Old 11-20-2002, 10:18 PM   #1
4a-geWRX
Member#: 28851
Sedona Red
Default What Hp is too much for the Stock IC???
I haven't been to the dyno yet, but im guessing after I put on the UTEC with the rest of my mods that I will be close to 300 flywheel Hp. I was just curious when I should think about upgrading the IC. Be it front mount or an upgraded top mount, what Hp levels are too much for the factory IC??
-Matt
4a-geWRX is offline   Reply With Quote
Old 11-20-2002, 10:18 PM   #2
mcv9802
Member#: 6597
2002 Impreza WRX
Sedona Red Pearl
Do a search n00b.
-Mike
mcv9802 is offline   Reply With Quote
Old 11-20-2002, 10:24 PM   #3
mcv9802
Member#: 6597
2002 Impreza WRX
Sedona Red Pearl
I always wanted to say that but never had the balls to say it to someone I wasn't related to. I'm glad I got that off my chest. It would be nice to get an answer to this though.
-Mike
Old 11-20-2002, 10:25 PM   #4
4a-geWRX
Member#: 28851
Sedona Red
Ill remember that the next time you want an UpPipe installed, or your car waxed.
Old 11-20-2002, 10:25 PM   #5
BobbyD
Member#: 27262
02 WRX
hah.. that was brutal..
--bobby
BobbyD is offline   Reply With Quote
Old 11-20-2002, 10:46 PM   #6
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I don't thing that at a certainam HP level is to much for the stock I/C. It's is more the fact that a bigger I/C should flow better and have less of a pressure drop then the stock unit so your Turbo should not have to work as hard to make the same boost. I also think what you are goind to do with you car, where and how you drive it may also somewhat dictate the need.
I have been running Stage 4 for about 7 months now, so it has seen temps from -10 to 110. I have thought on an off again about getting one but am having a hard time justifying spending a $1000 to $1500 dpending on what I get.
Troy
roybfr is offline   Reply With Quote
Old 11-20-2002, 10:59 PM   #7
silverscooby
Member#: 15060
It really has to do with tuning. With careful tuning of advance and fuel your stock IC should be fine for where you're at.
On the flip side, getting a new IC gives you alot more resistance to detonation. There are some top mounts in the 700-800 range. When you think about it, isnt that 700-800 investment worth it once you look at what you get out of it? I believe there are many guys running in the 340-350 flywheel hp range with the stock IC. I was one of them. Unfortunately, my car is in the shop with a rather loud tapping noise coming from the #1 cyl. I will know by Friday what's up. Take that as you will.
silverscooby is offline   Reply With Quote
Old 11-20-2002, 11:06 PM   #8
Vostok 7
Member#: 30209
Now I understand
what this is a formidable
I don't really think HP will affect the IC... Correct me if I'm wrong... All you'd get by going to a bigger IC is more HP.
What I would do though is get silicone hoses ASAP. Those plastic ones aren't all that great. (plus you get a roughly 5hp boost).
Vostok 7
Vostok 7 is offline   Reply With Quote
Old 11-20-2002, 11:08 PM   #9
Vostok 7
Member#: 30209
Now I understand
Troy
What he said, for the most part.
All a bigger IC does is make it easier on your turbo to make boost.
Vostok 7
Old 11-21-2002, 12:08 AM   #10
4a-geWRX
Member#: 28851
Sedona Red
ALright guys thanks for all your input.
-Matt
Old 11-21-2002, 12:51 AM   #11
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Haaland, myself, and now silverscooby.... is there a trend here? stock intercooler, 350hp, and blown pistons all. Hmm.. I'm thinking get a better intercooler!
DarthChicken is offline   Reply With Quote
Old 11-21-2002, 08:12 AM   #12
cloakscott
Member#: 14153
2002 Impreza WRX
WR Blue Pearl
Correct me if I'm wrong but doesn't a good aftermarket TMIC also allow you to tune a more conservative/safe map?
cloakscott is offline   Reply With Quote
Old 11-21-2002, 09:46 AM   #13
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Took the liberty of proof reading your post. Here is the new copy ready for print:
"Haaland, myself, and now silverscooby.... is there a trend here? stock FUEL RAILS , 350hp, and blown pistons all. Hmm.. I'm thinking I will get better FUEL RAILS!"
CT
AZScoobie is offline   Reply With Quote
Old 11-21-2002, 10:02 AM   #14
silverscooby
Member#: 15060
That's a good point Clark and I forgot to mention that. I've had some conversations with Shiv and Brett at Visnhu about the stock fuel rails. Basically, they have told me that the stock fuel rails have a tendancy to lean out (especially on #3 cylinder) when running higher boost, even on the stock turbo.
Who knows what caused my problems? Was it poor intercooling? Was is bad fueling due to the fuel rails (I have a walbro pump and sti injectors)? Was it a bad injector? Was it that my motor was built on a Friday and not a Tuesday?
Fuel rails cost a little over 400.00. If I had to do it over again I would have gotten those when I did my other fuel mods.
