Old 11-14-2002, 12:45 PM   #1
juztin180
Member#: 11804
Have a Nice Day? Need help choosing next mod
Well, I'm looking to do something else to the car.
Mod list so far is:
-18" SSR comps
-H&R springs
-3/16 mod
-Hacked air box
-TurboXS downpipe
-Catless 3" from DP to a magnaflow muffler
I'm wanting to get some more power, but I dont know where to look. Obvious choice I think would be an Uppipe, but how much will that give me. Ever since i put the exhaust on..I've been itching for more power.
What about a header? what kind of gains can I expect from that. Larger turbo? then I have to get new injectors, correct?
I want to stay around the $700-$800 area if possible
any ideas you guys have would be great
TIA
-Justin
02 Black WRX Sedan, 5spd
juztin180 is offline   Reply With Quote
Old 11-14-2002, 02:38 PM   #2
juztin180
Member#: 11804
nobody has any suggestions?
Old 11-14-2002, 02:55 PM   #3
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
chip?
Big_Hitter is offline   Reply With Quote
Old 11-14-2002, 02:58 PM   #4
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
turboXs mbc, samco turbo inlet hose, and an MRT uppipe, then go to a stage 2 chip from turboXs
hpracingwrx is offline   Reply With Quote
Old 11-14-2002, 03:32 PM   #5
NotoriousWRX
Member#: 9026
Up-pipe, MBC, Samco IC hoses and SAFC.
NotoriousWRX is offline   Reply With Quote
Old 11-14-2002, 04:09 PM   #6
Rich10
Member#: 14934
Best bang for your buck, buy a used TurboXS unichip (with harness and abc) in the "Private For Sale Classified" and have it mapped to Stage 2.
Rich10 is offline   Reply With Quote
Old 11-14-2002, 05:56 PM   #7
scoobieREX
Member#: 25008
orginially
founded by Germans...
If you haven't already done this get new tires....maybe even new rims in the process
scoobieREX is offline   Reply With Quote
Old 11-14-2002, 07:30 PM   #8
2.FIVEL
Member#: 23317
red, er blue, no black!!
No up-pipe yet? That'd be my next one...
2.FIVEL is offline   Reply With Quote
Old 11-15-2002, 01:46 AM   #9
juztin180
Member#: 11804
check mod list at the top
Old 11-15-2002, 11:06 AM   #10
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Upipe + unichip. Both can be found used and probably under $600 for both.
-Tom
trhoppe is offline   Reply With Quote
Old 11-15-2002, 11:58 AM   #11
Carlito2002WGN
Member#: 18914
2006 WRX
Black with some stuff
Post >
Umm...isn't Juztin running a good chance of destroying his stock up pipe? Especially now with a more open exhaust after the turbo? And, if his stock up pipe does take a crap, doesn't that mean the end of his turbo and then the end of his engine resulting in a very sad Juztin?
I would suggest an up pipe and U tec
If not those, then up pipe and suspension parts.
Oh and if you want more power instantly...put your stock wheels back on (or other light 16"s) with other tires of course
Carlito
Carlito2002WGN is offline   Reply With Quote
Old 11-15-2002, 12:24 PM   #12
Tuning Factory Inc.
Vendor
Member#: 3600
uppipe, new turbo, Unichip in that order. That's what I'd do.
Tuning Factory Inc. is offline   Reply With Quote
Old 11-15-2002, 12:26 PM   #13
jpaj88
Member#: 24719
Default Gauges
I can't believe no one said gauges yet. You have to get gauges before you start modding your car.
jpaj88 is offline   Reply With Quote
Old 11-15-2002, 04:48 PM   #14
juztin180
Member#: 11804
oh, sorry I do have guages. I have autometer lunar sereis boost and EGT guages
why go unichip instead of utec?
Old 11-15-2002, 05:10 PM   #15
Davenow
Member#: 23676
Default Unichip+your setup=300+HP
Because UTEC will be out of your price range of 600-700
I paid a lot for my used unichip and I paid 520. You should be able to find a unichip for under 500.
You will automatically be at stage 2 (get it mapped for it) and stage 2 is 303HP
Old 11-15-2002, 06:06 PM   #16
juztin180
Member#: 11804
that does sound good.
Other thing i was considering was the header/uppipe piece that is on www.wrxtuner.com
should this be done BEFORE the unichip?
Old 11-15-2002, 09:20 PM   #17
Z1 Performance
Member#: 9327
Skip the header..you are a long way from maxxing out the stock one.
You're at a bit of a crossroads, given that the idea is to buy stuff once, and get to retain it as you add future mods. At this point, I'd try ad figure out what you are going for....speed, handling, style, or a mix of all three. From there, figure out what you want the car to be power wise....a good highway car, a good stoplight to stoplight car, a good drag car, or a hybrid of all three (say, a mid 12 second car)...and obviously what factors into this the most is budget. If you want to end up with a powerful, reliable mid 12 second car (for example) that spools well, and has a nice broad powerband on the street and strip, you'll need a few things:
turbo, somehow ditch the factory induction hose, up-pipe, fuel (injectors, pump at a minimum), and a way to run it all (computer). I am aHUGE fan of the up-pipe, but am on the other side of the fence on it....while there is no doubt it is worthwhile, it's just that it it is time consuming to do (at least 2 hours, and ofte times upwards of 4.5 if the old pipe is stubborn (which they often are, as the Subaru hardware stinks). As such, we generally don't recommend it be done until you swap the turbo. This way, both are done at the same time, and the labor is economized a bit. If you are doing the work yourself, this may or may not matter much to you. In my eyes, the up-pipe is not a $200 miracle piece....it is a $200 (and up) pipe that costs you at least another $100-$300 to install...at that point, it gets to be a bit pricey, which is why we generally recommend it be done in conjunction with a turbo upgrade. Many here might differ with me, and thats perfectly fine.
A good electronic boost controller would do wonders for you at this point, though if you plan on some form of engine management (Utec for example), you might just want to wait, or get it now...since the Utec can also be used to control boost.
So, ask yourself this: what do I want to spend now, who si going to do the labor and or required tuning on the next mod. From there, the choice becomes much clearer.
Adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 11-16-2002, 01:02 AM   #18
juztin180
Member#: 11804
Thanks for the in depth reply. Just what i was looking for.
I was unsure of the header idea. I was thinking chip first.
The uppipe is not that big a deal, I can hopefully get the Jacksonville mod squad guys to help me with it for a case of beer in return(to be had AFTER the install )
I do want the car to be able to be driven easily ever day, as i've had it only 9 months and put 21k miles on it
I'd like it to be quick, where I dont have to fear running up against something I can't handle at a light, not that I usually race, but its nice to know its there. Mid 12s would be wonderful, but how would driveability be with a car that runs those times?
also, I'm weary of the stock tranny, as its been rebuilt once already. How much HP is safe? i've heard up to about 400hp.
I want the car to basically be an all around performer. Quick enough in a straight line, but even better in the curves with enough power to have fun at a track day.
Looks like so far i'm leaning towards uppipe and used unichip
Need Help In Next Mod SubieSky Legacy Forum 12 08-02-2005 11:57 AM
Help choosing next mod JRush Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 06-26-2004 01:02 PM
Need help choosing STi mods URABUSWRXSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-07-2004 02:09 AM
help choosing next mod thewhitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-03-2003 06:38 PM
Need help on next mod choice. jonmacs22 Mid Atlantic Impreza Club -- MAIC 10 04-03-2003 01:43 PM
