Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 11-21-2002, 01:15 AM   #1
Suby
Member#: 15608
WR Blue Vishnu Stage 2
Default Injector Install question
Hey BAIC,
I just installed my stage 2 kit, and part of that required the installation of my STi injectors. I got the car all ready to go and I turned the key to the on position to get fuel ran up through the lines, and the passenger side (closest to the front) injector was spurting out fuel from the top of the injector/fuel rail out in the engine bay. I believe that I may have pinched the top o-ring and that is what's causing it.
Any suggestions besides that?
Another odd thing I found is that the WRX does not use retaining clips to hold the injectors to the fuel rail, it is completely dependent ont he fuel rail holding them into position. IS there anything aftermarket that can hold them down as well for an added precaution.
Sorry for ther questions, and thanks in advance for all the help.
L8R,
King
Suby is offline   Reply With Quote
Old 11-21-2002, 05:46 PM   #3
bluemax
Member#: 6657
it's a pain in the arse but it can be done....you'll run rich and will need some sort of ecu fuel control...However, you can play around with the fuel pressure to fool the ecu.
why pink I don't know..
good luck..BlueMax
bluemax is offline   Reply With Quote
Old 11-21-2002, 05:47 PM   #4
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
good luck..BlueMax
If he's running the Vishnu Stage 2 he gets a Unichip which modifies the MAF sensor values to compensate for the larger injectors.
JD
wackie is offline   Reply With Quote
Old 11-21-2002, 09:20 PM   #5
Suby
Member#: 15608
Thanks for all the info guys I really appreciate it. I took apart the fuel rail again and sure enough I pinched the o-ring, I borrowed one from a stock injector( thanks for the hint man) and generously dapped some vaseoline on it (just happened to have some by chance ) and replaced it again, all is fine with it now, but stilla cting weird when driving, not tuned yet but the car just doesnt seem to have any go, weird but Shiv assured me proper tuning will erase that. IF not I guess i am taking her to Diablo to have them look her over.
L8R,
King
Thanks again for your help
Old 11-21-2002, 10:37 PM   #6
ginowrx
Member#: 6980
non bank got em all
Tommy uses the same excuse when asked " Hey dude what's with the Vaseline" eeerrr aaahhh Just happen to have some dude
Gino
mpjperformance.com
ginowrx is offline   Reply With Quote
VF34+STi Injector Install - Questions on Fuel, Oil & Coolant Jimbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-11-2004 09:08 PM
Injector install question (already searched) PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 3 05-13-2003 04:38 AM
Injector install question- please help jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-30-2003 04:06 PM
PE 650 injector install question. IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-27-2002 03:38 PM
injector install question suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-22-2002 03:46 AM
