Old 11-20-2002, 08:40 AM   #1
garie
Member#: 26607
2002 wrx wagon
Unhappy cant lock doors when turbo timer is running?!?!?!
hi! something weird started happening like last week.......when my turbo timer is running im not able to lock the doors with the remote anymore.....its weird cuz b4 it worked fine...the doors would lock and everything but now it doesnt.........i thought maybe i didnt ground the ground wire correctly...so i redid it...but it still doesnt work. I have the blitz turbo timer and a 2002 wrx wagon.
can u guys offer me any suggestions on how to fix it? thanks alot!! also could you tell me where i should ground the ground wire that comes out of the wiring? thanks!!!!
-gary
garie is offline   Reply With Quote
Old 11-20-2002, 01:52 PM   #2
WRX_Aaron
Member#: 23446
I have the same problem after install my Blitz FATT...I heard we have to bypass it but not sure how to either..hopefully someone knows
WRX_Aaron is offline   Reply With Quote
Old 11-20-2002, 05:01 PM   #3
Ride Operator
Member#: 18710
02 GDA PSM
12 Impreza Sprt Lmtd MBP
Default swankmonkey
I followed swankmonkey's install directions...
http://wrx.swankmonkey.com/turbotimer/
I have an APEXi TT and can arm my factory "upgraded" alarm , walk away, and have the TT shut the car off. FYI - I bought the HKS TT harness too, made the install that much easier.
There's several threads on installs.. try a search on "turbo AND timer AND install".
-T
Ride Operator is offline   Reply With Quote
Old 11-20-2002, 05:07 PM   #4
reXer
Member#: 13312
You have to cut a wire (if you don't have the alarm, not sure what to do if you have it) for the factory remote locks to work while the car is running. I'm sure you can find out somewhere what wire to cut. It's black and green I think. Look it up somewhere.
reXer is offline   Reply With Quote
car wont lock with the turbo timer runing pulser9 Car Audio, Video & Security 3 03-18-2007 07:25 PM
How to lock car with turbo timer still shutting it down. imprezdgc8 Electrical & Lighting 7 09-21-2005 09:17 AM
which turbo timer is a boost gauge also? m4r10 Electrical & Lighting 4 01-18-2004 12:23 PM
