Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-20-2002, 11:04 PM   #1
wistful
Member#: 745
2004 STi
Java Black Pearl
Default is the second o2 sensor necessary?
What were to happen if I were to just remove it? I mean, I already have a cat inefficiency code as we speak? Woudln't it just be the same? The car wouldn't totally spaazzzz would it?
Don
wistful is offline   Reply With Quote
Old 11-21-2002, 03:14 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you'd have a rear o2 sensor malfunction code instead
Old 11-21-2002, 10:10 AM   #3
wistful
Member#: 745
2004 STi
Java Black Pearl
so what are the performance ramifications behind that? I mean.. would my car run ok? or would it go into limp mode?
Don
Old 11-21-2002, 11:41 AM   #4
Julian
Member#: 1182
MY00 RS
BRP
The second O2 sensor is for OBD-II regulations, and mostly to let you know of the degrade/demise of your cats. It wouldn't limp.
Julian is offline   Reply With Quote
Old 11-21-2002, 11:42 AM   #5
Keith Cournoyer
Member#: 16764
Default 2nd O2 Sensor
I ran about 150+ miles with the 2nd O2 sensor removed, constant CEL, but no performance difference. The sensor is a waste of $150 if you ask me! I heard that the front 02 is the one that's important? Keith
Keith Cournoyer is offline   Reply With Quote
Old 11-21-2002, 02:59 PM   #6
whitemr2
Member#: 29525
1991 Subaru Legacy L
stealth silver
As others pointed out, it's just to monitor performance of the cat. It has no effect on performance (although, I can't rule out the possibility that the ECU MAY alter its maps if it thinks it has a bad catalytic convertor).
If you want to get rid of the check engine light, take the wires that used to run to the second sensor and connect them to the primary sensor (just like you'd connect an A/F gauge). That should appease the ECU.
whitemr2 is offline   Reply With Quote
Old 11-21-2002, 04:30 PM   #7
kturner
Member#: 8225
Default Careful
about wiring them together. The front is (at least on some cars) a 0-5 V signal whereas the rear is a 0-1 V.
kturner is offline   Reply With Quote
Old 11-21-2002, 07:25 PM   #8
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Default Re: Careful
You are correct I believe it is on 2000 and up.
EvasionOfTruth is offline   Reply With Quote
Old 11-21-2002, 07:35 PM   #9
SubaruStu
Member#: 8972
2003 WRX Wagon
Default Re: Careful
You wouldn't want to do that anyways. The ECU monitors the
switching frequency of the sensors. The front switches far more
frequently to adjust for driving conditions, as a result the rear
sees a more "constant" stream and consequently switches
(rich/lean that is) far less. When you cat starts to go, the
second sensor starts switching more frequently. At a certain
threshold of % frequency of the front, the CEL is triggered.
What most electronic fixes do via a resistor and capacitor, is to
keep the switching frequency sufficiently slow as not to trigger
the threshold limit.
Here's a good link to describe how the ECU and OBD-II works
for these things:
http://www.autoshop101.com/forms/h46.pdf
SubaruStu is offline   Reply With Quote
Old 11-22-2002, 12:38 PM   #10
whitemr2
Member#: 29525
stealth silver
Thanks for the clarification! My experience with this is on an OBD-I Toyota with dual sensors, which I now realize is a pretty unique application of the 2 O2 sensors (it basically ignores the second).
I didn't realize the output voltage could be different with different sensors.
can i zip tie second o2 sensor and put wideband o2 in that spot? sidwin AccessPort 2 02-11-2008 07:18 PM
Is the last O2 sensor need with STG2? o2sys Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-10-2006 10:04 PM
Is there a reason the Front O2 sensor is before the turbo? drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-28-2005 06:51 PM
is the FRONT O2 sensor a wideband sensor ? Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 07-01-2004 05:21 PM
will the car be ok w/o second o2 sensor? wistful Normally Aspirated Powertrain 1 03-06-2002 11:29 PM
