-180psi during testing. I wonder what mine is... I know nothing is broken in there yet....
Old 11-11-2002, 02:40 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yeah, that's a pretty high draw, did you do this with the ignitor disconnected??
Old 11-11-2002, 02:46 PM   #5
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default Hmmm....
What I did was this:
1) Warmed up the car to normal operating temp.
2) Released Fuel Pressure (disconnected fuel pump harness, turned the car on until it stalled)
3) removed all spark plugs and disconnected the harness connecting to the coilpack on top of the intake manifold to prevent spark.
4) opened the throttle all the way
5) turned the key to start the car, waiting 7 compression strokes till the pressure was steady. Repeated step 4/5 for every cylinder.
That was it....so did I do it with the ignitor disconnected, I think so.
Thanks,
kevin
2005 STI at 50,000 miles jasoncps Service & Maintenance 11 02-11-2009 01:45 PM
50,000 miles - compression test results! anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-01-2007 12:37 AM
Engine Overheat At 50,000 Miles!!! sube-trex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-04-2005 05:48 PM
Alternator going out at almost 50,000 miles? wrx02subbie Texas Impreza Club Forum -- TXIC 8 07-05-2005 06:41 PM
compression tested the Rex today...85k miles, mostly at Stg 4...good results: annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-11-2004 12:41 PM
