Old 11-22-2002, 07:07 AM   #1
EJ22T
Member#: 26603
1994 EJ22T powered-
majic carpet, Boo yaaa...
Default Modding a Legacy Turbo To get 13 sec 1/4 mile?
I got a legacy turbo recently, and want to modify it to get low 13's high 12's on the 1/4 mile strip. Heres what I'm thinking of doing:
*3" Turbo back exhaust *will do for sure
*93-96 WRX TMIC
Water Injection
*Raise the boost (don't know how much yet)
*bypass Fuel cut and boost cut (any suggestions on how to?)
Possibly aftermarket ECU
Does this sound right, will these mods get me to low 13's? any other suggetions?
Thanks,
Mark
EJ22T is offline   Reply With Quote
Old 11-22-2002, 08:23 AM   #2
morgie
Member#: 3836
2002 Impreza WRX
Search for "FCD" or "Fuel cut defender" on the internet and you'll find the circuit plan to build one !
morgie is offline   Reply With Quote
Old 11-22-2002, 11:35 AM   #3
serious
Member#: 22879
You didn't state what tranny you are running. If it's one of ths sti 4.44 ones then sure, with these mods you might hit lower 13's. With an auto or the stock 5mt forget it.
A wrx at stage 0 ( about 276 crank) in a wrx will do something like 13.6-9's pretty consistantly...at least from what i've read.
You also have to take in consideration your elevation. If you're a mile high then you're going to need a lot to go that fast.
I would recommend the old school wrx tdo5 with tmic. Crank up the boost to a safe level and get a computer. I'd also reccomend a good clutch with a lighter weight flywheel. Exhuast is very critical on a turbo so don't skimp here.
Other than that maybe injectors and an intake mod/ fuel pump upgrade.
Brent
serious is offline   Reply With Quote
Old 11-22-2002, 12:14 PM   #4
EJ22T
Member#: 26603
1994 EJ22T powered-
Why is it that the stock 5MT couldn't do it?
Mark,
Old 11-22-2002, 01:34 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
Legacy777 is offline   Reply With Quote
Old 11-22-2002, 06:35 PM   #6
morgie
Member#: 3836
2002 Impreza WRX
stock Turbo 5mt is 3.9 ratio
Old 11-23-2002, 03:37 PM   #7
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
the stock 5spd legacy turbo tranny is very good and strong enough to handle a good amount of power versus stock 160hp. I do second the advice on getting a new clutch and flywheel.
scubaracer is offline   Reply With Quote
Stock turbo 13.2 1/4 mile l.alvarez1974 Proven Power Bragging 9 01-22-2009 04:08 PM
4.8L 4000 HP 5.5 sec. 1/4 mile 4 banger Colonel Lingus Off-Topic 59 04-13-2006 08:15 PM
12 Sec 1/4 Mile Stock Turbo/Fuel Record Carlo Proven Power Bragging 72 06-15-2002 10:10 AM
Whats mods to get a WRX to burn a 11 sec 1/4 miles time? JammaREXV1.0 Factory 2.0L Turbo Powertrain 16 06-01-2002 01:33 PM
Message Board Statistics All times are GMT -4. The time now is 03:44 AM.
