Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 11-17-2002, 06:09 PM   #1
keithja
Member#: 29983
2003 WRX
Default Socket size for a tranny and rear end fluid change/fluid question too
Hi,
I am going to perform a tranny and rear end fuild changes. The vehicle is a 2003 WRX and I live in the USA.
What size socket is needed? Any brand oil pump recommended for the rear end?
I have also narrowed down my fluid choices to:
-Redline 75W90NS for the tranny and 75W90 for the rear end OR
-Royal Purple Max-Gear for both the tranny and rear end.
Snookem did alot of research and ended up liking Royal Purple. Any other opinions?
Snookem's negatives on Redline were that he had not data sheet that said it was OK with bronze synchos plus several negative reports (or at least confusing reports from users). Any thoughts?
I know the fluid thing is old turf, but after reading all the threads I am still pretty confused.
Thanks in advance, Keith
keithja is offline   Reply With Quote
Old 11-17-2002, 06:17 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
22mm socket for the drainplug on the trans a 1/2" extension and ratchet for the rear end.
jeremy
FWIW you are going to get grinding if you use Redline or any synthetic in the trans.
Old 11-17-2002, 06:18 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
I'm using Redline in my tranny and rear diff and have never gotten grinding. Been using it for about 6000 miles now.
Calvin
cnk is offline   Reply With Quote
Old 11-17-2002, 09:47 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Jeremy probably just missed the 75W90NS above. Redline fluids with the NS are non-synthetic.
Note, I do get grinding on NS fluid, but I think it's the way the dealership crappily rebuilt my transmission.
Old 11-17-2002, 10:04 PM   #5
cnk
Member#: 10757
75W90NS is synthetic. The NS only indicates that it doesn't have friction modifiers. Per the Redline Oil website:
75W90 NS - a GL-5 which does not contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting. Can also be used in racing limited-slip differentials where weak spring design causes too much wheel spin.
Calvin
Old 11-18-2002, 01:36 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
how dare you wait till you get about 10k-15k on it.
jeremy
Old 11-18-2002, 08:08 AM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I plan on doing the same thing this week. Do you know how many quarts are need for the tranny? I'm assumming just one will do it for the rear diff. I've never done either change myself, so any tips, hints, or instructions anyone wants to pass along?
Thanks
Old 11-18-2002, 11:39 AM   #8
tuca33
Member#: 24303
2002 Impreza WRX
Question
Is it really worth to change the tranny fluid??
what are the benefits??
and about brake and other fluids??
should i chankge them?
Thanks
Tuca
tuca33 is offline   Reply With Quote
Old 11-18-2002, 03:33 PM   #9
BlkRexWagon
Member#: 20587
'02 WRX Wagon
Midnight Black
Hey guys, I was wondering if those of you who changed the tranny/diff fluids did so for improved reliability/longevity or for a performance enhancement? I was thinking of changing mine, but it would only be because I plan on having this car for a looooong time and would like to protect my investment. Thanks!
BlkRexWagon is offline   Reply With Quote
Old 11-18-2002, 05:21 PM   #10
keithja
Member#: 29983
2003 WRX
Default Going to DOT 5 Brake Fluid would be another change
that could be considered. Is the WRX brake system DOT 5 compatible?
Old 11-19-2002, 02:41 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Default Re: Going to DOT 5 Brake Fluid would be another change
dot 5 no, dot 5.1 yes....look in the suspension/brakes/tires forum, there's a good post about brake fluids by 8complex.
jeremy
Old 11-19-2002, 09:53 AM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Was rebuilt around 29k... I have about 44k on it now. Still sucks arse.
Here is that brake fluid post, BTW... http://forums.nasioc.com/forums/show...hreadid=159647
Old 11-19-2002, 01:04 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
that's cause of the morons that rebuilt yours
Old 11-19-2002, 06:06 PM   #14
rotorbaru
Member#: 22493
2003 Impreza WRX
Silver Cobb stg 2
To get back on topic,
I put redline light weight shock proof in my trans and rear diff.
I can't tell any difference on the rear differencial but the transmission definately shifts smoother now with no grinding - so far I recommend it. Cobb has a right up on fluids, he recommends ultra light weight shockproof if you go with shock-proof, but I had light weight and it seems to work fine.
I have seen a racing transmission rebuilt that had shock-proof used in it, the stuff is amazing how well it clings to metal.
