![]() Texas Impreza Club Forum sponsored by Gillman Subaru Houston and Gillman Subaru San Antonio |
#1 |
NASIOC Manufacturer
We are happy to announce that we now have full time trained technicians to handle your service and repair needs for your Subaru Impreza, Legacy, Outback and Forester.
Available services include: Factory Recommended Maintenance (30K, 60K, 90K services) Air Conditioning Repair and Recharging Alignment (from Stock to Performance) Batteries Brakes Computer Diagnostics (including Check Engine lights scans and clears) Custom Wheels and Tires Electical Engine Rebuilds Fluids Change General Check Ups Oil Changes Tire Rotation and Balancing Transmission Service Tune Ups This is on top of our previously offered services such as performance part installation, suspension installations, etc. We also have extensive experience with repair and upgrades for the new WRX models, from boost controls and turbo updates to full suspension and brake installs. We are located in Rockwall, Texas, on the east side of the Dallas/Ft. Worth Metroplex. For price quotes on service and labor, you can contact us online at service@cobbtuning.com or by phone at 972-771-1555 (ask for Aaron). Regards, Aaron Lollar Cobb Tuning www.cobbtuning.com |
#2 |
How about DOT certification tests?
#3 |
NASIOC Manufacturer
Kevin,
If you mean State Inspection, if we did perform them, we'd only be able to do so for cars registered in Rockwall County. ![]() So unfortunately, no we do not do any State Inspections at this time. Thanks, Trey Cobb Tuning www.cobbtuning.com |
#4 |
Member#: 6085
Vehicle:02 WRX in work PSM |
I here you guys are the closest 4wheel dyno. How much is it to run? Just courious I don't even know if I want to make a special trip out there untill I get some more mods.
#5 |
Member#: 3187
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
As far as I know, Cobb doesn't have a 4 wheel dyno... I wouldn't worry about it too much. =)
-Bill |
#6 |
Last I heard the closest AWD Dyno was located in Atlanta, GA
Couldnt we disable the front axle... dyno the rear wheels then multiply that figure by 2??? Just thinking ![]() |
#7 |
Member#: 6085
Oops. I thought someone told me that at the rally-x two weeks ago. I know they said its somewhere in Dallas. I don't trust my butt dyno and would also like to see where to shift for max torque in each gear. I think that all changes with certin mods (intake, exahust, etc.)
#8 |
Member#: 3125
Vehicle:2001 Mustang Bullitt Black |
There's a 4 wheel dyno at APR in Alabama.
Rumor another shop in DFW has been looking into a 4 wheel setup. |
#9 |
Member#: 2823
TXIC
Vehicle:2000 BRP 2.5RS/'03 AW "cabrio" ///M w/SMG |
I hope you you meant just kidding kevin. if you disable the front drive, you'll free up some more power. Say you make 100 hp to all four. If you convert to 2wd you should see 110- 115 so by multiplying by two, you'd have the worlds only stock 2.5 with 220 hp. Wishful thinking but misleading none the less. Good try.
#10 |
I tried
#11 |
Member#: 6085
Sorry Aaron. I did'nt mean to get this thred off topic. I posted a topic about the 4-wheel dyno so put those replies there and it will be easy to follow. Thanks for the help.
#12 |
NASIOC Manufacturer
We can convert the cars to RWD to dyno test them on a 2WD dyno. Unfortunately, you don't multiply by 2 Kevin, but that would make for some impressive numbers. My little NA car would have been making 360HP to the wheels using that math.
It sure would be cool if someone in Texas got an AWD dyno, though, wouldn't it? ![]() Cheers, Trey Cobb Tuning www.cobbtuning.com |
#13 |
Under Heistiolean Discrete Mathematics:
Trey would have an 8.5 second Impreza... WOW! OK.. lets get back on topic... I just got quoted $375 for your 30K service... better than Huffines... what do you service? |
#14 |
Member#: 4531
Vehicle:2001 2.5 RS Sedan Silverthorne Metallic |
I think for a little peace of mind... knowing that people who know and love Subies would be working on my car. I would be willing to make that trip.. seriously.
(And while I was there.. scope out some parts and projects ) |
#15 |
Member#: 4383
TXIC
Vehicle:2007 yamaha/harley roadstar17\Sportster883R |
hey Trey!
What kind of services or discounts can you extend to my guys in Dallas or statewide for that matter(race Team)? I have 30 race drivers statewide. 1/3 are in the Dallas\ft worth area. Forrest Folwell Pres-Texas Subaru Motorsports [This message has been edited by ExchangeGuy (edited May 10, 2001).] |
#16 |
Guest
Member#:
according to Tim Powers, Subaru District Technical Operations Manager, if you convert over to FWD, you lose power. This cannot be an effective way to test on a dyno.
Also, on a side note...if the fuse, by some freak act of God, where to blow while you were running it, the car would jump foward at a very high rate of speed when the rear wheels engage. Just a little food for thought. ![]() |
#17 |
Member#: 2823
TXIC
Gus- Putting the fuse? Oh! On a 4EAT. I am assuming Cobb Tuning means converting it mechanicly, not just puting the fuse in to kill AWD in the auto. You can't do this on a 5 speed anyway.
[This message has been edited by rally kid (edited May 11, 2001).] |
#18 |
NASIOC Manufacturer
In regards to the Team Discount, we'll see what we can put together. I'm sure we can work out a deal to support you all that compete with your Subaru.
As for the dyno testing, we use this to determine gains/loses from modifications. Unless you put your exact configuration on an engine dyno, loses are going to be a fact of life. AWD, FWD, or RWD. Cheers, Trey Cobb Tuning www.cobbtuning.com |
#19 |
Member#: 2823
TXIC
Trey, I'm confused. Isn't "fudge-factor-free" wheel horse power more important in the real world that results from an engine dyno? I'd rather know how much power I'm puttin' down to the ground than just how much my engine is producing. I suspect engine dyno's are more for tuning than for benchmark numbers. Care to clarify?
