Old 11-19-2002, 09:07 PM   #1
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
Default gauge wiring
ok...i know i can go behind the radio and use the plug to light up my gauges , that works fine with my mech boost gauge, , but where do i get the 12v switched from for the electronic gauges???do i use the same wire on that plug behind the radio that i get the illumination from for the 12v switched? basically using 12v switched and illumination as the same, or am i better tapping into a fuse or something like rear wiper fuse. (which we dont have on the sedan) ...pics will help...i prefer not running wires through the whole car....
thanks
StarDogChampion is offline   Reply With Quote
Old 11-19-2002, 10:27 PM   #2
LangstonSubaru
Vendor
Member#: 2175
Behind the fuse box is probably best, but at the radio is so simple that you just can't past it up!
LangstonSubaru is offline   Reply With Quote
Old 11-20-2002, 12:43 AM   #3
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
bump?
**Prosport gauge wiring, need exact wires** shamrock 05 Interior & Exterior Modification 10 08-04-2011 11:13 AM
Need Exact Wires to Attach Prosport Gauge Wires To Idaho Electrical & Lighting 1 09-12-2007 06:15 PM
Help what wires on the clock do I tap for gauge wiring BIG BEN Electrical & Lighting 2 11-09-2002 01:04 PM
gauge wiring clock wire ? help dark knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-14-2002 07:26 PM
4 gauge wire into 8 gauge terminal. T-REX Car Audio, Video & Security 6 04-09-2001 01:11 PM
