Old 11-21-2002, 06:10 PM   #1
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
Default Part # needed for 2-pot backing plate to fit WRX
All I've been able to find is a GDB backing plate which I was told is designed to mate with a different hub (the STi hub).
I have all my calipers I just need the rear backing plates and rotors.
Thanks for any info you can provide.
-Pete
Chunky_Chicken is offline   Reply With Quote
Old 11-22-2002, 01:06 AM   #2
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
bump
Old 11-22-2002, 01:25 AM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default hmmm
Why would you want the GDB backing plate? Do you have a set of Brembo 2pot rear calipers and a R180 rear assembly?
subysouth
subysouth is offline   Reply With Quote
Old 11-25-2002, 11:51 PM   #4
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
I do not want the GDB plate, but its the only part number I have and some people seem to indicate that it can be modified for the USDM WRX hub. I am looking to install my subaru 2 pots, not the brembo 2 pots, although I think they both have the same 104mm eye-to-eye spacing.
There must be a part number since the subaru 2 pots are available in the UK on the samller hub. I've come across plates that fit, but without the ABS sensor hole.
-Pete
Old 11-26-2002, 09:53 AM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default What backing plate have you come across
that fit the 2pots and your R160 rear assembly but didnt have the ABS sensor holes? The only plate I can think of that would fit the 2pots and not have ABS sensor holes was designed for use with the R180 rear assembly(and subsequently 190mm rear parking brake shoes and therefore an entirely different rotor.)
ss
Old 11-26-2002, 10:25 PM   #6
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
I don't have a PN for that one either. A friend just tracked one down, and didn't notice the missing ABS sensor hole. They do fit the R160 though.
Anyone have any idea what the proper PN is?
Thanks,
-Pete
Q for BIGSKYWRX or other brake gurus-Subaru rear 2-Pot Backing Plate Dilemma SubbieAndCoop Brakes, Steering & Suspension 4 08-01-2007 08:04 PM
Need part# for Subaru rear 2-Pot Backing Plate altibaby Brakes, Steering & Suspension 52 03-16-2007 07:44 PM
GC8 Aluminum Control Arms, R160 Subaru 2 Pot Backing Plates, and Rear Camber Bolts keirnna Suspension/Brakes/Handling 21 03-16-2007 06:00 PM
Rear 2-pot backing plates? NicGordon Brakes, Steering & Suspension 1 10-15-2003 04:50 PM
Part # Need for STi Parts Greg 99 General Forum Archive 1 05-09-2000 07:14 PM
