South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 11-15-2002, 07:21 PM   #1
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Question Autocross tire and rim decision help
Iím contemplating getting 15" rims for autocross fitted with Azenis. For comparison how do you think the grip would compare with my current setup? Right now I have 18x7.5 around 21lb. with Parada Spec. II 225/40/18, I would be switching too 96 legacy 15 inch alloys with a 205/50/15 Azenis?
Thanks
Burnout is offline   Reply With Quote
Old 11-15-2002, 09:57 PM   #2
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
That would improve your gearing a bit, giving you a little better acceleration. Plus I think the grip on those would be noticeably improved over what you have...but that's my opinion.
Hopefully some of the experts here in the SE will give their opinions too...
DrBiggly is offline   Reply With Quote
Old 11-15-2002, 10:21 PM   #3
silverscooby
Member#: 15060
Dude, get the new Niche Orca rims. They come in 22" and they only weigh 30 plus pounds. Plus they're chrome so you could blind the other guys with your bling bling!
Good luck with your tire choice man and go kick some tail!
silverscooby is offline   Reply With Quote
Old 11-15-2002, 10:55 PM   #4
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
You'll DEFINITELY notice a difference in acceleration due to the gearing changes (and lower polar moment of inertia (ie. the weight is closer to the center)) This will give you an advantage on any course where you can stay in 2nd with the smaller tires as you have better acceleration the entire time. This increase is negated (maybe even to being a slight detriment) if you get to a course that requires you to shift to 3rd and others can hold 2nd, though.
I ran 195/50-15 S-03s (on 15x6 Legacy alloys) on my car this season (except for a few races toward the end of the season when I ran 205/50-15 Azenii) and while my tire size will be changing for next season, I'm definitely planning to stay with the smaller than stock sizing concept.
Shane -- http://www.warpthree.com
Warp3 is offline   Reply With Quote
Old 11-15-2002, 11:29 PM   #5
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
I was thinking it might make my gears a little bit smaller. On the courses I drive on now I hit third for a couple of seconds.
Do you think the grip level would be same or even better? And going smaller tire could I still be in STS?
Old 11-15-2002, 11:32 PM   #6
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I think you would have more grip due to the tire change. Plus you would have more acceleration due to the wheel size change.
Old 11-15-2002, 11:55 PM   #7
Fred
Member#: 3560
06 STi, 02 STi
06 FXT, 94 rally car
I'm going with 17X7.5 next year - subzeroes and azenis. I'm not too fond of upshifting to / downshifting from 3rd gear that much. If I start feeling like I'd be better off the other way, I'll switch and let them be my street wheels and the stock wheels be my autox wheels. I wouldn't want to go with 15" wheels, though. Trying to keep it as simple as possible for the first year.
Got a question for the brainiacs - how much contact patch would you give up by decreasing the diameter & width of the wheel? Would that cancel out the (slightly) quicker acceleration? It seems to me that you'd want to maximize the grip, instead of going for acceleration...
Fred is offline   Reply With Quote
Old 11-16-2002, 01:09 AM   #8
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
This was my main concern, cause I was thinking thatís quite a difference in size. The plus with running with the 15's is the coast, it's only $63 a tire or 252 a set, rather than buying new tires for my rims now that are around 141 apiece. That right thereís almost worth it.
Kevin I was just browsing through the vender GB forum and came across these Attacks http://forums.nasioc.com/forums/show...readid=275674, nice looking wheels and price. I think they weigh the same as the subzero's also.
Old 11-16-2002, 09:25 AM   #9
Fred
Member#: 3560
06 STi, 02 STi
Yeah, I don't like those. Thanks for the link, though.
I think the price difference on 215/45/16 vs. 225/45/17 is around $40/ set of 4 Azenis. Big jump from 205/55/16, though...
Old 11-16-2002, 12:22 PM   #10
Evegan
Member#: 16578
2000 Outback - 89E30
2003 NCAC DSP Champ
Hmm, anyone know of a 15x7 or 15x8 wheels that'll fit subarus? I run in DSP (maybe SM next year) and would love to find a set of smaller wider rims. Maybe put some hoosiers on them, I don't know. Any ideas?
Evan
Evegan is offline   Reply With Quote
Old 11-16-2002, 06:03 PM   #11
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
This depends entirely on the courses in your area.
I ran 16" the for 2 years and then switched to 15" last year, I am now back to running the 16". If you run only short, technical courses the smaller size will help you because of the increased acceleration.
If you constantly run courses (like I do) that are faster courses requiring top of 2nd and/or 3rd gear you will be having to change gear so often that many times you will end up losing time.
Opie is offline   Reply With Quote
Old 11-17-2002, 01:31 PM   #12
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
True, but you don't HAVE to decrease the width of the wheel just because you drop diameters (though it's harder to find wide small wheels). I mean you could always run a 15x7.5" Volk TE37 with 225/50-15s if you wanted (which I would in a heartbeat, if I had the cash).
The only reason I ran the 195/50-15 and 15x6 combo was availability and price. Since it looks like I'll be picking up your RS rims (16x7), I'm probably going to run a 205/45-16 or 225/45-16 next season, instead.
And, yes, 15s are a LOT cheaper than 16s or 17s. That's another plus for going that route.
STS 729
Old 11-17-2002, 02:23 PM   #13
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
This is the main reason Iím thinking of going with a 15.
I also run at the track and believe I could probably drop three tenths just by loosing the weight and the shorter gearing of the combo, maybe even a little bit more.
What is the diameter difference between the 225/40/18 and the 205/50/15?
Dedicated autocross tires and for autocross only. cid369 Tire & Wheel 16 01-11-2012 09:43 PM
I'm going to be getting tires and rims in next 2 weeks *help* blackout801 Rocky Mountains Impreza Club Forum -- RMIC 7 08-31-2008 08:12 PM
Autocross tires and rims CNC Scott Tire & Wheel 18 08-14-2007 04:55 PM
Help me get tires and rims!!! seasons Tire & Wheel 9 05-17-2004 08:47 PM
need help on tires and rims WReX_rated Bay Area Impreza Club Forum -- BAIC 11 08-16-2002 07:59 PM
