Old 11-18-2002, 01:13 AM   #1
sperry
Member#: 8636
WRX, OBXT, NA Miata,
F250SD, no more SVX :(
Default Busted Ground Wire Behind Intercooler
Woops!
During my Vishnu Stage 0 install, I broke the grounding wire that attaches to the bolt on the firewall behind the intercooler. The problem is that I can't figure out what the other end connects to! Anyone know where the other end of this wire goes?
Also, what kinda effect will this have on my car? ...so far I haven't really noticed anthing... but then again, I did the "grounding mod" already, so it's not like I'm short on grounding wires....
I just figure I should fix it.
Thanks!
--Scott
sperry is online now   Reply With Quote
Old 11-18-2002, 01:33 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
it's connected directly to the top of the transmission casing, i completely forgot about it when i did a clutch job, just took a lil re-working to fix it.
jeremy
Old 11-18-2002, 03:35 AM   #3
sperry
Member#: 8636
Thanks man!
Looks like I'll have to bust out the jack and git my wiring on.
--Scott
Power Wire as Ground Wire? Inprogress Car Audio, Video & Security 12 04-07-2006 02:29 PM
Solution for Web of Wires Behind Computer? caseynsb Off-Topic 33 12-01-2005 08:32 PM
Drain Valve wiring behind Right Rear tire... beege_mi Normally Aspirated Powertrain 0 05-27-2005 10:13 AM
Loose wires behind the fuse panel ivrep Electrical & Lighting 4 02-06-2004 08:29 PM
How to get to the cig lighter wires behind console? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-01-2002 09:44 PM
