Old 11-13-2002, 07:18 PM   #1
John #555
Member#: 27651
Question possible to bypass cruise control button?
I do alot of fwy driving and am always annoyed by the fact everytime I start the car I have to turn on the Cruise Control.
Is there a way to have it connected all the time? I can probly put that button to better use anyway, like i/c spray?
Thanks in advance...
John #555 is offline   Reply With Quote
Old 11-14-2002, 12:59 AM   #2
John #555
Member#: 27651
anyone? ...
Old 11-14-2002, 01:29 AM   #3
interiot
Member#: 24212
Default me too
This is definitely on my list of wanted mods as well.
I haven't actually taken a look at it yet, but I assume (based on the other switches I've looked at) that there's a connector on the back that you can unplug, and that there will be two wires on it that connect when the button is pressed. And it's likely that permanently shorting these together will automatically activate the cruise control. Though this is a momentary switch, and the computer is expecting to be pressed for a short time and then let go of, so it's possible you'd need something a little fancier (eg. a microcontroller or the right combination of transistors).
The only reason I haven't worked on this sooner is that I'm trying to figure out why in god's name they put it there in the first place, eg. is there a good reason it should be left as is? There are other cars with this kind of switch, so presumably the engineers weren't loony. I'm guessing it has something to do with safety, but it's not like the car will instantly jump away from you if you accidently press the steering wheel controls, and you won't have any chance to fix the situation. Or perhaps there's some particularly odd set of circumstances, which, if that switch wasn't there, would likely cause damage/injury? I haven't come up with anything after several weeks of thought though.
interiot is offline   Reply With Quote
Old 11-14-2002, 02:45 AM   #4
John #555
Member#: 27651
Default Re: me too
Originally posted by interiot
...and the computer is expecting to be pressed for a short time and then let go of,...
That is the part I'm concerned with. Let me know what you find. I'm not much of an E-engineer
Thanks!
is there a type of relay that disconnects after short period? That's what I (we) need!
Old 11-14-2002, 02:50 AM   #5
interiot
Member#: 24212
I'm no EE either, but I'm pretty sure that it wouldn't hurt to just try the direct short trick. If it weren't so late, I'd go try it now... maybe after work tommorow.
Old 11-14-2002, 03:05 AM   #6
John #555
Member#: 27651
when testing be sure to start the car with the CC button pressed in, since that's what we're trying to emulate. I'll give it a try as well when i get a chance.
Old 11-14-2002, 03:43 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Its actually a designed saftey feature. So that you dont accidentily hit the cruise button and end up running into someone cause the car wont slow down when you let off the gas.
Just like how electric moonroofs require two pushes of the button to close.
Old 11-14-2002, 04:07 AM   #8
interiot
Member#: 24212
Okay, here's some dismantling pictures:
But John's right, you don't need to take it apart to test whether a plain short will work.
When you start the car with the CC button pressed, the CC stops working until you "reboot" the car, as if it detected an error condition with the switch and is ignoring it. So yeah, some sort of microcontroller or transistor configuration would be needed.
If on the remote chance that I get around to doing some microcontroller code for this sometime soon, I'll post it, and possibly send one or two programmed chips to people. It's a fairly simple thing though.
I've thought of at least one alternative, though it'd take a fair bit more microcontroller programming: have a little buzzer sound if you press the CC controls on the steering wheel when the button to the left hasn't been pressed. *shrug* Just an idea.
Old 11-14-2002, 02:28 PM   #9
John #555
Member#: 27651
Nice work, interiot!!! I agree... it seems it doesnt like if the CC button is pressed when starting the car, which means we can't just short the wires.
How about using a capacitor and relay to delay the short in the switch? (I cant remember exactly how everyting works. this is purely based on what i remember from college way back when ) I need some help here!
Btw, thanks for the pics. I've been looking for good intruction on getting to the buttons.
Old 11-16-2002, 04:23 PM   #10
John #555
Member#: 27651
Could someone provide wiring diagram/ pinout of the cruise control button? (one next to fog switch)
Thanks in advance.
Old 02-01-2003, 03:56 AM   #11
John #555
Member#: 27651
one more try...
Could anyone provide wiring diagram/pinout of the cruise control button?
mods, please move this to the electrical and lighting forum
Thanks.
Old 02-01-2003, 03:00 PM   #12
just one blunt
Member#: 28244
2003 WRX
i have no idea why this car has it but i have driven a few others that have this button , as well as a bunch without it.
just one blunt is offline   Reply With Quote
Old 02-01-2003, 04:04 PM   #13
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The right way to do this would be to have a circuit that senses the cruise control "ON" light not active, and after a delay of a second or two, makes a momentary contact to the switch to activate the cruise control system. This could be done with a fairly simple logic circuit (actually a transistor with the base on the cruise light wire might work), a 555 timer, and a small relay.
The interesting problem is making a way to disable the cruise control. You don't want it popping back on when you push the button to turn it off, and it is necessary to have a fail safe way to kill the system. I know the stalk switch, and the brake and clutch are supposed to disengage the cruise system, but the main switch is still a good idea to really disconnect the system.
Alan is offline   Reply With Quote
Old 02-02-2003, 12:27 AM   #14
John #555
Member#: 27651
could you think of a way to make the cruise control master switch turn on 0.5~1min after the ignition? It sounds simple enough but i'm not much of an EE. how does a capacitor work? that might provide enough delay...
Thanks for your input.
Cruise Control Button aakrusen Electrical & Lighting 27 02-09-2008 09:34 PM
My cruise control button no longer lights up wrx2k4blue Electrical & Lighting 10 03-14-2007 05:07 PM
Cruise Control Button Illumination Dead? Virusx86 Electrical & Lighting 6 03-27-2006 01:56 AM
Cruise control button not lighting up... AK*WRX*2004 Electrical & Lighting 5 01-17-2006 01:55 AM
('93-'01) Possible to add cruise control? Kyguy Impreza Forum 9 06-25-2003 02:27 PM