Old 11-21-2002, 03:02 PM   #15
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I would put the upgraded fuel rails higher up then a bigger I/C, it is pretty nuts how much better the aftermakets ones are then the stock set up.
cloakscott IIRC a bigger I/C on the same map as a stock TMIC will run a little leaner according to Mark/Nate at TurboXS. This goes back to what I said above. The thing is that the turbo will work less at the same boost and the bigger I/C will do a better job of cooling so in the end you should be able to run a more aggressive map with the bigger I/C and still be relativly safe.
I do have to agree that with silverscooby that in the end @ $700-$1000 for a big TMIC it is worth it if it keeps you from having motor problems.
Troy
Old 11-21-2002, 03:12 PM   #16
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Yeah, the fueling needs to be changed as well... I have the Perrin rails on my car now as well, as does Haaland. As well as water injection, and running toluene - we're just a BIT paranoid now
Old 11-21-2002, 03:46 PM   #17
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I am curious as to what damage was found, ringlands?
Troy
Old 11-21-2002, 04:54 PM   #18
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Yes, ring landings broken/melted away. Almost identical damage, along the skirted side of the piston.
Old 11-21-2002, 06:31 PM   #19
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Do yall have EGT gauges? When my car was stock I did rails and an Greddy EGT gauge with the Probe right at the manifold on that side of the motor. It has saved me many, many times over... I see 900C I let off and find the problem...
CT
Old 11-21-2002, 06:41 PM   #20
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
of course! Done at the same time I got uppipe put in, which was over a year ago.
For Haaland and I, it was most definitely running that level of power, and multiple track days at PIR (not quarter mile, but full track). WOT for 12 seconds is one thing - WOT for 12 minutes is something else entirely. It requires a slightly different approach obviously.
Old 11-21-2002, 06:49 PM   #21
zacek
Member#: 19467
02 WRX
WR Blue
As a general rule, the stock IC will handle Stage 1 power levels or aproximately 280hp. If you plan to make more tnan 300hp (this is flywheel hp) then u may wanna upgrade ur IC. From 281 to 340 an upgraded TMIC is recommended. And from 340 onwards you will need a FMIC.
zacek is offline   Reply With Quote
Old 11-21-2002, 06:52 PM   #22
WhiteLightning
Member#: 21763
2005 MiniCooperS&D2
truck/car Dark Silver
Calling people 'n00b's is an utter waste of time, whopee I myself am new here so maybe I shouldnt be talking, but its all a bunch of crap, way to embrace others and add to their interest in a particular thing, everyone was new once...just because you're a seasoned clubber doesn't give u the right to treat others like crap...SO what if he didn't search before posting, every has done it at one time or another..thats how things go, grow up.
WhiteLightning is offline   Reply With Quote
Old 11-21-2002, 06:56 PM   #23
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
My car is setup for road racing and has been through about half a dozen track events including 40 minute enduro's running WOT all while making big power. Its unfortunate that your poor state of tune toasted your motor.
Zacek: I disagree on your rule of thumb. Lets remember that people will benifit from an IC upgrade the most of they are runnning a turbo past its design limits. This creates heat, the upgraded IC removes more of that heat and more power is made. I took the stock IC into the 11's. Its not a bad unit. When very high 16+ psi boost levels are run an IC is needed more and will make more of a difference. I now run an STI top mount IC that is more then doing the job at 18 psi making 450hp+. Lets all keep in mind that the "HP limit" of an IC would be the flow capabilities of the IC and not the cooling effect or Size.
CT
Old 11-21-2002, 08:00 PM   #24
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
They know each other. Notice their locations? Notice that the person who was called a n00b responded with his own retort and a grin?
jblaine is offline   Reply With Quote
Old 11-22-2002, 05:26 PM   #25
4a-geWRX
Member#: 28851
Sedona Red
Default Noobs
Originally posted by WhiteLightning Calling people 'n00b's is an utter waste of time, whopee I myself am new here so maybe I shouldnt be talking, but its all a bunch of crap, way to embrace others and add to their interest in a particular thing, everyone was new once...just because you're a seasoned clubber doesn't give u the right to treat others like crap...SO what if he didn't search before posting, every has done it at one time or another..thats how things go, grow up.
Yea whitelightning hes just fooling around. Thats my brother. We are actually talking about the same car. I am his mechanic. He let me drive occasionally too . Guys thanks again for all the help. I think my bro and i should upgrade both the fuel rails and the IC.
Matt
When too much is too much for a WRX Kings028 Newbies & FAQs 13 03-18-2010 02:38 PM
how much is too much for the stock gear box? WildBlueWRX Factory 2.0L Turbo Powertrain 1 03-11-2008 09:36 PM
How much HP is too much for the WRX? snvin Factory 2.0L Turbo Powertrain 40 12-02-2004 09:55 PM
How much hp is too much on the stock block? Porkchop-WRX Factory 2.0L Turbo Powertrain 5 10-03-2003 04:15 PM
Message Board Statistics All times are GMT -4. The time now is 09:10 AM.
