Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 11-19-2002, 01:16 AM   #1
WillysPU
Member#: 25994
2003 WRX wrb stage 4
What would Scooby do?
Question Newbie Needs Springs Installed
Hi BAIC list,
I am the proud owner of an 03 WC Blue WRX. I have been lurking on the site for about a week or so trying to absorb as much as possible.
I can do most installs, but my wife refuses to let me do a spring install due to the many horror stores resulting from exploding struts/springs.
So, can anyone recommend an installer along the Penninsula (Milbrea to Sunnyvale) that could do the install and alignment?
I haven't bought the springs yet as many installers appreciate selling the product and installing.
Thanks in advance!
ps: I have noticed a few requests for installers, maybe we could start a thread on preferred installers.
WillysPU is offline   Reply With Quote
Old 11-19-2002, 02:35 AM   #2
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
Bill and Chris from I-speed should be able to help you out for a nominal fee (or beer and eye candy) I'm sure they'll chime in shortly.
Otherwise, I've had good experience at RedStar racing in Hayward. Sounds like it might be a little far, but worth the drive to watch those crazy fools work
Dan_E is offline   Reply With Quote
Old 11-19-2002, 01:06 PM   #3
WillysPU
Member#: 25994
Thanks,
I am getting some new tires/wheels this weekend so I would like to get lower soon as well.
I have looked over on Scooby Mods, but I can't find this information, do you need a spring compressor to do this job? If a spring compressor is not needed, then I can can do this one myself.
Old 11-19-2002, 01:23 PM   #4
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Originally posted by WillysPU
Thanks,
ispeed or autonnivations.
suby_dude is offline   Reply With Quote
Old 11-19-2002, 02:46 PM   #5
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
Default Re: Newbie Needs Springs Installed
Hi BAIC list,
Well, the WRX springs are anti-climactic if drama is what you're looking for. If you're removing the stock springs and installing lowering springs then you don't even need a spring compressor. If she's afraid you're going to get hurt give me a shout when you want to do the install and I'll undo the springs. Or, tell her you're taking the car to have the install done at "Dreamlot" and I'll meet you there. $17 bucks an hour gets you a shop full of tools as well as a lift. Of course we'd do the work ourselves . If she reads this board that idea is gone .
Cheers, Joe
veloLexus is offline   Reply With Quote
Old 11-19-2002, 03:49 PM   #6
Diranged
Member#: 18722
2002 WRX Sedan
World Rally Blue Pearl
Hi BAIC list,
Thanks in advance!
Ok I have basic "wrenching" experience . Nothing major, but basic bolt on stuff... I had never done a spring install before, and I was able to do it with my friend in about 3 hours --with going slowly.
It really is a 2 person job, but if you read the how-to's, you can do it with most basic tools in easily under 3.5 hours. You can read a quick writeup on my experience at http://wrx.wiredgeek.net
For the work involved, i highly recomend doing it yourself - its not that difficult.
--Matt
Diranged is offline   Reply With Quote
Old 11-19-2002, 07:23 PM   #7
WillysPU
Member#: 25994
Alright, you all gave me confidence to do it myself, that's generally the best way to get to know your car anyway.
Just to clarify, if I can raise the car fully off the ground, do I need a spring compressor?
Thanks for the input, the Eibachs are ordered and should arrive in a couple of days.
Old 11-19-2002, 07:40 PM   #8
Diranged
Member#: 18722
2002 WRX Sedan
Yes, you need a spring compressor. No, you dont have to buy one, and no they arent expensive. I borrowed one from Pep Boys for free, but you can even buy them for $50.
1) Raise the car off the ground
2) Take off wheels
3) Remove entire strut/spring assemblys. You do NOT need a spring compressor at this point, because the strut top holds the spring in.
4) Use the spring compressor on the spring to tighten it down till the spring is loose inside of the strut assembly.
5) Take off the strut top -- see my webpage as well as as many how=to's as you can for help on this -- this is the one tricky part.
