Old 11-22-2002, 07:58 AM   #1
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Default O2 Sensor Malfunction Code
Hey all. I've asked a few people about my problem, but looking for second or third or fourth oppinions.
Anyway, as of about 2 weeks ago, I've been getting a CEL for O2 sensor malfunction bank 1 sensor 2. I have had the CEL about 3 times so far, after I cleared it, and it started 2 weeks ago, I got another one after a week, and the third a few days after the 2nd.
I could believe that my sensor is dead, but looking around in OBD-II, I found that it is giving readings, varying between .33 and .32 volts at idle. This is normal I suppose.
I don't know why I'm getting the CELs, and I need to get my car inspected before the end of the month.
DeusExMachina is offline   Reply With Quote
Old 11-22-2002, 10:55 AM   #2
SubaruStu
Member#: 8972
2003 WRX Wagon
Do you know which code it is? There are codes that cover things
like slow response, or heater circuit etc, that would indicate a
failing sensor even though it is still giving what appear to be
normal values.
Stu.
SubaruStu is offline   Reply With Quote
Old 11-22-2002, 12:07 PM   #3
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
I have Alex Peper's OBD-II (www.obd-II.com I think) and it only says the malfunction code, it just said malfunction bank 1 sensor 2.
Old 11-22-2002, 12:31 PM   #4
SubaruStu
Member#: 8972
2003 WRX Wagon
That's unfortunate that it isn't more specific. The two "malfunction"
codes for Bank 1 Sensor 2 (the rear one) are:
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
Both of which would indicate that the sensor is dying/dead, especially
if they keep coming back after a reset. That's what happened to
me when my front one died. The CEL kept coming back more
and more frequently until I changed it. I don't know if there is
anything else you can check before having to replace it.
Unfortunately, the rear sensor is the more expensive of the two
(here it is $275 Cdn ).
Good luck...Stu
Car jerks when accelerating, O2 sensor error codes pepper_bg Service & Maintenance 8 12-10-2007 03:05 PM
O2 sensor malfunction + long car ride = ? WRX Shenanigans Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-02-2006 01:35 PM
rear o2 sensor malfunction and misfire#1 x12oyx316x Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-06-2004 12:05 AM
mbc killing front o2 sensor, p0136 code? datdudedennis Texas Impreza Club Forum -- TXIC 4 09-13-2002 02:43 PM
O2 sensor malfunction - questions RigdenZW Normally Aspirated Powertrain 2 02-12-2002 04:53 PM
