Old 11-15-2002, 05:33 PM   #1
ychan
Member#: 9418
2002 2.5rs
aspen white
Default MRT header back system for Subaru Impreza MY 02 RS (again)
i looked on the modifications, but i couldn't find this, and did a search, and looked on the threads of note-- anyhow i'm gonna install the MRT header's back on Sunday. can anybody please gimme a list of the tools that'll be needed for this? i really appreciate it. or if you could please gimme a link, taht's be great. tahnks alot. tae care.
-y
ychan is offline   Reply With Quote
Old 11-15-2002, 08:33 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
Jack, jack stands, a 14mm socket and extention, whatever size wrenches you need to bolt together the MRT system (14mm or 17mm). That's about it.
Break loose all the header-flange nuts, disconnect both O2 sensor harnesses, remove the support brace bolt, remove the mid-pipe and pre-muffler exhaust hangers, remove the header-flange nuts, lower the whole exhaust to the ground, then remove the two post-muffler exhaust hangers. Pull the old exhaust out from under the car.
Installation is the reverse of disassembly.
Julian is offline   Reply With Quote
Old 11-15-2002, 08:41 PM   #3
Keith Cournoyer
Member#: 16764
Default MRT Installation
Just A Heads Up! If the 2nd O2 sensor is the same as the 2001, then it won't be long enough to install. My O2 sensor was fried into the stock headers and I had to replace it, so I cut the old wire off the fried one and attached it to the new one. I then shrink wrapped the wire and zip tied it to the car, out of the way of hot exhaust pipes. Good Luck, you'll enjoy the header. Keith
Keith Cournoyer is offline   Reply With Quote
Old 11-16-2002, 12:33 AM   #4
Julian
Member#: 1182
MY00 RS
BRP
My O2 harness was long enough, I needed no splicing. Just follow the harness into the engine compartment. It'll be zip-tied to some other wiring just under the plenum box. Snip it, then you have long enough wires.
Old 11-16-2002, 12:34 AM   #5
wistful
Member#: 745
2004 STi
Java Black Pearl
what parts of OH you from?
Don
wistful is offline   Reply With Quote
Old 11-16-2002, 04:47 AM   #6
ychan
Member#: 9418
2002 2.5rs
aspen white
i'm from cleveland, but i go to OSU, so i'm currently in columbus.
i got that O2 sensor extension that's supposed to be a good fix for the CEL, any tips? thanks.
-y
Old 11-16-2002, 02:13 PM   #7
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Tell me what you think of the MRT header. I am thinking about getting it for my 02rs. (automatic)
DoctorNick is offline   Reply With Quote
Old 11-16-2002, 04:45 PM   #8
obyone
Member#: 16523
Just pay attention the next time I come to one of the meets......Don't know when that'll be.....probably one of these days.
obyone is offline   Reply With Quote
Old 11-16-2002, 05:26 PM   #9
ychan
Member#: 9418
2002 2.5rs
aspen white
i too was trying to get an opion on the MRT for an 02RS, but didn't get mucgh fedback. i went with whole MRT set-up. i got the dual-tip, which i think is pretty nasty looking. it looks so stock it's sweet. i'll let you know as soon as it goes on, whi8ch should be tomorrow. i'll also be putting in a crank pulley tomorrow, if i have time. ok, keep your fingers crossed for me guys i can't wait.
-y
Old 11-16-2002, 05:27 PM   #10
ychan
Member#: 9418
2002 2.5rs
aspen white
oh yeah, any tips on that O2 sensor? or a link? thanks.
-y
Old 11-17-2002, 09:33 AM   #11
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
should be an easy install. don't be alarmed if smoke starts pouring out the first time you start the car up. it's just burning off some paint and other gunk that's in the new parts.
froggert is offline   Reply With Quote
Old 11-17-2002, 05:09 PM   #12
ychan
Member#: 9418
2002 2.5rs
aspen white
ok, this should have been the easiest install... except i was sent a header-back system that didn't fit!!! the headers didn't fit! it was off by a 1/4 of an inch what a waste of a day off and money. i gotta send some emails, and get this straightened out. the muffelr is on though, which sounds great! but i want everything on... man, my life sucks right now.
-y
Old 11-18-2002, 11:45 AM   #13
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
...welcome to the wonderful world of aftermarket parts, where anything is possible.
always keep a dremel, a torch and a big-ass hammer around and you'll be in fine shape.
peter
slater is offline   Reply With Quote
Old 11-18-2002, 03:56 PM   #14
ychan
Member#: 9418
2002 2.5rs
aspen white
and a punching bag, right? i wrote an email, so it seems like the situation is gonna be taken care of. i've been waiting for so long to get this bad-boy on, i can't believe i have to wait longer.
-y
For Sale: Megan Coilovers for Subaru Impreza WRX 02-06 & 04 STi: $845 sonikdrift Suspension/Brakes/Handling 1 12-27-2006 07:30 PM
MRT Header back system Sharmin7 Normally Aspirated Powertrain 3 08-18-2004 06:31 PM
('93-'01) Went from 15.9 to 15.6 with MRT header back system and.... scootr Impreza Forum 2 06-13-2001 08:53 PM
Just got back from a 50 mile test drive of my MRT header back system. scootr Normally Aspirated Powertrain 1 06-12-2001 09:57 AM
Where can I get the MRT header back system? 96Lconversion Normally Aspirated Powertrain 3 04-25-2001 02:22 PM