BTW does anyone else get a faint gear whine from the rear end (I think) when doing 60 mph and the drive line isn't under any load, i.e. between on throttle and off throttle? I got gear whine with the original oil too.
rotorbaru is offline   Reply With Quote
Old 11-19-2002, 06:40 PM   #15
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
can't wait to hear what hndatch has to say about this
Also, the tranny holds 3.7 US quarts. Tighten the drain plug to 33 ft/lbs.
The rear diff hold 0.8 US quarts. Tighten the filler and drain plugs to 36 ft/lbs.
Steppin Razor is offline   Reply With Quote
Old 11-19-2002, 07:26 PM   #16
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
I'm still a little confused here - so which brand/weight is best exactly?
Red line?
Should I ask for tranny fluid specifically or do I just go to pep boys and buy oil?
BeavisNuke is offline   Reply With Quote
Old 11-19-2002, 07:35 PM   #17
cnk
Member#: 10757
You'll get different opinions. I'm using Redline 75W90NS in the tranny and 75W90 in the rear diff.
Calvin
Old 11-19-2002, 07:40 PM   #18
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
As far as I can tell, almost everyone will agree that Redline 75w90 is the way to go in the rear diff.
As far as tranny fluid goes, it's still up in the air. What's the diff between Redline's superlightweight shockproof and their 75w90NS?
Old 11-20-2002, 08:35 AM   #19
rotorbaru
Member#: 22493
2003 Impreza WRX
Silver Cobb stg 2
[As far as tranny fluid goes, it's still up in the air. What's the diff between Redline's superlightweight shockproof and their 75w90NS?]
You may want to go to Redlines website to read about the exact difference between superlightweight shock proof and 75W90NS.
I can tell you I know shockproof has special additives to cling to the metal parts, so basically everything is always coated with oil - even after sitting for weeks! Shockproof aslo has friction modifiers added so it is say to use with limited slip differentials.
According to Redline, light weight shook proof has the equivalent shock protection of a 75W140 oil with having the thickness of a heavy oil.
If someone can come up with definate proof of why this isn't good stuff to use (besides being real expensive) I am willing to hear it, until them I am sticking with the shockproof!
(Besides, most transmission failures you hear about here on I-club come from shockloading, i.e. 5k+ rpm then clutch drop, what better than shockproof to prevent that)
Old 11-20-2002, 09:40 AM   #20
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
There are a few of us in this area that put in the Redline Ultralight Shockproof at one time. I've got 10-15k miles on the car since then and it shifts perfectly fine. It was definitely smoother after doing the MT swap from the old stuff. I'd probably use the lightweight as opposed to the ultralight though if I change it again. For the rear diff just use regular Redline 75W90. There are lots of thread in the _transmission_ forum discussing these things.
Phil
Old 11-20-2002, 09:48 AM   #21
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
I haven't hand any problems with grinding and all in my car since I put in Redline MT-90... however I haven't really driven it too hard, just got the clutch broke in this morning.
Off Topic
Speaking of clutch break in... I've never heard of a break in period for most other vehicles when replacing a clutch... why the heck are these so different??
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 11-20-2002, 09:56 AM   #22
BlkRexWagon
Member#: 20587
'02 WRX Wagon
Midnight Black
[i]
Off Topic
Thanks - Jon [/b]
I have had friends replace clutches in everything from VW Rabbits to V8 Firebirds and they have all had a break-in period for the new clutch. I would assume it depends on the clutch manufacturer, but we all know what assuming does
Old 11-20-2002, 10:52 PM   #23
tuca33
Member#: 24303
2002 Impreza WRX
So,,my car is 1000 miles and i dont know if i change those oils now,,or wait a little longer..
i will change my engine oil with 1500miles..
Thanks
Tuca
FS - 02 WRX Tranny and Rear end theformula175789 MWSOC Private Classifieds 10 07-10-2006 12:33 PM
Tranny & Rear End Oil Change modest1 Transmission (AT/MT) & Driveline 5 06-13-2006 07:39 PM
FS: '02 WRX Complete tranny and rear-end theformula175789 Mid West Subaru Owners Club Forum -- MWSOC 1 08-25-2005 08:49 PM
FS: [NY] WRX tranny and rear end ScreaminFast Private 'For Sale' Classifieds 14 05-09-2005 01:58 PM
sti motor, tranny, and rear end part out wrxben Private 'For Sale' Classifieds 34 09-21-2004 09:48 AM
