Old 11-19-2002, 07:25 PM   #1
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Default New clutch acting weird: engagement point randomly changes on clutch pedal...
I just had Exeter Subaru install a ClutchNet six puck sprung copper rally clutch in the PGT car (MY96 Impreza L with cable clutch) along with a new stock flywheel, throwout bearing and pressure plate. After daily driving it for about a month the clutch started acting strangely.
When engaging the clutch pedal at low speeds (getting rolling from a stop or bumper to bumper traffic) sometimes the clutch engages when the pedal is an inch off the floor, sometimes two inches off the floor and sometimes two and a half inches off the floor. If I come to a stop on an incline and the car rolls backwards with the clutch disengaged in first gear, engaging the clutch "catches" a little bit when the pedal is an inch off the floor, the car lurches, but the clutch doesn't fully engage until the pedal is two and a half inches off the floor.
Does this sound like the throwout bearing binding up on the pressure plate and I'll have to take the vehicle in for service or might there something I can do at the clutch fork to take care of the problem? I've swapped suspension and most everything else but I don't have the facilities to drop the transmission myself to inspect the clutch and pressure plate internally (yet ).
There is no cone | PGT Impreza L Rally Car | P Neon Rally Car
Trunkmonkey Racing | [email protected] | What is a Trunkmonkey?
Sean is offline   Reply With Quote
Old 11-19-2002, 07:28 PM   #2
rogue
Super Moderator
Member#: 7977
100% Abuse
Hi!
I'd like to preface this by reminding Sean that I have NO CLUE what I'm talking about...
Is it possible the clutch cable was not well stowed? Maybe it's catching on something randomly and getting pulled out of whack?
I don't even know if your clutch uses a cable or hydraulics or what, just throwing out an idea. I've seen a similar situation with throttle cables once.
rogue is offline   Reply With Quote
Old 11-19-2002, 07:34 PM   #3
Sean
Member#: 518
762 PGT Impreza L,
Quite possibly...that's what I was thinking but haven't had a chance to have an assistant go out and push the clutch pedal for me while I watch the clutch fork. Assuming the cable moves freely and doesn't bind I was wondering if there are any adjustments I can do on the fork to alleviate this. For example, will tightening or loosening the cable at the fork to change the engagement point help?
Edit: Yes, I'm a stupid driver, not a mechanic.
Old 11-19-2002, 10:32 PM   #4
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Default Re: New clutch acting weird: engagement point randomly changes on clutch pedal...
I just had Exeter Subaru install a ClutchNet six puck sprung copper rally clutch ... After daily driving it for about a month the clutch started acting strangely.
Sounds like you just answered your own question. Didn't anyone tell you that copper clutches aren't designed with user-friendliness as a primary design goal? Otherwise, they'd install them as standard equipment in performance cars, no?
wac is offline   Reply With Quote
Old 11-19-2002, 10:43 PM   #5
Sean
Member#: 518
762 PGT Impreza L,
Default Re: Re: New clutch acting weird: engagement point randomly changes on clutch pedal...
Ha. Well, I understand and fully expected the rough engagement and studdering. I did not, however, expect the engagement point to randomly change depending on the mood of the car. From the feel of the clutch pedal it feels as if the clutch is getting caught on something or the fingers aren't evenly pushing against the clutch disc.
Old 11-20-2002, 09:28 AM   #6
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
I just put a similar clutchnet clutch & Primitive flywheel in my 1997 Impreza (cable style). There is an adjustment at the fork under the hood, however I maxed mine out. It engages about 1" from the floor however I've noticed that is snaps in quickly to about 85-90% engaged, then takes about another .75" to fully engage. I'm worried that my clutch cable (car has 120k miles on it) is stretched so that once wear occurs, I won't be able to fully disengage it... To aleviate this I'm planning to invest in a new one. Also there may be an adjustment at the pedal, however I haven't taken the time to look yet.
When my car has warmed up a lot, the clutch engagement point seems to move up the pedal some, but not more than .5-.75 inch.
Good luck with your problems... hope they get sorted for you.
I'll let you know if I find an adjustment on the pedal. I'll be putting my new pedals on this Friday and will look.. may take a gander tonight as well.
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 11-20-2002, 02:26 PM   #7
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Yes there is a clutch pedal adjustment point. It is located above the gas pedal where the cable penetrates the firewall.
Albert is offline   Reply With Quote
Old 11-20-2002, 04:32 PM   #8
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
HA! my stock clutch has acted like this as long as I remember! no two friction points are the same! makes for interesting driving
maybe it has something to do with how the clutch heats up? or when the engine/trany is warm/cold it changes the friction point? copper expands......
(I dunno! )
GooseMan is offline   Reply With Quote
Old 11-20-2002, 08:31 PM   #9
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Does not apply to Sean's cable clutch.
Old 11-21-2002, 10:49 AM   #10
Sean
Member#: 518
762 PGT Impreza L,
OK, I adjusted the bump stop just above the clutch pedal and tightened down the cable on the clutch fork. This got rid of some slack and play but didn't solve the weird engagement problem.
OK, wac (and anyone else with a cable clutch), if you grab the clutch fork with your fingers is it mounted pretty solid or can you wiggle it around about half an inch from side to side? Mine wiggles (yes, that's a technical term ) quite a bit. Perhaps the clutch fork is worn.
Next question, all the hydraulic Imprezas I've driven have an engagement point about an inch off the floor...is that possible to do with a cable clutch? Brian (North Ursalia) didn't seem to think so when we were poking at the car last night, but whenever I got my old cable clutch OBS back from tranny service the clutch engagement point was about an inch off the floor then, over the course of a few months, started to get higher and higher until it topped out at about 3 inches off the floor.
Old 11-21-2002, 01:51 PM   #11
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
You do still have your return spring on the clutch fork right?
You may want to consider a new clutch cable.... My OBS was an inch or more off the floor until I put in my clutchnet clutch and flywheel. Did you heavily grease the input shaft? What condition was your input shaft in when you installed the clutch... Oh wait you had it installed didn't you.
Jon
Old 11-21-2002, 04:21 PM   #12
Sean
Member#: 518
762 PGT Impreza L,
Old 11-21-2002, 06:01 PM   #13
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
my bag,...cable...adjustable at the fork. duh.
Clutch engagement point change with altitude xS2k Transmission (AT/MT) & Driveline 6 01-03-2006 04:51 AM
Clutch engagement point changing (a bit long) ej25power Transmission (AT/MT) & Driveline 3 12-28-2005 04:43 PM
Ever-changing clutch engagment point PA-Brat Newbies & FAQs 8 04-11-2004 02:06 AM
machining flywheel - change clutch engagement point? czo79 Transmission (AT/MT) & Driveline 2 10-01-2003 03:49 AM
Clutch Engagement Point Change Momentary, is this normal? H5N1 Normally Aspirated Powertrain 5 06-08-2001 02:18 PM
