![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 17939
Vehicle:2002 WRX Sedan Blue |
Friend and I were working on his WRX, adding the Stoptech big brake kit, and I made the mistake of letting him do some of the work himself...he ignored the torque wrench and kept going, snapping off a banjo bolt in one of his nice new calipers. I tried to vise grip out the stub, but it is in there hard. Any ideas? Thanks.
#2 | |
Member#: 8945
TXIC
Vehicle:MY02 WRX Blue |
#3 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
i've never used an easy-out but from what i hear they're kind of brittle. for speed bleeders it's recommended you drill a hole, then lightly hammer in an allen key in the middle and try to twist it out, if it strips, go up a size drill bit and allen key.
#4 |
Member#: 17939
I'm nervous about putting a drill into this bolt as chips could easily fall into the caliper, causing some problem. I will look into this easy out thing.
#5 | |
Member#: 8945
TXIC
#6 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed |
banjo bolt Ive seen already has a hole through it. Did it break off low enough to get to the hole in the bolt? If so an easy out (or bolt extractor) is the way to go. It is agressively reverse threaded so it tightens into the bolt counterclockwise and tries to break the blot shaft loose. Of course, there shouldnt be much resistance to the bolt shaft coming back out anyway as I assume it was recently loose and not seized in place.
On a side note, invest in a torque wrench. HTH ss |
#7 |
Member#: 4374
Vehicle:06 Titan,99,94 SM 06 nasa spec miata champ |
dont banjo bolts already have a hole in the middle?
or did it snap off above where the hole ends |
| Thread Tools | |
| Display Modes | |
| HELP!!!! - Need Banjo Bolt in Rockville MD | kumanchu | Mid Atlantic Impreza Club -- MAIC | 3 | 04-27-2009 12:59 PM |
| i need a wrx power steering pump banjo bolt in MKE asap | scobaru | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 09-24-2007 01:19 AM |
| Stripped banjo bolt hole in brake caliper? Fix it!!! | thrdeye | Brakes, Steering & Suspension | 0 | 10-14-2005 03:10 PM |
| What size washers do I need for banjo bolts on brake caliper? | thrdeye | South East Region Forum | 27 | 10-14-2005 01:15 AM |
| Stock Banjo bolt same as Stoptech Banjo bolt? | mav1c | Tire & Wheel | 3 | 11-22-2004 10:15 AM |
