Old 11-17-2002, 09:15 PM   #1
Avenger
Member#: 1234
Default HKS wastegate problem
I got a HKS standard wastegate and I can't seem to get the right amount of boost from it. I've changed the spring already but it still reads 10 pound of boost when I go WOT. Any idea what else I could do? Thanks.
BTW I'm reading it from an autometer gauge that is tee from my BOV line.
Avenger is offline   Reply With Quote
Old 11-18-2002, 02:08 AM   #2
Aspen
Member#: 145
Banned to
Housework for Summer
It would help if you told us what spring tension you have.
Aspen is offline   Reply With Quote
Old 11-18-2002, 11:04 AM   #3
Avenger
Member#: 1234
It is a 5.7 psi spring.
Old 11-18-2002, 03:26 PM   #4
Aspen
Member#: 145
Banned to
You should have two ports on your wastegate. Make sure you are only using the side one and leave the top one alone unless you are using a boost controller, which then you want to tap into the top port with.
Also, verify your spring color is white.
Old 11-18-2002, 09:30 PM   #5
Avenger
Member#: 1234
Yes the spring is white. Right now I got the side port connected to the turbo (in between turbo and throttle plate) and the top port connected to the intake manifold after the throttle plate.
So I just remove the top, or do I have the connection wrong?
Thanks
Old 11-18-2002, 11:22 PM   #6
Aspen
Member#: 145
Banned to
Just remove the top and you should be good to go.
Old 11-19-2002, 12:54 AM   #7
Avenger
Member#: 1234
Thanks! I can finally go WOT with out worrying too much now.
Old 11-20-2002, 12:44 AM   #8
Aspen
Member#: 145
Banned to
no problemo. This is a common mistake on the HKS and Tial units...
50mm HKS wastegate fs jdmworx Private 'For Sale' Classifieds 0 03-30-2006 11:53 PM
Some items on eBay, HKS wastegate, Turbonetics, Standalone EMS rebo0t Private 'For Sale' Classifieds 4 02-17-2006 02:11 PM
40mm HKS wastegate mdcmotorsports Private 'For Sale' Classifieds 1 12-14-2005 08:05 PM
Need help with HKS wastegate problem rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-22-2002 12:34 PM
HKS wastegate Avenger Normally Aspirated with bolt-on Forced Induction Powertrain 17 12-26-2001 12:30 PM