6) take out spring, put new one in
7) put top back on ( you dont need the compressor for this)
8) bolt assembly back into car
9) reassemble car
your done..
really, the hardest part is step #5. And its just a bit tricky, not hard..
Good luck!
--Matt
Old 11-19-2002, 10:07 PM   #9
Jademonkey
Member#: 9213
2000 RS
Red
What springs are you using? Depending on how much you lower it, you might want to invest in some stiffer shocks.
You don't need a compressor. Just looses the strut bolt just enough so it's barely on. Then wrap it in a blanket, and toss it into the street! Haha, jk. Go "borrow" a compressor from Pepboys, and I'd recommend having some help when doing this. An extra set of hands makes the job a lot easier.
Good luck!
Jademonkey is offline   Reply With Quote
Old 11-19-2002, 11:23 PM   #10
WillysPU
Member#: 25994
***Anyone know the torque specs for the strut nuts and bolts?***
Jademonkey: I will look for a big old blanket to wrap them up in :>
I am going with the Eibach Pro's. I am in my 40's and the old bones appreciate a little cush for everyday driving. I have been looking at the Koni adjustables, I had them on an old Porche along time ago and they were a great mix of comfort and performance. I should be getting my Konig Passport 18" wheels and Kumho 225/45's mounted by the end of the week.
Look out Manny, Moe and Jerk, I am coming to get your spring compressor!!!
Thanks again everyone, this site is a great resource.
Old 11-19-2002, 11:28 PM   #11
BobbyD
Member#: 27262
02 WRX
hey, what and where exactly is dreamlot..?
thanks
--bobby
BobbyD is offline   Reply With Quote
Old 11-20-2002, 12:56 AM   #12
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
Default Re: Re: Newbie Needs Springs Installed
Cheers, Joe
It's a DIY garage. In Mountain View. www.dreamlot.com
Steppin Razor is offline   Reply With Quote
Old 11-20-2002, 06:35 PM   #13
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
I have the eibach sport springs on KYB AGX (Adjustible shocks) and I enjoy the firm yet smooth ride, and the ability to adjust. And a little less pocket book depletion than Koni's. Even the springs themselfs, paired with a larger rear sway bar of course, will give you excellent feedback, allow you to carry much more speed through turns, and will not injure kidneys when floating over humps and bumps in the road. This should be a manditory first mod!
Dreamlot?
WOW! I've never seen or heard of that place before. And here I was stressin about having to install fuel rails in the middle of downtown Santa Cruz with my mickey mouse travel tool box. I miss my garage
More info on Dreamlot..their site sux
Old 12-07-2002, 06:55 PM   #14
WillysPU
Member#: 25994
Just wanted to let everyone know the Eibach install is complete an the car looks and handles great!
If you follow Matt's (Diranged) instructions above you will be fine. The upper and lower 19mm bolts are tough to get off so make sure you have a long breaker bar or a fresh high quality 19 mm closed end wrench that you can pound on with a BFH (Big F'ing Hammer). Also, before you remove the upper 19 mm front bolts, check to see their exact position, their strength number "10" is printed on the top of the bolt. This bolt is used for camber/caster adjustment. If you replace the bolt exactly as you reomved it, the spring install will give you a bit of negative camber.
Other wise, follow Matt's instructions and review the P1 install in ScoobyMods.
Thanks for everyone's help!!!
Jim
Newbie On Spring Install sedonawrx Brakes, Steering & Suspension 1 03-12-2006 09:45 PM
Garage day anytime soon? Need spring installation help! SiOrange New England Impreza Club Forum -- NESIC 96 10-16-2004 04:02 PM
Newbie need clutch install help please boom2085 Legacy Forum 3 07-13-2003 03:44 PM
Need spring installation in the Atlanta area and can't find a good price! Pete C Brakes, Steering & Suspension 5 11-01-2002 01:03 PM
Ran out of time, need springs installed in SF SFsube Bay Area Impreza Club Forum -- BAIC 5 03-28-2001 04:38 PM
