Old 11-09-2002, 05:05 PM   #1
Loan1
Member#: 27542
Default Please Respond
Does anyone know if the 2003 WRX has a different/stronger tranny than a 2002? Please respond if you know anything.
Thanks
Pete
Loan1 is offline   Reply With Quote
Old 11-09-2002, 05:10 PM   #2
RACe
Member#: 28390
'03 WRX Sedan
MBP
I am the proud owner of a 2003. Don't believe the transmission is any different.
RACe is offline   Reply With Quote
Old 11-11-2002, 11:50 AM   #3
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
2003 has a different slave cylinder arrangement. Sort of a limiter to limit the speed at which the clutch comes up.
-Michael
d00f is offline   Reply With Quote
Old 11-14-2002, 08:15 AM   #4
Loan1
Member#: 27542
bump
Old 11-14-2002, 04:07 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
no... same thing... different clutch set up like said. As long as you treat your tranny with respect and don't push over 280 lbs you will be fine. 280 is about all your engine is worth on pump gas anyway.
Does anyone know if the 2008 dual AVCS motor has full oil press. at the exh cam feed? Wagonkenny Built Motor Discussion 4 03-15-2010 12:55 PM
Does anyone know if the splitters on the STI fit 02/03 WRX Nettalp Interior & Exterior Modification 3 11-02-2005 02:22 AM
Does Anyone Know If the LSAT Has Changed? STI 2 NV Off-Topic 3 07-05-2005 04:05 PM
Does anyone know if the rear seats for a WRX wagon and a ... SC WRX Southern California Impreza Club Forum -- SCIC 0 03-14-2003 08:40 PM
Does anyone know if the manual tranny problems have been solved for 01? dandbest Normally Aspirated Powertrain 12 01-04-2001 08:58 AM
