Old 11-11-2002, 08:50 PM   #1
team13
Member#: 29538
2000 Impreza 2.5
Unhappy Fuel Filter won't come off
This is my first time changing the fuel filter on my 2002 RS. I de-pressurized, made sure the car won't start, etc. but I can't yank off the hoses. I've pried, pulled as hard as possible, but they're only budging very slightly. (Yes, I took off the clamps.)
Any ideas on how to slip them off? Thanks.
team13 is offline   Reply With Quote
Old 11-11-2002, 09:16 PM   #2
en3d
Member#: 5238
GGA Black
get some bigger needle nose pliers and use some muscles.
en3d is offline   Reply With Quote
Old 11-11-2002, 09:58 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Get a knife. Split the hose at both ends and replace.
Either that or spray penetrating lube at the end.
Old 11-12-2002, 01:33 AM   #4
RugDoc2003
Member#: 3628
2005 Impreza WRX STi
grey
i don't know if this is quite the situation...
but with other hoses over metal tubes i've done this:
you take a flat head screwdriver and push on the edge of the tube towards the direction you want the tube to slip off... push a little and then go to the other side and do the same... eventually it starts to slip off...
hope that helps
rug
RugDoc2003 is offline   Reply With Quote
Old 11-12-2002, 09:02 AM   #5
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default it's a struggle
Yeah, I struggle with those every time.
You need to twist the hose. Once you are able to turn them, they will slip off. I have replaced Subaru fuel filters numerous times and every time it took a lot of effort. You have to be patient and keep twisting them until they give way.
vvk is offline   Reply With Quote
Old 11-15-2002, 02:43 AM   #6
Rajah
Member#: 362
2006 WRX STi
WRB / Gold
... and be very careful if you're using channel locks as they WILL tear up the hose. Fortunately, there is enough slack so that if you do screw up the ends, you can clip them off, and re-attatch .
If you think getting them off is hard, try putting unstretched hose back on!
Rajah is offline   Reply With Quote
Old 11-15-2002, 11:38 AM   #7
team13
Member#: 29538
2000 Impreza 2.5
Default Thanks, got them off.
The twist idea worked great, thanks for all the responses. Too late for the channel lock advice, I kinda wore through one of the hoses already.
Old 11-15-2002, 03:21 PM   #8
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Default Re: Fuel Filter won't come off
How exactly did you do this... dumb question?
snowone is offline   Reply With Quote
Old 11-15-2002, 03:24 PM   #9
team13
Member#: 29538
2000 Impreza 2.5
Default search
I did a search on this forum and found the answer. Pull out #11 fuse, then try to start the car, making sure it doesn't start.
Old 11-15-2002, 11:06 PM   #10
avk
Member#: 17252
'06 WX8
59E
To slide the hose off w/o damaging you can use an open 8mm wrench, fitting it around the pipe and pushing sideways on the hose end. Some "Liquid Wrench" may help too.
avk is offline   Reply With Quote
Wax won't come off again...Revisited MidRex Car Care & Detailing 4 10-27-2003 05:04 PM
Aarrg, my tranny won't come off. Wellhung Transmission (AT/MT) & Driveline 5 11-28-2002 07:45 PM
Tire won't come off ... Part 2 Loki Brakes, Steering & Suspension 10 02-25-2002 12:46 AM
Tire won't come off ... Loki Brakes, Steering & Suspension 6 02-09-2002 06:09 PM
Cap bolt just won't come off!! Need help! scooby5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2001 12:25 AM
