Closed Thread
Old 11-15-2002, 07:38 AM   #1
wrx_sti_ver4
Member#: 18906
1997 WRX STi Ver-4
Default air control valve
Does anyone know anything about the air control valve? My car starts idling at 1200rpm for no apparent reason. Then it'll go back to normal after I restart. I went to the dealer and was told that carbon builds up in there and one quick fix could be to clear it out with some carb cleaner so I tried that to no avail. I also checked on the price of a new one and it was over $200 for this tiny valve.
I posted in here because I assumed that the valve on the EJ20T was a little different.
Can anyone help?
Gary
wrx_sti_ver4 is offline
Old 11-15-2002, 07:41 AM   #2
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Default spring cleaning
There might be gunk built-up inside the idle-control-valve assembly. Try This:
Remove the throttle, then from it remove the ICV. It should just be 2 little screws, not too difficult. I did it on my car, not to hard. Clean out any junk in there its probably just giving the lil pistion(valve gizmo) a hard time moving and adjusting. Should take no more than 10-15min to get this part completely out of the car. Using carb cleaner would be ok i guess on that gunk, btw.
Jeffie
NavyBlueSubaru is offline
Old 11-15-2002, 07:48 AM   #3
wrx_sti_ver4
Member#: 18906
1997 WRX STi Ver-4
Default Re: spring cleaning
Jeffie
THANKS!!! I'll try that out and post the results...I really don't like the idea of spending $200+ on something I can fix.
Gary
Old 11-16-2002, 11:43 PM   #4
wrx_sti_ver4
Member#: 18906
1997 WRX STi Ver-4
Jeff,
did you mean that part on top of the throttle that you can adjust the idle with? it has some sort of magnet on the inside of it? i cleaned that and still had no luck...any other suggestions?
tia.
Gary
Old 12-23-2005, 12:36 PM   #5
stevo2234
Member#: 69853
2005 WRX
gold
sorry to bring up an old post but im having the same problem, where is the ICV located?
stevo2234 is offline
Old 12-23-2005, 01:07 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
From the Maintenance forum, a sticky thread on this subject-
http://forums.nasioc.com/forums/showthread.php?t=781242
Mulder is offline
Closed Thread
Idle air control valve circuit Hawk296 Service & Maintenance 20 03-08-2004 12:37 AM
Air Control Valve Hawk296 Service & Maintenance 3 02-23-2004 04:33 PM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 11:37 AM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
how to install O2 sensor, fuel filter and air control valve Suladed Service & Maintenance 4 11-11-2001 09:30 PM
