Old 11-20-2002, 12:52 PM   #1
Davenow
Member#: 23676
Default Catless Uppipe+TurboXS stealthback, is there a way to pass emissions??
I am getting the turboXS stealth turbo back, it has one high flow cat, I also REALLY want to get rid of that up pipe cat, But I need to know is there a way to get it to pass an emissions test if I do this? I really dont want to have to keep/reinstall the factory turbo back every 2 years for emmissions testing.
Anyone???
Old 11-20-2002, 01:56 PM   #2
norseone
Member#: 16350
B8.5 Audi S4
Yeah slip the tech a 20 spot.
-NORSe
norseone is offline   Reply With Quote
Old 11-20-2002, 02:03 PM   #3
WRX300
Member#: 17974
well at least here in IL you dont have to have smog till the car is about 5 years old....from what i have been reading at work the DMV will be changing how they run sniffer tests....it seems that in the next few years they will be removing the portion of the test that puts the car on the dynomoter and just plugging into the OBD system...which means if the OBD system says all is good (like with 02 sims and Capcitor fixes) then you will pass the emissions test...however im sorry i cant comment on your state but im sure something like that will be happening else where
~wrx300
WRX300 is offline   Reply With Quote
Old 11-20-2002, 04:57 PM   #4
koloumb
Member#: 28268
2002 WRX Sedan
Remember that you have an AWD car. A lot of DMV's aren't equipped to dyno an AWD car. They instead hook up to the car's computer to see if it reports any [emissions] codes. If it doesn't find any - you pass.
_Owen_
koloumb is offline   Reply With Quote
Old 11-20-2002, 05:33 PM   #5
slickvic
Member#: 29727
2003 Impreza WRX
Can anyone from indiana comment on whether or not cars here are tested for emmisions.
slickvic is offline   Reply With Quote
Old 11-20-2002, 06:39 PM   #6
NYC TURBO
Member#: 25214
Don't buy the turboxs, buy the MRT turbo back. It is guaranteed to pass emission tests in all 50 states. The uppipe cat does absolutely nothing once the car is warm. It is meant for cold start emissions only. Once the car is warm all it is doing is blocking airflow. remove the uppipe and make sure the car is warm before you bring it for inspection and go with the MRT turboback and you will pass the test.
Lee
NYC TURBO is offline   Reply With Quote
Old 11-20-2002, 07:36 PM   #7
Sweet Dreams
Member#: 25765
2002 Impreza WRX
Platinum Visa Metallic
wrx300.....I think you may have just answered a question that's been on my mind the last few days.
Here in Wisconsin, we don't have to submit to a dyno/sniffer test if we have OBD II. They just plug into our port to see if we have thrown any CELs relating to emmisions equipment. I was thinking that if I have an O2 simulator in my turbo back, and no CELs, then I should probably pass the test.
By the way, in Wisconsin, we have to have emmisions done every other year. There is no 4 or 5 year waiting period for new cars.
What do you guys think?
Sweet Dreams is offline   Reply With Quote
Old 11-20-2002, 08:17 PM   #8
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
Default interesting
If one were to pull the negative terminal, step on the brakes and then reconnect *right* before a smog check, would that clear any previous OBDII cat efficientcy codes? From what I've read, the car checks for cat efficentcy on sustained high speed cruising...
Schlad is offline   Reply With Quote
Old 11-20-2002, 08:20 PM   #9
hokiewrx
Member#: 18505
2004 STi
I have no cats, and I just did a 600 mile round trip this past weekend with no CEL. I've put about 1,500 on my car since I put the TXS SB w/ race pipe on. Go figure...
hokiewrx is offline   Reply With Quote
Old 11-20-2002, 08:22 PM   #10
ants wrx
Member#: 17885
2006 Scion xB
93 RB25det powered 240sx
that is the same setup i have...uppipe + turboxs stealthback with cat.
anyone know if this will pass in NJ?
ants wrx is offline   Reply With Quote
Old 11-20-2002, 08:46 PM   #11
dave_the_driver
Member#: 13588
2002 WRX sedan
Default NM checks the tailpipe emissions
You guys in states that let you drive a new car for 5+ years without a smog test are lucky. Here in Albuquerque it's every two years ... no ifs ands or buts. They plug something in to the engine and it automatically controls the RPMs (for testing both idle emissions and at speed, 3000 RPM ?). The sniffer probe they stick in the tailpipe measures CO as well as total hydrocarbons. They sure don't go by the OBDII codes alone, though they might check them to see if you've thrown an emissions-related code. The machines they now use are pretty expensive and "smart."
