Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 11-18-2002, 04:27 PM   #1
Schleppy
Member#: 15858
SPB
Default Are there really big differences in the various rear endlinks?
Well, I have a rear sway bar in, and I love it, it just kicks in a little late. Enter the aftermarket rear end links...
Now, as much as I would love to support Kartboy, and as solid as their rear endlink looks, do I really need to shell out $100 for it or will teh $50 MRT one work just as well?
Thanks a lot!
-Sean
Schleppy is offline   Reply With Quote
Old 11-18-2002, 04:34 PM   #2
nqwan
Member#: 2916
02 duburu arr exu
buy the kartboy! he'll give you candy too
nqwan is offline   Reply With Quote
Old 11-18-2002, 04:50 PM   #3
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
The Kartboy ones just look much more solid. At least one person here reported about an MRT endlink breaking. That might very well be an isolated freak incident, but when I saw the pictures of those beautiful Kartboy links, I decided that I would buy upgraded endlinks only once, and spend the money for the best. If they're worth $50 more than the MRT ones is really your call.
And yes, don't forget about the free candy! And they might still have free Kartboy t-shirts if you order enough of their stuff at once.
TheWRX is offline   Reply With Quote
Old 11-18-2002, 06:31 PM   #4
Schleppy
Member#: 15858
SPB
Damnit! Quit making me want to spend $100 :-D
Anyone have a used set they want to let go of?
Old 11-18-2002, 07:33 PM   #5
iloveturbos
Member#: 22868
MBP
i have the kartboy ones, and even though theyre some thick ol' endlinks, when i held them in my hand, i thought to myself, "these are $100?"
ive read a few incidents of the whiteline ones breaking on here, and the kartboy ones just looked great compared to them. good luck!
iloveturbos is offline   Reply With Quote
Old 11-18-2002, 09:09 PM   #6
Dolphin Overton
Member#: 1925
the Mrt/whiteline's break... they look like noodles too.
Dolphin Overton is offline   Reply With Quote
Old 11-18-2002, 10:59 PM   #7
tdxflex
Member#: 13634
mrt makes a different rear alloy endlink, they're around $100, anodized blue. you can check them out at vivid. i would probably go with kartboys because i read somewhere that they offer better clearance for lowered cars because they're a little shorter than stock.
tdxflex is offline   Reply With Quote
Old 11-19-2002, 02:46 AM   #8
Kostamojen
Member#: 2272
2013 Subaru 599 :P
Galaxy Blue Sexy
I know, its alot of money I was torn paying so much for something so little since I dont have much in the way of moding money... They were well worth it though, really smoothed and straighted out the rear of the car, and it was VERY much worth it for autocrossing.
Old 11-19-2002, 08:55 AM   #9
scoobygator
Member#: 11549
2002 WRX Sedan
World Rally Blue
Kartboy....worth every penny.
Scoobygator
scoobygator is offline   Reply With Quote
Old 11-19-2002, 10:19 AM   #10
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
djerickd is offline   Reply With Quote
Old 11-19-2002, 02:42 PM   #11
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Whitelines are fine IF you keep the bar at 22mm or less. If you have stock springs and 24mm bar you risk breaking the endlinks or ripping out the frame swaybar mounts.
If you are hardcore, get the Kartboy or Revlab links. If not, might as well save the $100 for some other STi tidbit.
linsavy is offline   Reply With Quote
Old 11-19-2002, 03:56 PM   #12
Schleppy
Member#: 15858
SPB
I think that i am just going to go for the Kartboy pieces. I am at 22mm right now with an MRT rear sway, and I have aftermarket springs...
I'll just track down a set and buy those...
Thanks all!
Old 11-19-2002, 04:09 PM   #13
aov
Member#: 7193
MY02 WRX
I have the Whiteline links and managed to break one. I was running a 22mm front bar and the rear bar set at 24mm. I sent my end link back to the vendor and received a new one back within 2 days free of charge.
I am currently running the stock front bar and the same rear setup and have had no problems.
If it is possible to rip out the stock sway bar mounts I would think this would be more likely with a stiffer set of end links?! I'd rather have the end link go (and have it replaced for free), than have the stock mount rip out.
That said, I'm sure the Kartboy ones are stiffer... but, I haven't tried them so I don't know how much difference there is.
-anders
aov is offline   Reply With Quote
Old 11-19-2002, 06:40 PM   #14
Schleppy
Member#: 15858
SPB
Good question! Will the solid endlinks cause the mounts themselves to break? That would REALLY suck...
Anyone care to shed a little light on this? Anyone from Kartboy?
Old 11-19-2002, 09:04 PM   #15
Fmdeadrick
Member#: 200
1999 Impreza 2.5RS
The lower mount on the front control arm of the WRX Sedan would be the weakest link, I suppose. But, the most likely failure would be the cantilevered bolt, mounting the upper to the bar of either the front or the rear. I think the stock front bar is fairly larger than the stock rear, but a very large aftermarket bar on the rear could surpass that. I think some of the competitors links have had failures in their supplied bolts. This could probably remedied with some higher quality bolts.
Mark
Fmdeadrick is offline   Reply With Quote
Old 11-19-2002, 11:19 PM   #16
doppelganger
Member#: 23007
Mark
Mark,
Everyone is blessing your endlinks!!! They sound great. How about a "hurray for Kartboy forum sale!" Hey, it was worth a shot.
doppelganger is offline   Reply With Quote
Are there any cars sold in the US now that are under 3000lbs? RaceCarRiot Off-Topic 93 05-05-2008 10:46 PM
Is it me or are there more WRXs out in the Tri-state? HoOn Tri-State Area Forum 15 06-27-2004 09:02 PM
Is there a big difference in up-pipes? MikalsWRX Newbies & FAQs 18 05-04-2004 07:20 PM
Why are there so many Subies in the tri-state? slippers2k Tri-State Area Forum 12 05-20-2003 05:02 PM
Is there a big difference between the Vishnu Stage 1 & 2? ChrisWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-24-2002 12:05 PM
