![]() Texas Impreza Club Forum sponsored by Gillman Subaru Houston and Gillman Subaru San Antonio |
#1 |
Baaleted
Member#: 11800
I've heard we break both syncro and actual gear.
The Chalak gear set is JUST THE GEARS, they use the stock syncro's and shafts. Unlike the Kaaz where it's a set of syncro's,gears, shafts etc and all components required to install in stock tranny housing. So, it really wouldn't be worth it getting just the gears when the syncro's are still stock and we can just as easily break those. Does this sound right or have I been mislead?
#2 |
Member#: 9796
Vehicle:2004 STI WRB |
It depends. If you are making a lot of torque, you can actually break the gears, otherwise you would normally break the syncros first. I wouldn't buy just gears.
Jason |
#3 | |
Baaleted
Member#: 11800
See, that's whats I thought. Thanks dude! BTW, I think I'm going to go with Kaaz. Chalak from Austraillia was calling me last night but it was at like 3:30 in the monin' |
#4 |
Member#: 8945
TXIC
Vehicle:MY02 WRX Blue |
You don't actually "break" synchros. Synchros only serve to match your input and output shaft speeds. You can break the dogs, even a synchro box has dogs (this is what grinds when you miss a shift).
#5 | |
Baaleted
Member#: 11800
#6 |
Member#: 8945
TXIC
You can destroy a synchro, but it's not something that breaks. It's like a clutch, you can slip it all day and destroy it, but it doesn't break.
More than likely Florida Boy's synchro was damaged by the excess metal bits floating around in his tranny. The only time you use the synchro is when you put the tranny into gear. |
#7 | |
Baaleted
Member#: 11800
Ahhh, I gottcha now. Getting all technical on us and stuff.... |
#8 | |
Member#: 6713
TXIC
Vehicle:2007 Prius brown |
you can wear out, and maybe even 'break' a synchro with excecssive powershifting. everytime you force the car into gear real quick, rather than letting it 'slip' into gear, you are putting some wear on the synchro. the early 4.6 Mustang GTs had pretty weak synchros, pretty much everyone who drove hard wore them out. Would cause the car to grind a lot on shifts. But the gears never broke. |
#9 | |
Baaleted
Member#: 11800
Ok, then Kaaz it is. Nicks mustang was in the shop twice getting new 1 2 3rd syncros... |
#10 |
Member#: 5270
TXIC
Vehicle:2008 EvoX MR Red |
Are you totally opposed to a dog box?
#11 | |
Baaleted
Member#: 11800
For daily driving, yes. For a race tranny, no. Do you run a dogbox? |
#12 |
Member#: 9796
I drove Blugin's car on dyno day. The dog box really wasn't too bad. I only stalled it a few times
How much are the Kaaz gears/synchros and what are they rated to (torque)? Jason |
#13 | |
Baaleted
Member#: 11800
One says 450HP and another guy says 500HP easily but that's more than I have planned. Here are the responses from RalliSpec... scroll to the botom. HERE |
#14 |
Baaleted
Member#: 11800
I was mistaking... the Kaaz utilize the stock syncro's. It looks I'm gonna replace the stock 1rst and 2nd gear synco and throw in the Chalak gear set, plus I can get better gear ratio's with them.
#16 | |
Member#: 2944
TXIC
Vehicle:2000 2.5RS Steel Blue Mica |
#17 | |
Member#: 2944
TXIC
scott |
#18 |
Member#: 2944
TXIC
could you shoot me the number for Chalak, I really would like to get ahold of them.
thanks, scott 281.289.0035 voice mail |
#19 | |
Baaleted
Member#: 11800
#20 | |
Member#: 2944
TXIC
thanks, scott |
#21 | |
Baaleted
Member#: 11800
I'll PM it to you. |
| Thread Tools | |
| Display Modes | |
| What are the actual effects of high compression? | williaty | Built Motor Discussion | 22 | 02-12-2009 04:49 PM |
| What are we to do? Our cars are about to end their reign... | delaner | Off-Topic | 272 | 06-19-2006 03:31 PM |
| N/A land...what are we missing? | Reciprocity | Normally Aspirated Powertrain | 57 | 03-09-2003 04:12 AM |
| This Sat or Sunday What are we doing??? | RS22b | Tri-State Area Forum | 7 | 07-20-2001 08:55 AM |