The way they used to do it, you could bring in two cars and have them scan the windshield VIN from one (the one without cats) and have them stick the probe and rev the engine on another car that's not modded. I'm not sure how they did it, but there were too many $20s (and then $50s) changing hands while two cars were being "tested" that they figured out a way to prevent it. So even if they wanted to fake the test (for $100+), i don't think it's possible. Of course, i'd be glad to be corrected if someone knows a way out of this.
I know someone with a European-spec imported Porsche 911 Turbo who'd gladly pay big bucks so that he doesn't have to have his mechanic mess with his car in the shop for a few days every two years so it can pass the test. He'd probably pay $500 because it takes his mechanic about 8 hours of labor for passing the test, and then to set it back for performance.
Hey, does anyone here in Bernalillo County have a UTEC in their WRX? I'm on the TXS waiting list as of last week, and will run my baby for a while at the stock setting and then maybe raise the boost and fuel curves a bit. Being that this is at 5000 feet, i'm afraid to play with advancing the timing.
Anyone in my situation who's nearby, please PM me. It would be great if i could do a roll-on test against another WRX with a UTEC and some mods so we can see what difference it makes.
I'm also looking for a mechanic, preferably someone unlicensed who's into high-performance turbo cars. There's five WRXs in my parking lot at work, but it seems that the only performance mods they've done are brakes, wheels, and tires. And that's just one guy. The rest are chicken and drive it like a normal car, it seems.
Well, i should talk. After rear-ending someone at low speed because of the slow and mushy stock brakes i put in the OEM replacement Porterfield pads all around. They're a huge improvement. Next up is the UTEC. Then the up-pipe.
Dave
dave_the_driver is offline   Reply With Quote
Old 11-20-2002, 11:53 PM   #12
doogdog
Member#: 29308
2005 Outback XT LTD
Champagne Gold Opal
Default There is a way
As you know the emissions testing in MA sucks, give Adrenalin Motorsport in Auburn, MA a call. They do mostly WRX tuning and have the scoop on your concerns. Don't forget, you can't put your car on one of the inspection station dynos due to the all wheel drive. I had similar concerns and they gave me the skinny, good luck.
doogdog is offline   Reply With Quote
Old 11-21-2002, 06:43 AM   #13
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: interesting
I think you have drive to restore the I/M (Inspection/Maintenance?) OBD-2 monitors to all read "Ready".
I think if one of them is still "Not Ready" there will be a problem passing.
In my experience with P0420's which pop up under some situations, the scantool erase procedure puts all the I/M monitors in "not ready," and the last one to clear is the "Fuel Evaporative System"
So, yes you can clear a cel, but you should drive for a few days to a week to get all the I/M monitors reset.
I am going to do two more scenarios next:
1) What does a battery disconnect for a couple of hours do to the I/M monitors?
2) After the next p0420 occurance, pull the neg cable, install the PEP MIL eliminator and read the I/M monitors.
z&cobb is offline   Reply With Quote
Old 11-21-2002, 11:43 AM   #14
nmyeti
Member#: 4980
Default Re: NM checks the tailpipe emissions
Dave
Dave,
I moved away from Albuquerque this spring to work for Turboxs. I'll be back in town to visit my family around Christmas time, so who knows... I might be able to bring you a Christmas present
For what it's worth, on my old Unichip stage 2 I ran [email protected] in Roswell, and then on my stage 4 I ran [email protected]
At the altitude of Albuquerque, you will need to play with the map just a little to get it just right, but once it's done, the results are well worth the effort.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 11-21-2002, 06:46 PM   #15
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
Default Re: Re: interesting
Most excellent! Keep me/us posted on what you find! I guess it's obvious that I do not (yet) have a scantool.
