Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Vancouver Impreza Club
Old 11-18-2002, 07:52 PM   #1
Funfun
Member#: 13087
blue
Default Change spark plug
Anyone know how to change spark plugs in MY02 Turbo engine?
Funfun is offline   Reply With Quote
Old 11-18-2002, 10:27 PM   #2
Avenger
Member#: 1234
Pull the spark plug wires out of the engine then remove the sparkplug with the spark plug socket. On the driverside you'll need to remove the washer bottle first.
Avenger is offline   Reply With Quote
Old 11-19-2002, 04:21 AM   #3
Funfun
Member#: 13087
blue
I can't see the connector of the sparkplug wire from the engine. Do I need to remove something out first?
Old 11-19-2002, 10:55 AM   #4
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Default Re: Change spark plug
I don't.. but I bet its funfun.
Mirage is offline   Reply With Quote
Old 11-19-2002, 12:04 PM   #5
Avenger
Member#: 1234
There should be a black square unit on top of your intake manifold with 4 black wires running out of it. Follow these wires to the engine, then take out the wire from the engine pulling only on the big rubber piece, do not pull on the wire.
Old 11-21-2002, 04:54 AM   #6
Funfun
Member#: 13087
blue
I'll try it. Thanks alot.
Old 11-21-2002, 05:00 AM   #7
imprezive one
Member#: 16906
2k3 wrx wagon
just to warn you, it's a PITA to get the passenger side ones changed. There's barely enough room for you to work or put a tool down there. It's not impossible though, just be patient and don't get careless. Make sure you reconnect everything in the right order also!
imprezive one is offline   Reply With Quote
Old 11-21-2002, 05:01 AM   #8
imprezive one
Member#: 16906
2k3 wrx wagon
whoops, I meant driver's side, I thought I was in japan for a minute there, heh heh.
Old 11-21-2002, 03:25 PM   #9
Avenger
Member#: 1234
That is why you remove the washer bottle.
Old 11-30-2002, 08:11 AM   #10
Crash's WReX
Member#: 26265
2002 WRX Wagon
Default Drivers side plugs
I am trying to change plugs today, and I am not able to get at the rear driver's side plugs. I removed the battery and the windshield washer tank, but the rear drivers side plug seems practically against the engine compartment, like I can get a socket in there, but can't get a socket wrench on it.
Any suggestions?
Crash
Crash's WReX is offline   Reply With Quote
Old 11-30-2002, 03:07 PM   #11
Avenger
Member#: 1234
Default Re: Drivers side plugs
Any suggestions?
Crash
Try fitting a swivel joint onto the sparkplug socket and see if you can get it at a different angle instead of straight on.
Old 11-30-2002, 06:55 PM   #12
imprezive one
Member#: 16906
2k3 wrx wagon
I just did a circus act contorting my hand/arm/socket wrench to fit in there and did like a 1/10 turn each time... it was really tedious but it worked? I dunno maybe your hands are bigger than mine.
Old 12-01-2002, 05:42 AM   #13
Crash's WReX
Member#: 26265
2002 WRX Wagon
Thanks for the advice. I bought a smaller extension and will try again with more patience (nothing like spending an hour or so trying to change a couple spark plugs....)
Peace,
Crash
Changing spark plugs...need to change all 4? jester696 Service & Maintenance 6 12-22-2008 09:10 PM
Trying to change spark plugs - can't get socket on plug winston856 Service & Maintenance 5 03-18-2008 06:42 PM
changing spark plugs? racerwad Newbies & FAQs 7 10-23-2000 07:47 PM
When did everyone first change spark plugs? SubieRacer Technical Forum Archive 19 05-27-2000 08:38 PM
At what engine temp to change spark plugs?? Dan00RS Technical Forum Archive 5 05-12-2000 01:52 AM
