Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 11-20-2002, 03:32 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Check engine code P1443: Evaporative emission control system vent control function?
"Evaporative emission control system vent control function problem." Is this the gas cap code? If not, what is it? Thanks.
garface is offline   Reply With Quote
Old 11-20-2002, 04:05 PM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Its the code that I got for two years... don't worry about it.
Old 11-20-2002, 04:14 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
yeah it's prob gas cap......just drive car and see if it goes away.....it should.
Legacy777 is offline   Reply With Quote
Old 11-20-2002, 04:43 PM   #4
garface
Member#: 1581
MY00 RS/STi7
It came on about 1 day after getting gas. I tightened the cap and it went away 2 days later. Then after I got gas again, it came on again, except this time it isn't going away, even after I took the cap off and retightened it. I'm thinking maybe I need a new cap. Or maybe I should give the Sunoco guy a good swift kick in the....
Old 11-20-2002, 05:03 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
If you look under your hood there is a vacumn line that runs off the top of the intake manifold and under the passanger side intake runners. It starts on top the intake manifold right behind the TB. There is a little electronic solonoid there with 2 vacumn lines in it. One is the line you followed from the top of the intake manifold, the other goes to the vent line from the gas tank. Make sure that you dont have a broken vacumn line there or the solonoid is broken. Mine was broken and it threw a code until I plugged up the vacumn leak. I dont remember the number of the code, but it was very similar in description to the one you have.
J
jeffg is offline   Reply With Quote
Old 11-20-2002, 05:39 PM   #6
garface
Member#: 1581
MY00 RS/STi7
Thanks Jeff, would that affect the car in any way? Anyone have a pic of what you're talking about? Also, would it be possible for the hose to broken somewhere else running toward the gas tank?
Old 11-20-2002, 05:45 PM   #7
2Point5RS
Member#: 3639
J
Are you talking about the hose that is on the PCV valve?
2Point5RS is offline   Reply With Quote
Old 11-20-2002, 06:53 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
No, it is a small vacumn line, like maybe 1/4" in diameter.
if you look at the top of your intake manifold, right behind the TB, you will see a small metal hose bard screwed into the top of the manifold. it points straight up, towards the hood. The vacumn hose attached to this bard is what I am talking about.
Okay, I just looked for like 35 minutes to try and find an underhood pic. I will take one when I get home and point out the parts.
J
CEL code P0457: Evaporative Emission Control System Leak Detected (fuel cap) aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 02-09-2015 09:50 AM
P1443 Evaporative emission control system vent control function problem gtlegg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-21-2009 04:09 PM
Check engine code P1591 Help!!! Idle speed control Crump Service & Maintenance 1 12-06-2006 07:21 PM
Evaporative emission control system vent control function problem holtian143 Newbies & FAQs 8 09-30-2005 11:19 AM
Evaporative emission control system vent control function problem holtian143 Service & Maintenance 3 09-29-2005 06:24 AM