Old 11-30-2002, 04:33 AM   #16
dave_the_driver
Member#: 13588
2002 WRX sedan
Default Re: Re: NM checks the tailpipe emissions
Originally posted by nmyeti
Dave,
-Nathan
www.turboxs.com
Nathan, i didn't see your reply until tonght. I had gotten the impression that you couldn't help me in getting the UTEC set up for Albuquerque's altitude and 91 octane gas. If i had seen this reply earlier, i wouldn't have canceled my UTEC order. I know you used to live here. We both know John V., the Impulse RS lover. I'm working on getting a high-flow cat-included turbo-back exhaust. I was just not willing to hook something up that would detonate all over the place unless i could get some help in remapping it.
David
Old 11-30-2002, 12:44 PM   #17
koloumb
Member#: 28268
2002 WRX Sedan
Dave
Aren't there any small clubs that host install days in your area? Usually the person hosting it has the room, tools and experience of others to help install mods.
_Owen_
Old 11-30-2002, 12:57 PM   #18
dave_the_driver
Member#: 13588
2002 WRX sedan
_Owen_
i don't know of any such thing in Albuquerque. My garage is pretty small and i don't have a lot of tools or much mechanical experience with new cars, but i can provide food and drink.
David
Old 11-30-2002, 01:10 PM   #19
mlambert
Member#: 13831
Default Re: Re: Re: NM checks the tailpipe emissions
David
Thats always the most rewarding way of working on cars. Here in portland we are amazingly fortunate to have Mr Perrins experience, Mr Sponaugles amazing garage, and a group of really great guys to help get everything worked out. When I lived in Houston it didnt take me long to find a group of enthusiasts that got together bi-weekly or so and hosted install days. Nothing beats getting together with people that share a common interest and help you work through a tough install.
Youll find folks to help you, maybe get to know the local DSM crowd if you cant find subaru owners that turn wrenches. What about AZScooby and that group?
mlambert is offline   Reply With Quote
Old 12-02-2002, 03:23 PM   #20
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: Re: Re: interesting
The evaporative emissions I/M eventually reset, but it took longer than the other 1/2 dozen. That's after erasing a P0420 CEL directly with an OBD-2 scantool, and not installing my MIL eliminator or disconnecting the battery.
Unfortunately it takes two events to get the P0420 CEL on. This means you miss 1/2 of the events.
I wonder if catching and erasing the 1st event would keep the Inspection/Monitoring tests in their "Ready" states?
Current Conditions:
Stage 2 UTEC with 93* octane "non-oxygenated" program
with the TXS TMIC, 16.5 psi, stock intake with K&N filter, stock uppipe, 5W-30 Mobil Synthetic. Ambient Temps from about 28F to 60F, oil temps with a fully warmed engine range from 60 to 80C, elevations about 1000 to 1500 ft.
*I use Exxon 93 octane from an exempt county. It's 15 cents cheaper than "city slicker" gas designed by the EPA.
Old 12-02-2002, 04:15 PM   #21
nmyeti
Member#: 4980
Default Re: Re: Re: Re: NM checks the tailpipe emissions
For the record... since this seems to come up every time I tell someone I used to live in Albuquerque.
Albuquerque is in New Mexico, and is several hours of driving from Arizona.
Dave,
I sent you a PM.
-Nathan
Old 12-02-2002, 04:31 PM   #22
mlambert
Member#: 13831
last time i drove I-10 thru AZ/NM i didnt even know I was in NM by the time I hit el paso, its not that far
Old 12-02-2002, 05:12 PM   #23
nmyeti
Member#: 4980
474.95miles to be exact.
Old 12-02-2002, 06:48 PM   #24
silvercharged
Member#: 19295
To elaborate a little futher on this......I live in Maryland, which is now doing OBD scans as their emissions testing.....
The Auto X-Ray code scanner I have not only erases the CEL and turns off the Check Engine Light, but, at the same time, resets the "readiness tests" that are incorporated into the ECU......
Nice tool for $132.00
silvercharged is offline   Reply With Quote
Is there a way to make Word export to HTML in a simple format? Jessie James Off-Topic 11 02-27-2004 04:06 PM
is there a way to read what my cel is akcel Engine Management & Tuning 4 02-23-2004 06:22 AM
is there a way to d/l the UTEC software to practice? wrxtuner02 Engine Management & Tuning 2 12-05-2002 01:41 PM
Any way to pass emissions? N/A01RS Normally Aspirated Powertrain 24 10-28-2002 10:10 AM
('93-'01) Is there any way to find out if the WRX is the most crashed "new" car this year? Snoopy Impreza Forum 25 10-16-2002 01:53 AM
