Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 11-11-2002, 08:08 PM   #1
willow
Member#: 29515
2002 wrx
Default Installed New Exhaust/Heat shield remove?
Can you guys/girls help me on this?
Well, I just installed greddy evo exhaust system two days ago. Now, it's making disturbing sound whenever I turn or accelerate hard. From my observation, I think it is coming from heat shield vibrating due to its contact with greddy's mid-pipe. Yes, I checked. Small portion of the Greddy's mid-pipe is completely touching that heat shield. What should I do? Should I remove or hammer that heat shield a little bit?
Your advise and comments will be very appreciated. Help. It's making me a little nervous.
willow is offline   Reply With Quote
Old 11-11-2002, 08:12 PM   #2
jcme262
Member#: 13694
remove it or grind contact area
jcme262 is offline   Reply With Quote
Old 11-11-2002, 08:12 PM   #3
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Heat shield
I would not remove the heat shield if at all possible. HTH
n2xlr8n is offline   Reply With Quote
Old 11-11-2002, 08:38 PM   #4
willow
Member#: 29515
2002 wrx
So, did anyone remove the heat-shield at the mid-pipe?
I mean, is it a regular or common thing to do when you up-grade your eshaust?
I think I installed it really well. Everything fit well except that heat shield.
Old 11-11-2002, 08:48 PM   #5
doogdog
Member#: 29308
2005 Outback XT LTD
Champagne Gold Opal
Default no problems here
put in my evo exhaust a few months ago and no problems, which way did you tighten the bolts? From the cat back or from the muffler to the cat? I had to play with the hangers a bit and when I tightened it up it pulled away from the heat shield. I tightened mine from the cat back.
doogdog is offline   Reply With Quote
Old 11-11-2002, 08:56 PM   #6
willow
Member#: 29515
2002 wrx
doogdog,
You mean there shouldn't be such problem expected from greddy evo for wrx? That is good to know. May be I installed mine not so well as I thought.
I tighten mine from catback to muffler. May be I should reinstalled it before I hammer or cut off anything.
I did not receive instruction sheet from my order. Can answer me a few question?
There is no need to reuse stock bolts and springs right? I didn't. I'm little worry if I did this wrong now.
thanks
Old 11-11-2002, 11:01 PM   #7
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
Lightbulb Heat Wrap
Wrap it with some heat wrap material. I wrapped my up pipe and down pipe all the way to the muffler.
fatray is offline   Reply With Quote
Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Tri-State Area Private Classifieds 14 02-28-2009 08:08 AM
(NYC)Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Engine/Power/Exhaust 13 01-07-2009 11:27 PM
Bad idea to remove exhaust heat shields? RoadTrippin Normally Aspirated Powertrain 6 04-27-2008 10:35 PM
If I remove an exhaust heat shield, the car will burst into flames TRUE OR FALSE kaisersouse General Community 9 10-10-2006 08:41 AM
Removal of exhaust heat shields, bad or no problem? lag Legacy Forum 28 10-28-2003 09:00 AM
